canalsiderenovation
    9
Everything posted by canalsiderenovation
  1. I'll have a play around now to see if I can change it. I think Alto have blocked off being able to make any changes/locked it. If I can get into it I'll reduce the temperature to about 45 degrees.
  2. Found an online version of the manual https://www.samsung.com/uk/support/model/MWR-WW10N/ If anyone has any suggestions that would be great. I tried to navigate but the only screen I could get to is this.
  3. Success but I can't see anything about flow temperature.
  4. Don't get me started! We did look at this as we have a good flow but it was a no goer - CRT.
  5. Yes we don't have gas and our ground was not suitable for GSHP so our options were limited unless we wanted to stay on oil. We did go down the RHI route and our payments will start in March. I just need to do some monitoring of the meters now and see what's happening. If anyone knows how to reduce the flow temperature then that would be great.
  6. Exactly. In the three years we had the house before renovation we had heating for a month until it packed up and we survived with just the logo burner in the lounge albeit we moved the bed into the lounge. It was not pleasant. We are both nesh and I'm always complaining I am cold.
  7. How do I turn down the flow temperature. Well we survived last year with no heating, I'm going to try 19 and see how we get on. 22 degrees was nice for us but I would have had it warmer so I'm not sure how we are going to find 19 degrees.
  8. We can't get gas due to our location.
  9. We want our heating on all the time! Their daily rate with Octopus is however more competitive than the cheapest rate we can get elsewhere (see my first post) and then the 5.00pkwh during those few hours that would help. We don't have an EV.
  10. Thanks @SteamyTea yes we are in Whitchurch (as long as you have the Whitchurch in Shropshire not any of the others)! Let's see how we get on over the next week and I'll monitor. I wonder if we just have had the house very hot unnecessarily! We haven't got our external wall insulation yet and hopefully once the solar is up and running it will fair better. I need to look at those tarrifs too and work out which is best to move to, especially the one from Octopus which seems to have day rates on a par with others and then the cheap rate between midnight and 4am.
  11. Ok so I just spoke to Alto and they told me to take the meter readings from the H/P and immersion and to keep a record of this along with my normal electricity meter reading. So: HP 11903.98 Immersion 0155.14 Electricity reading 09945.3 Reduced all thermostats to 19 degrees and will monitor for a week.
  12. Ah I've found something else now in the handover pack.
  13. I'll check our variable tarrifs. I've found some information from the MCS installers.
  14. We were using 300 units a month not a week pre renovation! We only had our immersion on as and when pre renovation not consistently.
  15. We were using a max of 300 units a month and both working from home. We didn't have any heating as such as it was knackered oil so just used the woodburner or layered up but we had an electric shower and the water was all heated by immersion and we had all inefficient appliances and an oven which took an hour minimum to cook anything no matter what and we were paying the same rates as now. I've turned all the room thermostats right down to 20.5 degrees now but now thinking I'll go down more. At this cost I'd turn the heating off completely and just burn wood! We still turn TVs off from standby but we have got now appliances on standby and the coffee machine and Quooker gets a lot of use.
  16. Erm, how do I find this info out? I'm panicking! Probably before as we were only using about 250 units a month albeit we only had a stove for heating and our hot water was immersion/electric shower. I'm reducing all temperatures now to 19 degrees on the thermostat. The hot water we don't mess with and that comes from our heat pump. £100+ a week in electricity seems crazy.
  17. I'm a bit concerned on our electricity use. We moved back into our house over Christmas and the ASHP was commissioned early December. We have had the heating on 22 degrees with the room thermostats set at this temperature. I took a meter reading on 7th Jan and it was 09359.1 and today it's 09945.3. This seems an awful lot in just over a week *slightly panicking and thinking we need to reduce our temperature* Alongside this our fix is up for renewal and I've been looking at tarrifs. We both work from home and we have (or will have soon once the electrician recovers from Covid) the solar working and the Solic 200 to divert excess to the Immersion. Whilst I don't think Economy 7 will suit our lives I've been comparing tarrifs. Bear in mind we have never lived in an all electric house it's a bit difficult Symbio has a 12 month fix at 14.678pkw and 19.500 per day standing charge but Octopus seems to be as competitive with the Octopus Go charging 14.63pkw day and 5.00 during the hours of 00:30-04:30. Even if we don't use it during these hours the day rate is still competitive and we could set timers to charge things up. The standing charge is more expensive at 25.00 a day against Symbio but this Octopus still seems decent. Finally, do we have a smart meter? I think it was installed by the last owner because we haven't done anything.
  18. How do I convert to cubic meters?
  19. Wife now thinks she may have been in shower over 20 minutes so it could be she completely used up all the water! This hasn't happened when I've had a big bath and she had the large showerhead on and the Mira shower is really powerful. I should have got on the app whilst she was in and adjusted the temperature to cold.....
  20. Hmm so it seems to be almost a third of the way up. Tank height 197cm and that flexi is 68cm. I can't see any lower point - there are higher points not lower ones. I'm presuming it's as good as it gets as it is?
  21. No small wire I can see you less you mean the black one? Water is back hot again so it may be the wife used all 400 litres which seems crazy.
  22. So, wife had a shower, washed hair face mask etc. She says around 15 mins max. Around 10 minutes later I went to wash my hands and hot water is cold. Even now hot water is only lukewarm. We have the washing machine on but that's it. With the best will in the world I don't think anyone can use 400litres in a shower. Do we need to ask Alto to come out and look at our ASHP? We still don't have the solar up and running and excess diverting to the immersion as our builder tested positive for Covid today so now pretty much all of them are self isolating!
  23. This is our front door. In the absence of any LVT what would you say is the best option? This is only very small so would hardwood be OK again or is there anything else which would work?
