ragg987
    1
ragg987 last won the day on June 7 2017
ragg987 had the most liked content!
Personal Information
  • About Me
    Detached 330m2 house on 3 levels with separate garage, MBC timberframe, Integraspec ICF + Kryton waterproof concrete basement, Norrsken 3G glazing. Clay tiles and zinc roofing, STO render on carriers plus some timber cladding.
    Designed to Passiv standards and tested to 0.57 ACH @ 50Pa. Heating and DHW using 7kW ASHP. UFH to ground and basement only. Airflow MVHR with in-line electrical heater to first floor. PV 4kWp
  • Location
    Aylesbury
4904 profile views
ragg987's Achievements
Regular Member
Regular Member (4/5)
228
  1. I fitted a Texecom Elite system in our self build into house, annexe and garage. House and annexe are treated as independent areas, each with is own keypad with a RFID sensor. Steep learning curve to program it using their PC application, but doable. It monitors via PIRs, plus smoke and fire detectors. Also drives my door-bell. I agree that this is old fashioned tech, but it's now in year 10 and I've only had to change one backup battery in that time - the panel alerted me to the pending failure of the old battery. I abandoned their android app a long time ago, but I believe they have upgraded that tech a bit. I use home assistant integration for remote monitoring and management. I wanted to avoid reliance on wireless and battery powered devices, so everything is wired to the central unit. All devices, internal and external sounders etc take power from this centre which has is own fused spur. Solid steel cabinet and well built. Their corner PIR sensors are pet friendly, however I have one 360 sensor that is not. I'd use then again based on this experience, though I'd probably see what other companies are doing and what progress the tech has made first.
  2. I've used mine in cooling mode for the 7 summers that we've been here. Works well for us, I added solar shading to the large south and east facing windows and this helps a lot. As above we have flow set around 12C and run it for a few hours consuming excess solar power. It makes a big difference, though not the same as Aircon. Our MVHR will switch to heat exchange mode when it is too warm outside, that helps. And on a cool night we open windows to help. I added an Aircon kit, essentially some insulation and a drip tray. There is usually condensation in this area, and downtimes also on the copper pipes leading to the UFH manifold. Nothing excessive and seen no issues so far.
  3. We did not recess curtain tracks, my example was for track lighting. I recall that there is a recessed curtain track option, I did not explore so cannot help on that front, sorry.
  4. I am happy with a couple of provisos, some I mentioned above. To summarize: I would put a sound muffler in the MVHR flow pipe, or some other strategy to reduce impact of fan noise in bedrooms. Increase the rigidity of the first floor pozi joists. I get quite a bit of floor bounce. Maybe even a concrete floor as used in some countries? Do something to reduce the floorboards 'squeaking' when walked on. Perhaps related to above. By sealed air gaps I mean caulk above at floor and ceiling level. This leaves air gaps under forests for MVHR.
  5. Example CoP results here https://www.researchgate.net/figure/COP-of-the-air-to-water-heat-pump-with-different-load-side-inlet-temperatures-Based-on_fig1_326114264
  6. The heat pump will be least efficient at higher water temperatures, so if you are constantly topping it up AND aiming for a high 55C that seems to be the worst case. I use a timer to heat our 300l tank to 42C then we consume it all day and to up the following night. This is because I am on 7.5p night rate. Prior to the dual rate I heated at the warmest time of the day to improve HP efficiency, as per @PhilT above. And to take advantage of solar power during the day. In the current sunny weather excess solar diverter heats the water and I don't need to run the HP. I suspect you were advised to keep it off timer as a HP takes longer than a gas boiler to heat the water. So less risk of running out.
  7. Aha - that is really useful thanks - I had not considered the over-voltage in the garage. Grid voltage in our area tends to be steady at about 242v, so well within the 230 -6 +10. But of course no guarantee it will remain there.
  8. A 6mm cable shows a 1.5% drop at 5kW. I guess my question is what mandates the 1% voltage drop limit? Is there a standard someplace for PV inverters, or is this a overheating risk?
  9. I want to fit some solar panels on my garage roof - approx 2.5kWp to supplement the 4kWp I already have on my main house roof. This is facing due south on a 40deg pitch roof. I would also fit a myEnergi Libbi battery and inverter in this space, plus a myEnergi Zappi car-charger. The garage has a small DB with a 32A (6mm) armoured cable in a duct to the CU in the main house, approx 25-30m long. I was thinking of a 5kW inverter to allow more headroom in the peak power input or output to the battery. One of the companies quoting tell me the 32A cable is not suitable as the power drop at 5kW would exceed 1%. I cannot understand why a cable rated for 32A would become a problem - can anyone explain this or am I being given some B*s*?
  10. I can do this with the standard Hitachi ASHP controller, provided the times for price boundaries are known. I use the flow temp compensation and variable circulator speed options. Set timer to raise room temp by e.g. 2 degrees and flow temp will boost, so will flow rate. Set timer to reduced room temp and either the system powers off or reduced flow temp and rate. Depends on the delta temperature. I use this scheme when the external temperature is above freezing. When colder my system efficiency drops quickly so I leave the room set to a constant temperature, however the compensation control will still adjust flow to optimise for the load. I am about to get a smart meter fitted and will switch to octopus intelligent soon after. My simulation suggest I will save about 25% on the bill with a few timer and behaviour changes, even allowing for a 10% increase in electrical consumption due to running less efficiently overall.
  11. Fitted inside the window? I understood placed inside it was more a case of heat diffusion rather than keeping it out? I.e. avoid the direct sunlight on your furniture.
  12. The website shows they have a removable option. You may be right about vulnerability, I intend calling them next week to discuss. I wonder if they have a roll up option rather than rigid frame? That way I can store them in a box, assuming I don't damage then whilst handling! I've looked at some solar calculators, and the sun is below 40 degrees most of the winter and into the shoulder months. An option might be just to leave them on and settle for the reduction in solar gain. Don't know.
  13. Luckily that view is blocked by trees and other houses. But our internet dish points to the top of it so we have line of sight from our roof.
  14. Comparing Microlouvre to Mermet Satine 5501 to Mermet Ultravision. Images at 0, 20, 40 degrees inclination.
  15. Living in our build for over 5 years now (is that still a new build?) and turning to first cycle of maintenance. Internal painting, quotes on way. Check. Cleaning drains / gutters. Check We have approx 20m2 of South and West facing glazing. Great in the winter as the light and solar gain is very welcome. But last summer we got too hot indoors, despite running the ASHP to cool. A large patio umbrella has helped, it partially shades 2 of the glazed areas. But... Googling I came across this product, Microlouvre. https://www.smartlouvre.com/ It looks great, I could clip it on to the windows, externally, around April or may and remove it in aug or sept and store in the garage. A sample arrived and it looks good, permitting a view out while completely blocking sun from about 40 degrees up. Anyone got any experience? Not priced it yet... Alternatives I looked at: External solar film. Not removable and reduces light and solar gain in winter. External roller blinds. To be effective for solar shade they pretty much block the views and light. V expensive for electrical control. Light sails, awnings, brise soleil. Don't like the big overhang, not practical in our build. V expensive for electrical control. Fixed slats. Already have this on one window, works well. Other half not keen. Plus impractical for glazed doors.
