SilverShadow
Everything posted by SilverShadow
  1. Thanks guys, very insightful as always 😁 To clarify on Redbeards cost £2500/m2 - i think that's for a double storey extension, based on what i can read? But to clarify on Q3 (which i worded extremely loosely in hindsight 🙃), i was hoping for 'finger in the air cost' for an architect to draw up the designs & building plans for the builder to use. Realise that might be difficult to gauge on the above info, but just whether we should expect £500, £1000, or more sort of bracket?
  2. Hey guys - been a while since i troubled you good folks for advice. But that time is nigh again.... 😉 We're looking to extend our house next year (build over single storey adjacent garage & some internal room layout alterations). We're at the initial 'chat about proposed changes/ initial quotes' stage & struggled to find builders with the right credentials, or those willing to get in touch. So, i've been in touch with these guys, who dropped me a line: https://www.mastertradesmen.co.uk/ They've asked regarding PP, building regs, permitted development I wanted to ask you guys a few fundamental questions, please: Who determines what aspects of PP, regs, PD are relevant? I was under the impression the builder would consider this, but that may be a bit naive, and perhaps it's something we should ascertain independently up front? Architectural plans - are we best engaging an independent architect 1st, and getting this drawn up before engaging builders? Architectural costs - realise this is a 'finger in air' guesstimate, but does anyone has a rough idea what these might cost? (for an extension over garage, on a 3 bed detached property, with some internal room layout alterations)? If anyone has some good web-articles about the steps, process order, rough costs that would be hugely appreciated 😁 TIA Shadow
  3. PS - ignore the above illustration, this is more like it: 75mm PIR board (yellow) - arranged horizontally (concrete floor to ceiling (mecahnically fastened as mentioned) 35mm batten - glued to PIR with adhesive (i hope!) Option 35mm yellow PIR to fill the void the batten creates. Arranged vertically, so the PIR is x-crossed to reduce moisture escapage 11mm PIR screwed into 35mm batten Sorry guys - i'm really keen to do this, as i feel it'll be very worthwhile. But i'm a details person and like to have a clear picture before starting (especially with the cost involved!) Many thanks Shadow
  4. Slight update on this guys... Firstly, huge thanks for your time and insight into this - always appreciated. Secondly, i've put this off due to work & other commitments, but looking to resume this soon..... Using the pic i previously enclosed, i'm hoping the following will be a sound strategy: Breeze block interior face - i don't intend sealing this (so it'll be breathable from moisture coming through in/out) Yellow PIR - i'll use 75mm continuous PIR (floor to ceiling, all taped edges/joints) and my VCL. I'll mechanically fix these boards to the breeze blocks & tape over (i heard dot n dab isn't as good with porous external walls?) 35mm wooden battens - i've read Pinkgrip Fastfix Foam is a good alternative, for fixing the wood onto the 75mm PIR I may fill in non-electical gaps in the 35mm void (between battens) with extra PIR for extra insulation I'll fix 11mm Osb3 on top of the battens as the interior wall surface Does that sound feasible to you guys? PS - would you insulate the walls 1st (floor to roof), then floor 2nd and roof last? Indebted as always....
  5. Thanks Nod 😁 I guess with it being 3 to 1 dilution of brick acid then the upvc should be relatively ok. At least for a few mins, until its cleaned off 🤞 I think that was the difference - I'm sure most builders aren't like them, but it was builders doing a bricklayers job 🙃 All they needed were Stetsons 🤠
  6. Hey all - hopefully a nice simple one guys, but then that's often been the way at posting time...... 😅 We have a few m2 of brickwork that was recently mullered by a builder when re-pointing. It's very rough cement finish, that's made the brickwork look scruffy. I've seen/read that brick acid might be our saviour here (either Sika or Bostic Cementone Brick/Patio Cleaner). I've read up on the application (PPE and general application rules), but thought i'd ask anyone who's used the products before for a few hint & tips Any clarification on the following would be amazing, please: Wetting the surface 1st - apparently this helps reduce the bricks absorbing the acid into them? Also scrubbing some chunks down with a wire brush 'pre-application' is meant to help Application & cleaning - i was just going to use a paintbrush & try not to dab the intra-brick mortar too much (so its only really the brick face having it applied to) & use the wire brush again Application time - probably on the product, but i'd assumed just a minute or so before cleaning off with plenty of water? Brickwork is near upvc - i'm a little nervous any splashes might damage the window/door. Even though it's diluted acid, i wasn't sure if it would damage them (maybe plastic/tarpaulin would help protect, or am i being over-protective)? PPE - gloves, mask, googles, long sleeves Other products - anyone ever used other less-hazardous products? I've read lemon juice might also work??? If it helps, our bricks are rough face/porous (Heather brick finish), so wasn't sure if this would alter our approach. Happy to provide pics, if that helps Thanks as always for your valuable insight Shadow
  7. My thoughts exactly - chances are we'll get a heat pump sometime in 2026/maybe '27, depending on when we get the work done. From what i can see, the same grant will still be in place & maybe prices will have come down £1-2k by then
  8. As an aside and distraction, i followed up with the part on here mentioning heat-pumps...... We had a firm pop around to give us the spiel around this, just so i could have all the facts/costs to hand: They were quoting circa £16k, for pump & installation (Vailiant, Mitsubishi, or Samsung - air source version). They also rightly (as mentioned on here) said they wouldn't put the pump in the garage, nor the side of the house (where the neighbours fence was <1m from our wall exterior) where we hoped it could live. The did offer to install above the garaqe. However, as it's a sloping 'non-load bearing' roof then it'd need scaffolding, which would make the yearly servicing expensive/ impossible. It also seems like we'd need a servicing plan (circa £15/month), which i'd imagine pays for the yearly servicing up front. They did offer to fit in another slot at the rear corner of the house. However, as we're potentially having a 2 story extension there next year, i was a little worried about damage/needing to remove it, in case any of the foundations/wall brickwork needing doing (as yet, we don't know). They were also a little sketchy about allowed rads with it (we were planning to use some Milano Aruba ones) - i guess they'd need to know if these are to spec as regards pressure/heat exchange, etc? A heap pump feels like something we might do 1 day (with the £7.5k grant) in place, but maybe not with potential building work going where it's suggested location would be. They did mention the £7.5k grant would drop to £5k in April this year, but i couldn't find anything around that
  9. Thanks Nick for all your help Just thought i'd ask the last question, as it may be that space could potentially be an issue (if we located to somewhere that has a relatively small m2 outer wall area)
  10. Thanks Nick, good to know this up front 😁 I hesitate to ask more, but I have another general question, & your knowledge is golden: For housing the combi boiler, does it always have to live on an outer wall, so the vent/flue go directly outside? Realise in the loft this won't be the case if the flue goes out the roof, but wasn't sure if you could locate the boiler on any house wall & have a flue (eg 1-2m long) from it to the outside?
  11. Thanks Nick - we've got an extendable loft ladder that you can pull down no probs. It's lit & with floor boards. As a side question: do you know of any problems or no-no's with putting the combi vent through the roof tiles?
  12. Cheers Nick, Only other thing we thought was whether some plumbers don't like going into the loft for servicing them? As a rough guess, i'd imagine the taps would be 5-8m from the loft combi
  13. Thanks Nick - we were looking to upgrade the rads as part of the refit (we've been looking at Milano Aruba, if you know them). Our existing system already has a cylinder, so that wouldn't be too much of a problem i guess Essentially, when we change the CH it'll be not only a new heating system (eg: combi), but also new rads and a new location for the combi. We may opt for the combi in the loft (and a vertical vent through the roof tiles, as no gable end wall), but that's TBC A heat pump was just something else to rule in/out. If it can't go in the garage, then it's a no-no, and if there isn't some variant (other than gas boiler) we could fit in there that's covered by a grant then it's combi as suggested above 👍
  14. Many thanks for the advice, guys Sounds like a combi is the way to go. I've heard good things about Valiant, although read they use aluminium heat exchangers (apparently steel is best) Something else we might take a look at, is a heat pump. Given there's a £7.5k UK grant, if we can get a decent one fitted for <£9k it might make sense. It'd have to be fitted in the garage though (which i've read conflicting reports as to whether it's viable)
  15. Thanks guys - the boiler is probably another topic in itself For the record, it's a fairly small detached house (probably 8 or 9 radiators, once we've reconfig'd the house), 1 bathroom & only 2 of us here. The boiler's prime use would be heating a few hours a day, morning showers & the occasional bath. We don't have any solar, & a heat pump likely to be way too bulky/expensive for our needs. Perhaps i'm wrong, but a full system boiler with tank feels a bit excessive & a combi would be the ideal solution?
  16. Thanks NfW - very useful. Yeah, i'd thought reusing the pipes might be feasible (with a lot of cleaning out!). From what i can see, none of pipework is microbore (at least, the pipes connecting the rads aren't!) I wasn't sure how 30-40 year old soldered joints would stand up to the rigmarole of being yanked and dragged about when reconnecting/relaying the new pipework. Given that (afaik) combi systems are higher pressure than old gravity-fed, i just wondered about any minor leaks as a result. Realise there's never any guarantees anyway, but i'd assumed soldered joints would be just fine
  17. I'd assume it's a system one, as it has cylinder & expansion tank
  18. Hey folks I'm sure this question gets asked 1000 times, so apologies in advance if it has...... We're looking to replace our CH system in the next year (install a new combi-boiler, to replace the old gravity-fed boiler that seems to come from the steam-locomotive age! 🤪). This will likely involve moving the boiler location & hence alter the pipe layout As part of this, i was originally planning to replace all the existing copper pipes. However, an old skool plumber mate of mine said it was just waste/way for plumber to maximise profits. Tbh, it's not as though copper 'wears out', but i'd imagine it'll be clogged with sludge Is he correct on his assumption it's ok to reuse the pipes? If we kept the old pipes, i presume they'll need flushing out thoroughly? A newer combi-boiler CH uses a higher pressure, so i wasn't sure if the old joints (soldered i'd presume) would stand up to this? (I'd bet the old gravity system is at least 30+ years old) Any thoughts or ideas on this most gratefully received 👍 Shadow
  19. Mamy thanks, Eric - exactly what I was after 😀
  20. Indeed - we recently had EPS (not EPC, as i mistyped! 🙃) retro-fitted to our house & it's made a huge difference. The process is fairly quick (albeit noisy & potentially a bit messy), and involves drilling holes though the exterior brickwork cement, at intervals, to blast in the beads (which have an adhesive coating). I can't be sure of costs, n terms of your extension. We had ours done as part of the GBIS gov't scheme, which should help pay for costs. I don't know if an extension would qualify for that scheme (or ECO4, is another govt scheme) Ideally, (as others have mentioned) you really want this to be fixed by the original builder - but if all else fails, options like this could prove viable
  21. PS - do you mind me confirming: does the 'clear' one dry to an opaque colour, please? I think white will be too harsh in some areas. Likewise, clear (if it cures as 'fully clear') can also be unsightly
  22. Hi there, Sorry to hear about the shoddy way you've been treated. Out of all the trades, i've always found builders to be the ones to be most-wary of I'm sure many on here will have much more sound advice than me (i'm usually the one asking for advice), but this article may be helpful in terms of next steps: https://www.checkatrade.com/blog/ask-a-trade/how-to-deal-with-cowboy-builders/ You can also get insulation retro-fitted into the cavity wall, as a last resort (EPC beads, for example) Apologies i can't give anything more specific - i hope you manage to resolve this
  23. Hi there, Hopefully a quick and easy Q, for you guys in the know! I'm looking for a decent translucent sealant, and wondered if anyone could recommend something please? A few basic details, if this helps: For exterior use (mostly around window frames) Translucent (definitely not 'clear' or white) - i prefer the 'opaque' look where possible, as it'll be used against various materials and gives the most consistent finish Silicone based, unless anyone thinks a caulk is superior? Preferably something readily available (eg: Toolstation/Screwfix, etc) This seems to be in with a good shout 🤔 https://bonditgroup.com/products/gp200-general-purpose-silicone Many thanks, as always Shadow
  24. Thanks, man I did look around, but all the prefab concrete products i could see were either too thick, too wide, or i needed to bulk buy. If i can find something 40mm x 40mm up to 1m long from a national retailer (eg: Travis Perkins) then that would be easiest. If not then i'm happy to try casting one as a project/experiment - the idea is to pour into a wooden cast it & let it solidify, take the doorframe out & lay it in place, then put the frame back (rather than try to slide into place or make it in-situ). Sounds like good advice for how to make it 👍
