Everything posted by newhome
14 I think, and 1 more that needs connecting .......
When you say zones. Do you mean UFH loops? Or the number of room thermostats?
Don't think so. Will see if I have the manual somewhere.
Yeah, I just turn the white dials up to 70 (but they do feck all anyway), put the cock clock and cock pump clock back on the timer, and set the room thermostat(s) back on I guess. Thanks so much for all your help, and others who contributed. Collective genius in action. I am in awe
At least the name of the topic is accurate
Nope, way older than all the super dooper stuff.
TS is downstairs off the utility room. 2 set of manifolds upstairs (I don't think they even work anymore), and 2 sets of manifolds downstairs that work after a fashion but given how quickly the boiler heats up and how slowly the UFH heats the room up I don't think it's working very efficiently.
So in summary I guess it's all super fecked?!
Well assuming they weren't still at 30 from when they were on first thing this am? Dunno There is an immersion heater switch in the boiler room that I only turned on if I needed to use it. He has wired a switch from that to the other side of the wall so the switch in the boiler room is now on all the time just so that I can use the one the other side of the wall when needed, that I didn't need as I already had a working one. Even I know the theory behind that is super flawed!
Yep they are all fully open / max. They were before, I didn''t alter anything, although there have been a number of people here looking at this so who knows if they've been altered.
So the temp dial on the manifolds is: 30 degrees on both downstairs (15 on the cold one) and 10 degrees upstairs on both hot and cold, ie both pipes are cold whereas downstairs the hot one is mildly warm,. All room stats are set to frost still.
Max = fully open yes?
Don''t think so sorry. I think I burnt my hand on the small round thing in the middle. It's not 100 degrees hot.
Pics below. The room isn’t that big so not that easy to get zoomed out pics. Well not on iPhone anyway. Dog photobombed photo 4 Temp gauges still at 45 and 50 respectively. 2 sets of manifolds are 670mm to the higher of the 2 horizontal pipes (hot?) downstairs. There are 2 sets upstairs which are physically higher of course.
Yep, all at 65.
Maybe I is a wimp?
There are 4 of the red things. Yes 4 full manifolds. Sorry not understanding what you mean by low. Low temperature? How do I know?
The UP green pump is hotter. Actually have just burnt my bloody hand on that!
What should I have done with the red things? They are all open max just now which is what they were to start with.
Is like trying to keep your hand on the hottest radiator. Touch it and remove hand! Couldn't keep my hand on it.
20 mins ago I reckon. Hasn't got any hotter since then. Boiler power is down to 6kw now so just ticking over.
We're down to 12kw now so on a go slow so I think the boiler's having a cuppa. The dial next to the PHE reads 50 and the other one reads 45. It's been like that for a fair bit so I don't think the TS is going to get any hotter with the boiler set to 65. Might be wrong but just a feeling ......
The cock's indispensable or the stat?
