Tony K
Everything posted by Tony K
Hi I have agreed a deal with my neighbours whereby I get some temporary vehicular access to my SB plot across their private roadway, and in return I will fix a few holes in that surface. There are three or four areas similar to that shown here. I had originally thought to cut out a neat edge around the broken areas with my large angle grinder, remove everything inside the area, then use tarmac to repair it, having applied fixing solution to the fresh edges, and then melt fixing strips on top of the joins. My concern was that tarmac might not do well with the rebar which is in the current surface construction, and I am not sure that removing the rebar is a good idea. When I spoke to one supplier today (Meon UK) they suggested I use their Hardmaster w615 stuff, which is like a flowing concrete you mix with water and pour in. This stuff operates in depths between 30mm and 250mm. As you would expect, I have to remove any debris and loose bits, apply some sort of sealant to the exposed rebar to prevent it rusting, then pour the stuff in. They advised me to create a neat edge if possible, though apparently it's not essential so long as the edge is stable. The problem with this method is that there are lots of areas where I would have to break out pretty stable, sound material just to create at least 30mm of depth to pour the W615 into. The damaged areas are like mini craters - deep in the middle but progressively more shallow to nothing towards the edges. Even with a slightly different product (Meon do a W660 which seems to operate between 10mm and 100mm) if I feather it out at the edges I will naturally be creating areas at the edges of the repair where it could split, crack, fail etc. If anyone has any experience of doing decent, but economical repairs to roadways I would be interested in your opinion. Thanks
Full Plans Approval - can the Inspector overrule?
Tony K replied to Tony K's topic in Building Regulations
That's it, yep. The nominal / notional / nocturnal / whatever it is boundary was, in this instance, the far side of the footpath from me, so it can be stretched even further than the centre line depending on circumstances. The really important thing of course is that it is, in fact, fire safe. The building inspector apparently had a quick chat with the fire safety officer about my set up, and both were happy, so that might be of use to someone on this board in a similar position. I had prepared a fall back position whereby I proposed a fire door, but happily I didn't get to test run that argument. Finally, my original post posed the question: Can the inspector overrule the plans checking authority once they have approved a set of plans? Well, the building inspector himself told me today that legally he wouldn't have a leg to stand on once the plans had been approved (which is how it should be, otherwise why have the full plans procedure?), though whether he would have issued final sign off when push came to shove is another matter perhaps. -
Thanks all. No sooner had I posted than the local building inspector turned up unannounced, said he had spoken to the fire officer and to the checking authority, and was now happy for me to proceed as planned! I've also had the neighbour over to clear the air, which was nice. And it's sunny here today too. For those who are interested, the dispute was over the interpretation of part B4 of the regs, and whether it was safe for me to build a house to the edge of my plot, with a door facing onto the boundary. The regs say that any wall with an opening (doors, windows) greater than 1m2 must be one metre back from the boundary to prevent fire spread risk. It is a difficult thing to envisage, but our neighborhood is very olde wordle and higgledy piggledy, with access via a series of footpaths only. The checking authority were happy that the footpath outside my plot was sufficiently wide that there was no risk of fire spreading from my house to my nearest neighbours (who by the way, have recently built an extension with doors and windows facing the same path!). The local inspector originally less pleased, and minded to say I could not build to the boundary and have a door. This is to do with the difference between the legal boundary and the nominal boundary for building regs purposes. Your actual legal boundary is not necessarily the boundary for the purposes of making a fire break. If the land between you and your nearest neighbour is never likely to be built on (so a road, river, access or whatever) then it is legitimate for your building regs inspector to feel that there is a fire break there already and you don't need to provide one by stepping your building line back. Here endeth both the lecture and the stress! -
Hi all After obtaining planning permission for my SB, I then got full plans approval under the building regulations. I used a partnership authority arrangement, where your plans are checked by the officers of a local Council other than your own, but the actual site inspections are undertaken by your own local authority building inspectors. My full plans application was approved under the building regulations by the checking authority. I have now started digging the footings, and my neighbour, who will not listen to reason under any circumstances, has complained to the local building control officer about an element of the project. Everything is, and will be, in accordance with the approved plans. To my amazement, the local building inspector tells me that he is minded to agree with the complaint, and find that this particular element of the SB is not compliant with the building regulations. I have contacted the checking authority who have reiterated that there is no issue whatsoever with this aspect of my design, and that it was considered fully against the regs when they approved it. Leaving aside the simple fact that he is wrong, can the local building inspector overrule the fact that the project has full plans approval already? I believe his role is simply to check that the work is carried out as shown on the plans, not to revisit the decision to grant approval, but I cannot find a regulation or law to that effect. Has anyone experienced such a thing before? I've put the local inspector in touch with the checking authority who are happy to speak to him, but it is stressful. Thanks!
Deep, narrow hole for a pump. Can a mini digger cope?
Tony K replied to Tony K's topic in Foundations
I can only get a mini digger on site, hence the concern. I think I've solved the problem now. I will rearrange the attenuation tank into a more shallow pattern, allowing me to use a 1.5m deep pump. This in turn will only require a 1.7m deep hole. -
My own advice is to never, ever rely on a phone call to the planning department, or even a letter /email. Firstly your likely to get through to some kind of generic reception, or at best the admin department of the planning office. Actual planning officers are now so thin on the ground and often dealing with large workloads that the last thing they are allowed to do is answer general enquiries. Secondly, even if you get a reply it'll either just direct you to generic information sources (not helpful to you in this case) or offer an informal view that comes with a disclaimer, and so doesn't offer any protection. As @DevilDamo says, you can apply for a certificate of lawfulness, but if you're going to do that you may as well just apply for planning permission. Personally I'd be tempted to just put the fence up. Based on the photos enforcement action seems unlikely, but there is a risk of course.
- 128 replies
- planning permission
- fence
(and 2 more)
@Al1son There are three things I would add to the correct advice given already by @DevilDamo 1. Explore fully whether the path is one over which the public have the right to pass. Even if the wider estate is owned by the Council, the pathway may be for residents only (i.e not for the public, regardless of whether they actually use it anyway), and if the estate is private (i.e the open areas outside the houses are not maintained by the Council) then it is likely the path is not public. Look for signs around the estate saying 'private, residents only' etc. 2. If you do need planning permission then either accept it and apply, or accept the risk of putting up the fence without permission. A great many houses get a slightly rougher deal in terms of needing planning permission when their neighbours do not. A classic example is of a house at the very end of a street, adjacent to another road. A fence over one metre high in the location marked in red needs planning permission, where all the ones in green do not: The good news is that no sensible planning department is going to refuse a decent tall fence in the red locations. The bad news is they can't help the fact that you technically need planning permission, and can't give you a short cut to the system. An application may be overkill, but it is legally necessary if you are adjacent to a highway. Of course, you could just build it and see if they come and make you take it down. They probably won't, but there is a risk there, and its probably not to be advised therefore given the relative costs of an application vs the fence itself. 3. Check your deeds. Even if you don't need (or you obtain) planning permission, some estates have restrictive covenants in the deeds preventing tall fences. That's nothing to do with the planning dept, and you should consider it sepeatly. Good luck!
- 128 replies
- fence
(and 2 more)
Yeah, dig down in stages. Could work, but when I come to put the clay back in the hole the driver is sitting in, it often won't play nicely. More to the point though, would you think a decent mini digger can go to even 1.4 deep in thick clay? Should be OK surely, but I've not gone so deep down with a small machine before. For context, the top level (i.e the garden) has already been reduced by about 60cm from its original level, so I am actually going pretty deep down from original ground, if that makes a difference. Thanks for the suggestion. -
Afternoon all. My SB, on nigh-impenetrable clay, needs a pump to discharge surface/rain water into the main network. The drainage engineer has designed a standard system whereby an attenuation tank (basically soakaway crates wrapped in plastic) links to a large pump. The tank has got to sit a certain distance below the surface, simply so that it is buried under enough weight not to float up out of the ground. The pump must sit a certain distance beneath the base of the tank, otherwise the system doesn't work: Thing is, the hole I would need for the pump is about 1.8m deep. I can only get a mini digger to my site, and though we have used a great little machine to dig out a mountain of clay so far for the footings etc, I am concerned that it might not reach so deep into the clay for this job. The spec says it can reach, but I have heard that there may be more to it than what the spec says alone! Has anyone used a mini digger to go that deep? Any problems at all? My other option is to create a more shallow, but equally voluminous tank, which I can do by laying the crates across the site more and into the ground less. That means the pump will only need to go about 1.4m deep, but even that seems no small task for a mini digger. If anyone has any experience on this issue they can share I'd be grateful!
Hi all This is almost certainly a daft question to those in the know, but... My SB is flat roofed, and I have designed it with a fairly high number of small rooflights to fit between the joists. This is helpful in that I don't have to muck about reinforcing larger openings, but unhelpful in that I have to build far more upstands than I otherwise would. Is it possible to get rooflights with the upstand supplied as part of the unit, and if so, are they any good? Finally, if anyone has a recommendation for cheap, small rooflights I'd be grateful. Thanks
@Bozza sorry I meant to reply sooner. Everything you say is plainly right and I have followed your advice. Cheers
It's an interesting idea in many circumstances I'm sure but to be honest I've done an awful lot to appease them already. I'd probably rather give the money to the surveyor!
Yes I had seen that no response is the same as an objection, just wasn't sure about whether I paid for the lot. I'd be grateful if anyone has any suggestions on an appropriate person to act for me in the PWA. There isn't any dispute over boundaries and I'm not altering their foundations at all, so I'm looking for someone to confirm that which my engineer has already committed to: that the works won't affect my neighbours. I presume that does not have to be a traditional pw surveyor?
Thanks @Mr Punter that's what I needed to know. All my other questions fall away in that case. I will get a price from a PW surveyor and hope my neighbour doesn't waste any more of my money. If we enter 'dispute' as its called, do I have to pay for their surveyor as well?
That's what I really wanted to establish. Obviously my steel screw piles will be deeper than any surrounding foundations, but do they actually count as 'foundations' for the purposes of the act? I can understand driven or bored piles being considered a foundation, but the screws can actually be taken away again, and so could perhaps be treated differently?
Thanks all. I have read the guidance and understand the regulations, but they don't seem to address the specifics of this case, hence my original three questions. I get on OK with the neighbour, though he is a worrier and I think he wants the PWA process so that he can get surveyors involved, all at my expense. That's his right of course, but given I've already shown him my insurance cover, and a specific piece of work from the engineer putting his name (and his professional indemnity insurance) to the fact that my work will not affect his house, that all seems a bit OTT, hence not wanting to do the PWA if I don't need to.
Hi all. My SB is within three metres of the rear elevation of my neighbours house. Between my plot and his house is a footpath about 1 metre wide. His house was built circa 1905 and then extended last year. I am excavating my plot down by 68cm, then using screw piles with a slab on top. Three questions arise: 1. A PWA is required if my footings are deeper than my neighbours, but am I comparing his footings to my 68cm excavation or to the depth of the screw piles? The screws can be unscrewed and taken away in future apparently! 2. My neighbours extension has 1m trench footings, but the original section of his house is likely to have shallower footings. Am I comparing my proposal to his deeper footings or the shallower ones? 3. Neither of us know how deep the footings under the original part of his house are. His rear wall abuts the footpath which is unmade, not adopted, has no registered owner, has rights of way on foot over it for both of us, and has a rough concrete surface with foul and surface drains set into it, including at the base of his wall. If I wanted to know how deep his original footings were then I'd have to break up the path and drains to find out. Given neither of us owns the land, I'm hesitant to do this. Is there any provision in the PWA for circumstances where the depth of a neighbours footings are unknown and cannot be ascertained? Thanks!
To be fair its Thames Water head office blaming baby wipes, the actual workmen are perfectly clear that the pipes are all old, broken, have tree roots in them and all sorts, and need replacing, and that the odd wipe is neither here nor there!
A different little bird whispered some similar things in my ear! Problem is that the local network is prone to blockages (baby wipes seem to be the villain of the piece, even though nobody locally has a baby), and Thames Water are forever around here lifting up manholes and poking about. They would spot any phantom connection pretty quickly. My research into rainwater harvesting is returning some interesting early results. I would need a tank that could hold nearly twice as much rainwater as I would ever likely use - a 7500 lt tank to be precise, measuring some 1.4m deep, 3.3m long and 2.3m wide. That needs a big hole dug for it, though not that much bigger than the one I have already dug for my soakaway, which it would replace. The giant tank is needed because it has to sit half empty all the time, to ensure enough extra capacity to accommodate any 1 in 100 year downpours. I would also still need to connect to the main sewer, because the tank would need to pump water away if it got more than half full. My plans for a green roof would have to be abandoned if I got a harvesting system - you can't harvest from a green roof apparently, or from hard surfaces, which means my patio and artificial turf area would need to be drained separately. The cost for the kit seems to vary from about £3100 to £3700 depending on whether it contains a pump. That actually doesn't compare too badly to the costs of buying the large pump my drainage engineer has specified for the current proposed drainage system. All things considered it is certainly worth investigating further.
Thanks all. The planning dept didn't ask about drainage, and the building control dept signed off the use of a soakaway, though I was aware that it might fail given the clay. For that reason I've done the ground lowering and installed the SA now, well ahead of any actual building work for the house, just to test it. The drainage engineer feels confident that by proposing the attenuation tank, pump etc, Thames Water will have to say yes, what with the house already having approval and there being almost no other feasible options. I will find out in a couple of weeks whether he is right. If Thames Water say no (and even if they say yes) I will explore the use of harvesting systems whether as a preferable alternative even if I can connect to the sewer, or as a back up alternative if I can't.
I can see the general issue of course, but there must be some degree of local variation? If my local network is, for instance, under capacity then I wonder if there is merit in me seeking permission for a direct connection? The line I would connect to is a combined sewer, so I'm not sure I would be affecting the mix of product. I might even be helping to flush things through a little!
I don't know for sure, but I can only get a mini-digger on my site and it was pretty close to the limit of how deep it could dig when we put the soakaway in, so going far deeper probably isn't an option. That was my understanding, and I can demonstrate that the first three options aren't feasible. I just wondered why direct connection to the sewer is such a no-no?
I have considered various set ups like that, but they all fail due to the whereabouts and design of my slab, services, a void for heave, and the sewer connection. Thanks @Oxbow16 but my land has never been touched by human hand, and the clay is consistent all around. My original hope was that someone would say that surface water flowing directly into the main network is demonstrably fine, and that they had experienced as much. Doesn't look like anyone has had that experience though! The next best outcome for me was that someone might come up with a new idea, and though I had discounted harvesting at an earlier stage of my build, that was before all this happened so I will certainly revisit it now, if only to compare the cost of it with the attenuation tank and pump arrangement.
Thanks, I'll look into it. If I've got to pay for a pump then I might as well pay for a harvesting kit instead if it does the same thing.
