Redbeard
Everything posted by Redbeard
Low Carbon Heating Teachnologies and Social Relations
Redbeard replied to Lewis Hubbard's topic in Other Heating Systems
Thanks @Ferdinand, that makes sense! -
Hi Lewis, It would certainly help me greatly (and probably others too) if you defined the types of social relation(s?) you mean, rather than having to open the file to find out. Is that possible? (By the way, I have just received a request to take part in another survey and I cannot read the pro forma to see if it's for me or not, since I cannot get past each page without filling it in! If yours is like this it may put people off starting. Hopefully it's not!) -
Building a straw bale house on the western side of Islay
Redbeard replied to Selina's topic in New House & Self Build Design
What about pre-fabricated straw panels? "If you’d like to get in touch with Barbara about consultancy, EcoCocon’s prefabricated panels, or anything else, you can email her at barbara@strawbuilding.org.uk or contact her by phone on 07720 716 589." -
What can be used to insulate the overhang of a warm flat roof?
Redbeard replied to plockhart's topic in Flat Roofs
Cork board, perhaps? Or perhaps not is low cost is a criterion. -
I may be wrong but I am sure I have wrung water out of Rockwool like out of a sponge, so I am not sure it is water-resistant. Is it not that the rigid or semi-rigid 'batts' may have a water-repellent coating? -
You don't go on to say that *you* have a party wall agreement for your works. Have you? Whatever the current situation you need PW advice. I don't know how it complicates matters if you have to invoke the PW Act after you have started but for reasons stated by others above you need to, I think.
Light refurb/renovation & building regs
Redbeard replied to Roger440's topic in Building Regulations
OK: 150 PIR on the sloping ceilings would meet the Regs. 60 WF on the walls wouldn't, but you can put a cogent argument that you are reducing interstitial condensation risks and thus potentially extending the life of the building at a slight 'energy cost'. If I understand you correctly I think you are saying that if you cannot comply to the letter you may be better saving the BC costs and doing the best you can. I think the issue may arise when you come to sell, when the buyer's solicitor asks re works and re BC approval. If there is none they throw up their hands in horror but ultimately agree to be a lot less horrified if you drop the price, probably by an amount far in excess of the BC fee. Yes I know about indemnity policies and so on, but (a) that they cost and (b) that you cannot apparently get one if BC are already aware of the breach, which they may be via the potential purchaser's enquiries. I hope this helps. I don't expect everyone to agree with me but, in old examiner-speak it at least 'shows my workings'. -
Internal insulation (IWI) carries the biggest risk of interstitial condensation - vapour condensing on the masonry surface of the wall behind the insulation, since the insulation make the wall cold by isolating it from the heat source. It may be a good compromise solution for existing buildings but not new-build, in my view. How about building solid block with EWI (thickness depending on material)? Why are you thinking of a cavity. What is it doing, in your view?
Tell us more about that. Where is it on the pics from outside? In general the tiles don't look too bad, although the bottom row LHS looks a little 'unhappy'.
Welcome! Frankly I'd have done nothing. 'Underfelt' (or, now, 'breather membrane') is a nice-to-have belt-and-braces luxury. My 130-year-old roof has no membrane. As long as the slates or tiles are in good order I would argue that you need do nothing. The membrane is there to catch the water if the tiles or slates fall off. Arguably, no slates falling off, less need for membrane. If the felt is crumbly it would, I suspect, be worth getting an asbestos test done since, if I remember correctly, some felts at some time were reinforced with asbestos fibres (hse.gov.uk's asbestos essentials section will tell if my memory is wrong). A bit more detail will allow us to give a more informed opinion. With the exception of the asbestos issue referred to above, no need to worry much (if at all) unless the external pics you haven't shown us yet show areas of slipped or damaged slates/tiles.
Good! Use the CAT scanner... That may sound cynical but will the person pulled off another 'more important' job have the CAT scanner/ lack of rush which allows for finding cables in a fortunate rather than unfortunate way. Could you re-ask the Q in a way which invites a Yes or no answer? Will you be using a CAT scanner and/or other methods to ensure there'll be no damage to my cable/pipe runs? "Yes". Good! It makes the position clear should damage occur.
Read PD extension - measuring 'height'
Redbeard replied to Alan Ambrose's topic in Planning Permission
Is your garden room masonry, and does the room wall itself form the retaining wall? If not, and you have effectively retained 'the end of a swimming pool' inside which you have built the garden room then, according to my LA, the measurement is from the flat bottom of that 'swimming pool'. If you have properly built in to the ground, and the ground abuts the building then IMO the height is measured from that 'highest' level. In my case I retained a bank, and built a TF shed from the bottom of the retaining wall. Appr 1.2m was retained, so 1.8m to eaves height, therefore PD with ridge ht of 4m. "No", said the LA! "It's more than 2.5m above GL at the eaves, so it's not PD". So it has Planning Permission. -
Solid wall Internal Wall Insulation (Warm Batten) design
Redbeard replied to Annker's topic in Heat Insulation
I think there is. I had always believed so and a quick search suggests that my mind is not addled in that view! Ye-e-e-e-s. My preference for retrofit is to choose methods which do not rely on a VCL (which in the methods I use limits how low you can get the U value). Theoretically if you use moisture-buffering materials and have a guaranteed excellent air-flow then you can go for lower U values and deficiencies in the VCL are less of an issue (though you still want an air barrier). -
Free-standing stud wall with insulation and adequate x-vent behind is great, and ventilation may be adequate for a whole elevation with say 4 air-bricks per storey. If you have studs against the wall then you need an 'in' and an 'out' (say 225 x 150 each) between *each pair of studs'. That's a hell of a lot of air-bricks, ranging from 'not aesthetically pleasing' on, say, brick walls to virtually impossible of rubble-filled stone with a loose core. https://assets.publishing.service.gov.uk/media/614b30aad3bf7f718a54c0be/iwi-guidance.pdf -
Fine tuning my IWI Solid wall (Warm Batten) design
How about the above but with added 25 x 38 (?) counter-battens over the Intello, forming a service void so that the elecs are inside the air-tightness/VC layer? -
Hello! Not with mineral wool, I am afraid. I have not used mineral wool as an internal insulant. I think I would be a little uncomfortable using it without a VCL, as even the 'rigid' grade of rockwool used for EWI is not as dense as 'basic' (140kg/m3 - 180kg/m3) rigid WF in terms of moisture-buffering ability, although at apparently 110kg/m3 it's not so far away). If you are finishing with plasterboard you could (at a cost) use an intelligent membrane such as Pro Clima's 'Intello'. Yes, for reveals use as much insulation as you can get in without 'losing' the window or door frame. If you were taking the risk of no VCL then you could buy the EWI grade of rockwool and plaster directly to it, with the necessary mesh reinforcement, effectively as per thin-coat EWI. -
Although achieving the target U values makes it easy to comply you can 'comply' without meeting those targets, and it sounds like your house is a good case (old, stone, etc.) for invoking those 'get-out clauses'. Yes, it requires discussion with BCO, and that's not always so easy, but it can be done. I will be doing that next year. -
I am not fully au fait with the Building Safety Act but I am not sure why you would not be able to fit windows yourself. I did 2 years ago (admittedly before BSA). As I read a brief guide to BSA it talks about the positions of responsibility and of liability, but as I (very briefly and incompletely) read it, if you as householder take on the responsibilities and liabilities you can do it. I may well have missed something. -
Extremely Distorted / Warped Double Glazing
Redbeard replied to CGoodge's topic in Windows & Glazing
Arggggghhhhhhhh! Oww! I thought it might be just the window pictured. Like you I cannot see the manuf'r/installer taking that in their stride. I wonder if you can get an 'expert witness' who will not appear biased in the installer's eyes.- 16 replies
- glazing
- double glazing
- (and 6 more)
Do I Need Even more Insulation? Decision needed within next 24hrs
Redbeard replied to peekay's topic in Heat Insulation
Who did your insulation and air-tightness strategy? Do you know for certain that there is no chance of air movement in the 'sandwich'? If the air-tightness within the depth of the upper wall is not really good then the EPS could be just a fat expensive render board, potentially doing nothing to the sum total of insulation. How deep is the cavity in the gr floor walls? Then we can maybe roughly work out relative GF and FF insulation values. Without more info I think it's too early to make any call on additional insulation, or not. -
How wide is that cavity? -
I think the bonded bead boat has sailed, as the OP intends (or not) to install mineral wool this weekend. It will be better than a poke in the eye with a sharp stick, but check for and block any air-leakage and sort it as you go along. I see no reference to vapour control layer (VCL), except that the insulated plasterboard may have one, but only where the joints aren't. Worth doing that condensation risk assessment. 'Feels' like it may be OK (except that air leakage within the 'sandwich' isn't) but I am not CRA software.
