Adam E
Everything posted by Adam E
Timber frame vs ICF vs Traditional masonry for a new build
Adam E replied to Indy's topic in General Construction Issues
I went with Scotframe their engineers specifies straps to slab, and soil investigation company and structure engineer specified raft foundation with enough steel to build a battle ship I was really interested is a insulated slabs as a few on hear have done but non of my professionals had worked with them so went with traditional. -
Brilliant thanks so Much I have just turned it off, really easy when you know how thanks again. Adam
Hi what are the author settings
Hi trying to turn off freeze stat, I have a 8.5kw ecodan latest version when you see the time the freeze stat was used and the fact that the system has Glycol I would like to turn this off on previous posts it mentions auxiliary settings but can’t find freeze stat anywhere is it a dip switch settings? Any help appreciate Adam
Hi I realise this is an old post but covers my problems I am trying to turn on the Freeze stat mode on my ecodan 8.5kw asht latest version when I go into auxiliary settings I can find no mention of freeze stat the system has glycol antifreeze but when I seen this pie chart I was concerned as how much it was running any ideas how I can turn this off. Adam
I also could not get a temporary habitation certificate (Renfrewshire council). Say no longer issued.
- 11 replies
- vat
- completion
(and 3 more)
Building Control Completion at last (and some statistics)
Adam E replied to ProDave's topic in Building Regulations
Thanks for the feedback hopefully everything will work out ok for us and a holiday will be in order next year -
Ok I understand now. How long did the vat reclaim take. -
Hi Dave , we had building control out and are in the process of getting a few things sorted including a certificate for the mvhr which I self installed so congratulations on a massive step forward we haven’t done anything about the vat as I thought you needed the compleat certificate before you could claim the vat -
No idea of your build details but this might be a option https://www.ecomerchant.co.uk/news/paint-on-airtightness-really-are-you-kidding/
Digger ! looks as if It was cut with a laser from Star Wars Enjoy your well deserved cider
Hi it’s a standard (Toby ) that’s what it’s called in the west of Scotland, if you have a standard water key it will fit on to the flat bit which you need to turn a quarter turn, if you look just now the flat bit is in line with the pipe below turn it a quarter turn so it is across the pipe it usually doesn’t mater if you turn left or right but turn it clockwise , some time they are very tight but it will go.
Thanks to all, I will also incorporate some sort of safety device to avoid potential problems !
Hi that looks great,I was looking for the easy option but will start looking at unit options. Adam
Hi all I am looking for units for raised washing machine and dryer, I found this online which would be ideal but no UK delivery due to brexit https://washtower.com/ any suppliers in uk ? Adam
Hi-tech gadget to trace the route of a drain.
Adam E replied to epsilonGreedy's topic in Party Wall & Property Legal Issues
Hi we had to get a company in that located the main sewer it was supposed to run along the edge of the pavement according to Scottish water but was one meter into the road,it cost around £400 they opened up a man hole cover and had a massive coil in the back of the van with a transmitter of some type that could be picked up by a cat type tool -
Hi not sure about flow and pressure as a friend who worked for Scottish water did our application if it is made up ground both Scottish water and building control insist on using a barrier pipe i tried to post the link but not good on computer but if you google the heading below you will see the pipe with a red marker line to identify it. Adam POLYGUARD MDPE BARRIER PIPE
Hi we are on the final stage of a Scotframe build The 2 points above are very relevant we extensively modified a existing kit the kit itself was extremely well made and we also ordered all windows and doors through them as stated above the vat has to be paid upfront so that is a big consideration the communication from scotframe pre delivery was very poor but after the kit is delivered we had a scotframe project manager for any issues or queries (Jamie ) who was excellent to deal with its a a very good product, but I would look for a kit manufacturer that will supply and erect the kit saving the vat and provide a better service to the average self builder adam
Hi I tried to get a interest only mortgage for our current home to fund our new build I went through a mortgage broker but the only interest only mortgage were for buy to let not owner occupied we are in Scotland but I would check availability of interest only loans first adam
Boarding/Sheeting between the rafters and felt
Adam E replied to Kev1312's topic in Roofing, Tiling & Slating
Hi it was made by celotex among others usually 12mm thick it’s like fibre board with tar mixed through it Marley contract services used it on all the large sites in Scotland in the 1990 ‘s as a replacement for sarking boards if you google (Wood Fibre Insulation Sarking Boards ) you can still get some results but it is a very poor replacement for traditional sarking boards or osb sheets adam -
Hi just a update ashp and ufh working fine, still to fit the salus Auto Balancing Actuators I just opened up the loops and checked all the feed and return pipes were heating up and put the hot water on for a while and everything seams fine thanks pro Dave and Scotland for your help Adam Underfloor Heating Wiring Ctr.pdf
Thanks I will alter switch to on if I have a problem but will try default first thanks Adam
Brilliant thanks I will try that in the morning and hope for the best and post how I get on. Thanks. Adam
HI Scotland did you have to alter any dip switch positions ?
trying to scan wiring centre Underfloor Heating Wiring Ctr.pdf
