Tosh
1 Follower
About Tosh
  • Birthday 10/08/1964
Personal Information
  • Location
    Powys
Tosh's Achievements
Regular Member
Regular Member (4/5)
44
  1. you obviously haven't seen how many we have in the welsh hills so I certainly wouldn't be wishing it on anybody. Like many aspects of government the line of corroboration with large companies is suspicious.
  2. that ban was lifted some time ago, in our county Bute energy are currently going through planning for 3 wind farms in mid Powys consisting 65 windmills up to 220m high.
  3. A vote here for a sprayer. I bought one for our place as couldn't get decorators to even look at it let alone quote. Masking isn't much more than with a roller, you can buy rolls of pre taped masking film for doorways/windows. It is vastly more quicker than a roller and I would say a better finish but let that be in the eyes of the beholder. The only downside was cleaning the gun and hose etc between colours as we didn't have running water which meant lots of tubs of water to flush it through which was time consuming. Its a Titan Control max 1900, brill machine but it struggled a bit with thick paint like Tikkurila Optiva 5, someone recommended flow and bond and was a lot better after adding that. But time over would have got a more powerful unit. Definitely would recommend.
  4. I used 16g SS pins through a Hikoki. Initially to pin the cladding as a temp measure before final fixing with visible SS nails. Cladding company spec'd the nails. There's a section of gable that's been left for over 12mths now, waiting for me to get around to it, and the pins are still holding fine. Not sure I'd trust them long term though. Timber can move around a lot.
  5. Have a look at BAL Stopgap fill and prime. Datasheet says you can apply to chipboard. Then top with Stopgap 1200 SLC. Expensive way to deal with 1sqm though. What about just screw n glue some 6mm mdf sanded/feathered out? Underlayment will compensate for minor imperfections but most flooring companies will likely recommended ply over the chipboard before underlayment.
  6. The BAL adhesive mentioned is probably the rubber crumb AF Max. People think its a new concept but it was around many years ago. Your tiler will love you if you go with that as it's a lot lighter to use and handle.
  7. If there are other properties in the vicinity that have been replaced then I'd have a look on the planning portal and see what documents were submitted/approved under those applications. Judging by your discription my inital thoughts are you don't need a planning consultant if there's other properties in the area that have been demolished/replaced. I'd just get the architect to do the planning drawings and submit them. My architect wanted me to employ a civil engineer to plan the route for a 32mm water pipe across our site - at which point we parted company! Planners will tell you if you need anything more. Planning consultants are useful if you think you're going to get into a standoff with the LPA over the principle or design of what you're doing.
  8. https://www.dortechdirect.co.uk/faceshield-uv-membrane-1-5m-x-50m.html?srsltid=AfmBOoqoEF0dakba4-g2N6bQWWJldFY0_x-xl9EHV3bDlDYYmAein1TV We were going to do open screen but decided against it in the end. This stuff any good? 12mths fully uncovered according to the data sheet.
  9. We have a slam shut as well. Was advisd to keep a small keysafe with a spare in an outbuilding 🙂 Interested to see you using Tece cisterns. We've used Tece frameless, really nice product but be aware where you purchase as there are non WRAS approved units out there which can catch out the unwary, I know!
  10. builder should charge you 5% for labour and materials. You claim back the 5% as part of your VAT claim at the end. The builder deals with the 15% via their own VAT input/output calculation. Materials you buy direct are 20%, so claim the full amount back. Some of the accountants for supply/install we've used have asked for the planning permission to confirm 'conversion'.
  11. I have an unopened 20l tub of TT spare, well 2 x actually but will keep 1 x in stock. Damn useful stuff. PM me if you're interested. I created a mortar fillet between the foundation and ICF then coated it with TT, fibre tape on the joints then used a cavity membrane over the top to direct into a french drain.
  12. I was going to mention Party Wall Act but looks like thats already in motion. What about just putting a few heras panels on feet across there? Surely the edge of their wall will be set back from the boundary otherwise they'd have to dig into your property to install the foundations.
  13. Tosh
    Rats!
    I have an old Air Arms TM100, used to be perfect for the job in hand. Unfortunately after a few years in storage (ahemm self build yawn) it won't hold pressure. I couldn't find anywhere to either get spares or repair and was about to throw in the towel but then found a place in stoke by pure chance that said they could repair it with seals made by a local company. Almost willing for them rats to come back!
  14. Our formed cills were all folded but they did have to solder a few joints around our plinth flashing. They just took the coating off back to the steel, to the width of the solder and then painted afterwards with colour match spray.
  15. Tosh
    Rats!
    Our new neighbours decided to put ducks in their garden. Within 3 months here the rats came. Chewed through the timber floors of our sheds and destroyed our belongings. Tried to politely reason with our neighbours and put poison down for 2 years but still they came. They just find different ways to break in. Explained that it was the food that was attracting them. In the end I just lost my patience and had a row with them. Coupled with the rat man telling them the same they eventually removed the ducks and food source. Although the council in our area did'nt offer pest control they did say they would do a visit and talk to the neighbour and ultimately we could file a nuisance complaint though it never came to that in the end. The chicken food IS the reason you have rats. Stop the food and they'll stop using your gaff as a hotel.
