bmj1
Everything posted by bmj1
Hi all - just taken on a new project - and I figured this time I'd buy myself a 'temporary toilet' Photos attached of the toilet in question. It has an outlet for 110 soil pipe out the back - and I had figured I would just connect it directly 'to the main manhole'... ... but now it's arrived, I'm scratching my head trying to figure out what's the best way to actually do this - i.e. leaving the cover open and plopping a soil pipe straight through the top - is that the play ? I don't really want to go too far away from the 'main manhole' - because the groundworkers are going to rip up and re-lay all the soil pipes... ... any practical suggestions ?
Any ideas how I can remove marks like this from tarmac? Not sure what it was done with but looks to me like it was spray painted on..
With the benefit of experience, I can tell you that the "right" way to do this is to specify up front as part of the tender (i.e. quote process) for the doors that you want to review the detail for the load bearing to mitigate cold bridging (and that this is of importance and so should be allowed for), and that a technical drawing must be prepared by the door company for review and client sign off prior to commencing production. After the fact, they have potentially done exactly as they were asked in this case.
Thanks guys. I'm going to press the MEP designer further on these points to list out exactly what functionalities we require from the BMS - to understand if this is the correct approach.
This was just an example of a previous job the MEP designer shared. He was saying there needs to be a control system for the ventilation, AC, Heating, openable windows, etc, e.g: - Interlock to prevent AC and heating operating at same time - Interlock to disable AC and ventilation when windows are open - Possibly some automatic opening of windows when Fire Alarm triggers etc Does that make sense ?
That makes sense. Any recommendations of how we can minimise Total Cost of Ownership? I'm worried about capex, as well as license fees and maintenance fees. Also, any recommendations systems ? Thank you in advance.
Hi all, Having done my own (smart) home, I typically made use of self contained systems, i.e: Lutron Ra2 Select Shelly Velux Coolmaster Heatmiser Unifi Access Wiim Rainbird When it came to automations - I ensured everything could connect to Home Assistant and built my automations that way. I'm now working on a community project - ~900m2 over 2.5 floors of shared communal space. The MEP guys are advising we need a BMS panel. I don't get it. He shared me the below as an example of the kind of thing we're talking about. Is he right ? Is this the modern way to approach things ? Please guide me ! Thank you in advance !
Ugh, I've seen this before, disgusting practice. I can recommend you someone who specialises in construction dispute resolution, he's very good (used him myself and had a final settlement with the builder signed inside 2 weeks). Drop me a PM if interested.
Do you have any retention still held back ? Whereabouts in the country are you based ?
Of the three: Pebble grey. P.s. nice bricks
We used Philips master value throughout. Warm white.
Huge difference between set and actual room temperature
bmj1 replied to iMCaan's topic in Underfloor Heating
Been there - had a plumber cut off all the wiring labels and run almost every zone wrong... It's all fixable, fortunately.. just time consuming -
We found massive variation in price when ordering our flat roof velux roof lights a few years ago. Best prices came from online suppliers. You need to call to get a quote when making a bulk order.
Sorry - I'm not intending to trickle feed - I think I've just posted a bit early in the process. The building itself is roughly 900m2 over 2.5 floors, it's shaped broadly in a cube. Agree that fabric needs to be spot on. The only draft detail I have right now is 250mm PIR in the roof. The rest will get fleshed out over the coming weeks. Mechanical ventilation is planned: a big unit from Systemair. I haven't yet seen details on how air tightness will be achieved, but I have discussed with the team making use of Aeroseal. I think it probably makes sense to post back in a few weeks with a bit more info and some drawings.
It's a steel deck with concrete poured in - I think ! "A steel deck with a poured concrete floor, known as a composite floor system, uses corrugated steel sheets as permanent formwork and reinforcement, creating a strong, cost-effective, and fast-to-install structural slab by combining the concrete's compressive strength with the steel's tensile strength. The deck acts as a working platform and holds wet concrete, while shear connectors (like headed studs) bond it to the steel frame, forming a single, load-bearing unit after curing, common in commercial and multi-story buildings."
So the knotty areas so far have been: a) Ventilation requirements: some serious kit and duct sizes involved b) Fire Strategy: means of escape/staircases c) Structural design: achieving a very large column-free main prayer space, without a crazy steel bill I was referring to the professional team (architect, SE, MEP, PM, Interior Designer). Despite having a full professional team engaged, I certainly plan to keep asking questions here, and keep sharing any findings.
Interesting... so if using electricity - then might as well go for electric UFH - interesting and will put it to the team
I'm particularly surprised by your suggestion for "screed electric heater wires" - my understanding was that wet pipes are much more cost effective to run.
Hi Nick, Comments as follows: I expect the space to be used frequently throughout the week, including a daytime nursery on premises So we'll likely want to keep it at temperature from say 6am to 11pm Does this change anything ? We're building it for ourselves, so we do care that it is cost effective to operate (subject to the capital investment required, but essentially we have an owner mindset on this one)
- composite concrete - it's a community building/place or worship - heated by UFH, I imagine using electricity (not gas) - floor covering likely natural stone tiles Any other questions?
I'm working on a community project. Today with the design team we discussed making use of a 150mm composite deck which sits between the steels, and then making use of dry screed (cement) boards on top for ufh pipes to sit in. The reason for suggesting screed board was to minimise build-up. Also important is ensuring no noise transfer between floors (hence 150mm deck). I can't help but think that there must be an approach here where the composite deck could be used as the screed ? Or alternatively we do a 100mm composite deck with 50mm cemfloor/liquid screed on top... Any thoughts on this ? I figure there must be some buildhub wisdom on this...
