Garald
Everything posted by Garald
Correct. That would be about 1.5kW in my case, but the improvement would obviously not be that, but a certain percentage of that, representing the efficiency gain (how much, I do not know; what would be a sensible rough guess?). Would it be higher at a higher ACH? I did the heat-loss calculation with ACH=0.6, if I remember correctly.
[one more chapter in the heat-renovation saga...] I'm doing heat-loss calculations now to determine what heat-pump to get. The spreadsheet I am using asks me, naturally, whether I have MVHR or a ventilation system without MVHR. The answer is really neither, since I am getting a positive-input ventilation system, hooked up to the heat-pump: https://www.ventilairsec.co.uk/products/hydro-r/ vmi-technologies.com/wp-content/uploads/2020/09/aquarea-purevent-visionR.pdf (sorry, in French) But what should I enter in the spreadsheet then? Or should the rule of thumb be that I'll obtain a heat loss somewhere between MVHR and no MVHR? Where in between, more or less? (The spreadsheet is giving me a total heat loss of 5.2kWh with MVHR and 6.2kWh without MVHR.)
All right - I am no longer considering UFH.
Another thing I don't know how to take into account is that a 11kW Yutaki is in principle more efficient and a little quieter than a 8kW one, apparently. Or is it the case that a 11kW Yutaki would nevertheless be less efficient in practice *at the task of heating a place that requires only 8kW*? https://www.hitachiclimat.fr/documentations/telecharger/brochure-yutaki-2-0
A "buffer" in this case would be...? The difference between maximal capacity (11kW for the 8kW Yutaki) and nominal capacity (that would be, well 8kW for the 8kW Yutaki model, obviously)? Would that be enough for the scenario of two people showering and another taking a nice hot bath, when it's cold outside? Also, what about cooling? I don't imagine the VMI can really be short of cool water, but, if I ever put two fan coil units total, will I regret getting only 8kW during the summer?
The kitchen will be used just for cooking (largely by me) and for having breakfast and/or small meals at the breakfast bar.
I also think the idea that tiles hurt your feed is daft. My family (all branches) went from dirt floors to tile floors in the kitchen about 100 years ago and has never looked back. However, my girlfriend descends from a long line of opinionated doctors, and it has been Carthago delenda est for weeks now. Her brother is actually into feet (as in, he operates on them) and answered, in brief: "I have tile floors, they are the worst, but it's not as if they were going to cause crippling arthritis or any such thing". So probably there is no actual reason. But I'll get a bamboo floor for the kitchen just to get this issue over and done with. That is easy to clean, no? (I'm also getting it for the landing of the little attic staircase, including the cat toilet under it.)
Well, 5.2kW if it had heat recovery, 6.2kW without. What I will have is a VMI-Hydro'R system (https://www.ventilairsec.co.uk/products/hydro-r/). It is a positive-input system that does not have heat recover as such, but, rather, that water produced by the heat-pump preheats the air being distributed throughout. The manufacturer website claims that this is done "without extra energy", but that's of course physically impossible; still, we can presume the process is somewhat more efficient than radiators, since otherwise there would be no point to its existence. Let us say, very conservatively, that my needs are really 6.2kW, in that this system helps a little bit. (Do you think it helps more than that?) At any rate, what does this mean in practice? Is a 8kW pump fine or too little? As I said, I'll be living alone at least half the time in the near future, but a scenario in which two people take showers on different floors at the same time is more than possible (in fact it could in principle happen that two people take showers while one takes a bath, though we aren't sirens or anything). Is a 11kW pump too much? I've read a 8kW pump can be a bit tight for *cooling* in a place this size, but I suppose that's the case if one has lots of fan coil units. I'm not sure I'll have any - the basic plan is to get cooling *only* from the VMI-Hydro'R system (though we could follow the advice here and install, at the very least, the ducts needed to install a fan-coil unit in the attic and another in the main south-facing room (the long library, which is the central part of the apartment)).
Here is the corrected worksheet. I've left heat recovery efficiency at the default value of 66%. I will have a positive-input single-flux (VMI Purevent) that I *think* does something that amounts to heat recovery, in some sense? I don't really know what value I should input. What would be a reasonable guess? At any rate, with 66% (which may be optimistic), I get 5,2 kWh. With 0%, I get 6,2 kWh. The bizarre thing is that the system still tells me: "your heat pump is expected to provide 69% of your hot water". (For the record - at least half of the time in the immediately foreseeable future, I'll be leaving alone; at other times, girlfriend and/or my parents will be visiting for more or less extended periods. None of us are amphibians.) 629771879_Haraldsheatlosscalculation-corrected.xlsx
You are of course right - these were the default settings on the spreadsheet - I see in the actual settings of the MVHR we will install that there are three levels (0.35, 0.5 and 0.6). Let me choose 0.6 to be on the safe side. (There's also a turbo setting of 0.75 or so for a short while - is it when the friend you invited over turns out to have had an active case of COVID? And you burnt the food?) I'll have VMI, which does have heat recovery, but I have no clue as to its sufficiency. I've left it at the 66% setting. How do I find out the right value? It's not obvious from a quick search (perhaps because I don't know what I am looking for). The result is now: Heat loss calculator figure kW 5,2 1344846824_Haraldsheatlosscalculation-corrected.xlsx
I just did the heating calculations (hopefully without making any major mistakes). I seem to be getting that I need at least 8.5kWh. The eyeballing estimate turned out to be in the right ballpark. (The fact that there are two spots we have not been able to insulate (attic sidewalls and the small corner staircase to the attic) is what brings me over 8kWh.) Does that mean: - 8kW would not be enough - 9kW would be enough - 11kW would be... an acceptable overcalculation? Notice that the Yutaki comes only as a 8kW unit (maximum performance: 11kW) or as a 11kW unit (maximum performance: 15.2 kW) ? 1623540008_Myheatinglossworksheet.xlsx
All right, here is my sheet. Tell me if I have done something wrong. I am getting: [Heat loss if known kW 6,6 - no idea where this came from; what is this?] Heat loss calculator figure kW 8,5kWh Heating flow temperature C 45 I seem to be getting that I need at least 8.5kWh. The eyeballing estimate turned out to be in the right ballpark. (The fact that there are two spots we have not been able to insulate (attic sidewalls and the small corner staircase to the attic) is what brings me over 8kWh.) Does that mean: - 8kW would not be enough - 9kW would be enough - 11kW would be... an acceptable overcalculation? Notice that the Yutaki comes only as a 8kW unit (maximum performance: 11kW) or as a 11kW unit (maximum performance: 15.2 kW) Then I get: "your heat pump is expected to provide 69% of your hot water. You will need additional heating to provide 31% of your hot water." Should I take this seriously? I thought Hitachi Yutakis and Panasonic Compact Aquareas had big, nice water tanks. What is the limitation here? (Also, what about cooling? Yutaki, Panasonic, etc. are reversible.) 309760954_Myheatinglossworksheet.xlsx
I'm having a bit of trouble getting the Heatpunk app to understand that I don't own all of the ground-floor, and so some of my walls are not in fact external walls. How do I do that? ... and I am having trouble to get the FreedomHeatPump spreadsheet to understand that there are cities no in the UK. Shall I just pretend that Paris is London? It's hotter during the summer, but the two have similar winters.
I think I'll do my own homework. (Really doubt she did any calculations, in this case.) Her suggested framework will not work, and a hack as in https://www.atlantic.fr/Chauffer-le-logement/Pompe-a-chaleur/Aerothermie/Aerothermie-Air-Eau/Wall-In (in the general direction of what IanR was suggesting) in such a constrained space is tempting fate (though, if people show me how, I could do the airflow calculations for fun). She reacted quite badly to the suggestion of putting the external unit on the roof, at this late stage in planning (work on the house started weeks ago). Of course permits from town hall would be needed. The one plausible alternative seems to put the external unit in the courtyard (as was our plan B, before the architect was lured into this practically literal trap). I am actually meeting with the only other person in the coop who comes to meetings tomorrow (we have >60% of the votes together), and can try to get his preliminary agreement (he was not against it when we mentioned this plan B to him some time ago). Should I do any flow calculations here? It's not as if the courtyard were toilet-sized - you can see its dimensions in the other thread. (Perhaps the unit should be a bit further away from the wall, or in front of my staircase rather than in front of my bathroom window?) We already checked back in June that the external unit of a Panasonic (with sound protection around it) satisfies sound-pollution regulations, being below ambient noise - and a Yutaki would be a bit quieter than a Panasonic (the specifications claim 54dB at 1m for the 8kW model and 49dB at 1m for the 11kW, *without sound protection*, which lops off more than 10dB).
Thank you very much! If I want to explain to the architect (who said "but I installed plenty of ACs in that configuration") what would go wrong (I've already relayed all the arguments above), should I say the following: An AC, by design, recycles air, and thus, if plenty of the air that it has just cooled gets cooled again further, that's not fatal or even necessarily undesirable; in contrast, in a heat-pump, we are *extracting* heat from outside air; once we have extracted some heat from that air, we want to say good-bye to that air as fast as possible, since it is harder and more expensive (and in fact quickly becomes impossible, given the design of the machine) to extract further heat from already cooled air. (Not to mention that a 11kW heat-pump pumps almost an order of magnitude more air per minute than a medium-sized AC, no? But that's a different matter.) This is apparently an object lesson of how "a heat pump is inverted AC" is a bad metaphor, or at least one that can be very misleading when pushed.
Hi, I think by now everybody knows about my recently narrowly averted heat-pump catastrophe. Suffice it to say that I'll be doing my own library research from now on, and will try to find a specialist (hopefully a third party, rather than an installer eager to sell a product and his services, even in ways that make no sense) to check on what I have in mind. I am looking at two heat pumps from companies that my architect and I have looked at in the past - Panasonic Aquarea (High Performance All in One Compact J Generation 1 Phase · R32; 9kW) and Yutaki S Combi (8kW and 11kW). (This seems to be the right range; the installer who shall not be named convinced my architect that my newly well-insulated triplex apartment (ca. 120m² on which one can stand, plus inhabitable attic space and a big stairwell) that 11kW were needed - I still have to do the heating calculations myself, but common opinion here seems to be that less than 11kW would be fine.) They seem to be both high-quality products. Both of them are apparently compatible with the Aquarea PIV system we are installing (which will provide cooling in summer and supplementary heating in winter). Their inside units are of about the same size (the one by Yutaki is a bit taller, and as a result stores 220L rather than 185L of water), their SCOPs are roughly in the same range (those of Panasonic tend to be slightly better)... The main difference I can see is that the external unit of the Yutaki is quieter by about 5dB. If there are massive differences, I am not noticing them. (Is there anything I'm missing?) One thing that mystifies me is why the Yutaki S 8kW seems to perform worse than the Yutaki S 11kW: it has perceptibly worse COPs and SCOPs, its EER is also a bit lower - and, for some reason, while the sound power of its outside unit is the same (64dB), the sound pressure at 1m is greater for 8kW vs 11kW (54dB vs 49dB). What is the reason? And, should the calculations show that 8kW are enough - will this be a reason to consider getting the 11kW model after all? (The external unit of the 11kW Yutaki model is much taller than that of the 8kW model (or the 9kW Aquarea), since it has two fans instead of one.)
Now I am in "getting my architect to accept reality" mode. She is telling me that "there is theory and there is practice" - right, but that goes in the other direction! Something may work in theory and fail in practice, but if something fails utterly in theory, then it will certainly fail in practice! (I didn't tell her that yet.) She says (I translate): "I understand the arguments [...] but I advise you to listen the arguments of Mr. I., who didn't doubt it would work [NB: he has arguments?], as well as several technicians with whom I talked at Interclima [a trade show at the beginning of October]. (Please note that for the moment he is the only competent installer who is available, and I've been looking for one since July.) I have no experience with heat pumps, but I have already installed many external AC units in this kind of configuration and they have worked perfectly for a long time." How do I explain the difference - is the main part that the amount of air being pumped through a heat pump is much greater than that pumped through by an AC unit? The idea that a heat-pump is mainly an AC running in reverse may have played her a dirty trick. "If, contrary to the professionals [who precisely - Mr. I, the technician who agreed to install a heat-pump fan in this bizarre configuration?] you think that 8kW is enough, Atlantic has a kit for interior installation: https://www.atlantic.fr/Chauffer-le-logement/Pompe-a-chaleur/Aerothermie/Aerothermie-Air-Eau/Wall-In " Questions: (a) how do I do the heat calculation for the whole triplex apartment? (I have only seen the spreadsheet for a single room, which presumably could be used for one level of the house.) (b) What do you think of this kit? It looks like something roughly in the direction of what IanR was saying. (Then she asks whether I want a supplementary study and what would be the deadlines and the price. Quite aside from the fact that I don't know how I feel about paying someone for correcting his or her own mistakes, after having paid him or her for making them, I really feel I should be asking someone else about this matter, and let her take care of ventilation (which is what she does best) and everything else. Does anybody know a heat-pump installation specialist in the Paris area?)
