SlivenClod
Personal Information
About Me
Subject to planning approval I will be building my second self build shortly
Location
NE Lancashire
SlivenClod's Achievements
Member (3/5)
4
I am tiling into trays that form the treads on the stairs. I have 30+mm depth in the tray and using 10mm tile. I am concerned that there may be some movement in the staircase due to the central spine design. Any suggestions on how to avoid the tile cracking?
I have a warm roof construction - 140mm woodfibre insulation between spars, 60mm woodfibre sarking boards above with water & windproof membranes. Inside is an airtight Intello Plus membrane, all taped and sealed. Then 25mm battens to take plasterboard. My builder, excellent but traditional, wants to use Duplex, foil backeded, platerboard on the ceiling. I am unsure on two counts, first, they are 50% more expensive and second will it negate the performance of the "smart" VCL we have? Any suggestions please. Thanks
Marmox Thermoblock under SIPS?
SlivenClod replied to Post and beam's topic in General Construction Issues
I am just about at this stage and having "discussions" with my builder. Please can you sketch this out please so I fully understand it. I would be very grateful. -
I am planning a similar patio area. What sub-base did you have for the pedestals?
Some suggestions on waterproofing please. The flat roof to the garage is to form part of the patio. I feel the spec for the waterproofing proposed by the architect is inadequate. I also have concerns about insulation below the planter. The load bearing is provided by the beam and block flooring and I intend to build a fall towards the back of the garage where ity picks up draing form the rest of the patio. All this below porcelain tiles on pedestals The garage will have minimal heating. The two sections have conflicting text detail on the buid up, which doesn't help. Thought? 11G SECTION B-B.pdf 12F SECTION C-C.pdf
Hello again, I joined this forum some time ago as I made my first planning application. Two years on, after much frustration, we have our planning permission. In the intervening time I have gone from traditional construction to SIPs and now looking at timber frame. We are looking to be as close as we can to Passivhaus with ASHP, PV panels, MVHR. What are the relative merits, pitfalls and costs of the two systems. And peoples experiences in construction and in use. I have attached a couple of drawings to help inform your suggestions Thanks06A PROPOSED PLANS.pdf07A PROPOSED ELEVATIONS.pdf
I have just come across Sunflare Powerfit 20 thin flexible solar panels. Designed to sit between the seams on standing seam roofs. Has anyone any experience with these? They are America so not sure if available in UK
How to finish around door casing without architrave
SlivenClod replied to Pete's topic in Doors & Door Frames
Have you thought of creating a shadow line? I would be worried that the plaster would start to fail with the movement of the door in your sketch. I have seen it done like this - and I am planning using this to do away with architraves -
Thanks for that. I can now just use a backdrop at the point nearest the connection to the main to shorten the deep digging.
What is the maximum slope allowed on foul drainage lines? I have a sloping site with >2m fall. House at the top and connection to main sewer at the bottom. I am guessing a back drop(s) will be required somewhere.
Exterior Wood Fibre for SIPs
SlivenClod replied to davidc's topic in Structural Insulated Panels (SIPs)
@jack is your cladding on to SIPs? I am considering vertical timber cladding onto SIPs and finding it difficult to find details on suitable product, on fixing method and general arrangement. -
Has anyone used/got experience of thin film solar cells? I am getting resistance form HWMBO that PV panels are ugly "I'm not having those on my nice new house!" The plan, at the moment, is for raised seam metal roofing and I understand this works well with TFSP and I might get it past the design guru!! TIA
I understand I should be keeping it out, but we love the outdoors and we have fabulous views. So how do I make best use of the PV generated power other than AC on the hot days? PCM heat store, MVHR, ASHP, ? Is it worth having an old fashion immersion heater for DHW? As you can see I am might confused at the moment and trying to absorb as much info as I can.
This would seem a good thread to ask this question:- I have concerns about over-heating due to glass and aspect and solar gain. Now, if the sun is shining to warm the house would it not be a good idea to run AC from PV array to cool it for free? Sounds too simple
Still at planning stage.... As we are on sloping site we are planning to have the living area on first floor and bedrooms beneath. I had it in my head that we would have a pot & beam floor as we are looking at UFH from ASHP. What about bedrooms? I have read elsewhere on here that upstairs bedrooms require little or no heat as heat comes up from heated rooms below. We won't have that. There will be a far amount of solar gain, in fact I am concerned about over heating, so will probably have MVHR system. Could this be utilised. Ideas please.
