Dillsue
Everything posted by Dillsue
Probably best to ask an MCS installer if theyll sign off work youve done and kit that you may have supplied. 400watt panels are likely 1100mm+ wide versus under a metre for the 190s so assuming a 2x7 array youve got at least 700mm of extra rail width. The panel height will likely be 100mm different so you may need to move the top and bottom rails if youre unlucky. Maybe worth checking the panel mounting so your clear whats needed?? MCS guys are not known for lashing things up so you want to be clear that you can extend/relocate mounts
If youve already got G99 approval then that export capacity is in the bag for life, so no worries on the DNO front. MCS is a bit trickier. Someone posted recently that MCS arent the only accreditation scheme that qualify you for export payments?? I think that over time with a drive for greener generation you may find companies will be less picky as to which micro generators they buy from and it maybe that you pay a small inspection fee to check youve actually got PV/wind/water turbine and theyll buy your export?? Theres also at least one company advertising PV kits for self install that will do MCS commission and certification if you buy and install their kit. Way cheaper way of getting MCS accreditation.
TIC is total installed capacity, so that statement says that if you increase TIC you wont get paid for it. Lets say you doubled your capacity then youll only get paid for half what you subsequently generate, so you are still only getting paid for generation off the originally installed and registered TIC. Im fairly sure you need to have the extra capacity installed by an MCS installer so youll pay through the nose for the extension, yet get no premium return by way of extra FITs. Maybe Im reading what you are saying wrongly, but thats my understanding based on enquiries I made a few years back, post 2016 but before covid.
You need to speak to your FIT payment provider as OFGEM dont get involved with customers. I asked OFGEM a similar question a few years back and thats the response I got back. From what I understand you can only change things on a like for like basis if something has failed. Upgrading the size of the array is unlikely to fall into the definition of like for like. Only exception would be if a 190watt panel failed and a direct replacement wasnt available then I think youd be justified in going to the next larger available size, but thats unlikely to be 400 watt and it wouldnt be all the panels either. If you ask and get approval definitely post back as theres likely 1000's of peeps that would love to up their FIT payments, me included. Even if you could fo this swap one of the savings you mentioned was no change to the mounts but I think youll find 400 watt panels are considerably larger than your 190s
No!!! He fills in either a G98 OR G99, not both. If he keeps his export below 16amp/3.68kw and uses a G98 certified inverter, then he notifies UKPN that he has solar PV that has 16amp limited export. Its a G98 notification, not an application. The notification goes in after the system is connected to the grid If he wants to export more than 16amps because he has more to export OR he doesnt use a G98 certified inverter, then he has to ask permission via a G99 application. The G99 goes in before the system is connected to the grid and you need approval before you connect to the grid The spark signs off the install/test paperwork in either case. Unless theres extra complexitiy added to limit export via G100 theres not normally a DNO inspection, AFAIK G98 is straight forward and G99 can be if you keep things simple and sensible, in my experience.
If your mate wants to be grid tied then its no problem exporting if he keeps export under 16amp/3.68kw. Any export just goes into the grid for someone else to use. If you want paying for any export you need a professionally installed system almost certainly using new parts and costing ££££££ G98 is a notification not an application form, if your max export is 16amp or less. You notify with a G98 and apply for permission with a G99 application. Work out who your DNO is and Google G98+their name to get the form. A spark can sign off the install
You tell the DNO what you want to export to the grid, and what equipment your going to use to limit the export to what youre applying for, the DNO then says yeah or yeah but upgrades are required. Once youve got approval and done the work send the DNO the completed commissioning form and a simple drawing showing how things are connected. If youre mate keeps export under 16amp then he just notifies the DNO via a G98 notification. Getting paid for export is a differnt set of certification/approvals from getting permission to connect to the grid.
Set app is used with later HD wave inverters which would be an SE5000H. If yours was installed in 2015 it will be the older SE5000. If thats the case the wifi connection is set up from the inverters display and is covered in the manual.
If you can log onto the portal, but theres no updated monitoring data, then check the inverters internet connection. If youve changed router/ISP/wifi password then the inverter cant send monitoring data. If youve had a replacement inverter then the new inverters serial number needs adding to the monitoring portal. If its not the internet connection then probably need to log the fault with SE as they can do remote diagnostics
Advanced PV calculator anyone? Or how to..
Dillsue replied to puntloos's topic in Photovoltaics (PV)
I think the latest Leafs support V2H but I understand its a bit of a niche just now so probably worth doing youre homework as to your V2H options. If youve already got big battery capacity then it changes your options somewhat and 15kwp is unlikely to be "to much" -
Having your panels facing different directions gives a longer spread of generation which could be more useful than a massive peak depending on your motivation for installing PV Whether 15kwp is "too much" depends on your motives and set up. In the summer youll likely have too much for self use but in the winter you could cover much of your usage if you have a battery bank. Batteries come with a big environmental footprint, so a consideration if one of your motives is environmental. A long spread of generation may negate the need for batteries or allow a smaller battery pack. If youre happy for excess to go to the grid, and the grid can handle it, then youll never have too much and a gas power station can throttle back a bit on sunny days. On the flip side, if you want to keep everything yourself youll likely need batteries, PV diverters, an EV etc to grab as much as you can -
For this reason DNOs linesmen might not be too happy with you -
Technically youll likely need an electrical inspection even If off grid- see previous comments. For grid tie theres-No local authority involvement unless you want it. No MCS unless you want it. Unless you want something else the only additional formality for grid tie is G99 at circa £300. Im sure someone posted that their DNO processed a G99 for free??
I know virtually zilch about battery charging systems so Ill take your word for that. Whats the plan for a failed inverter? If your mate is going to keep a grid connection for battery charging and pay the standing charge then why have the system off grid? You might have to pay a G99 fee to do things legit but its a one off payment thats probably quite small in relation to what hes likely to pay for his PV just now.
Not sure where UVCs came into the comments on warranties as the chat was about PV and you were commenting on MCS and SEG.... clearly not UVC related.
At the time you "occasionally" connect to the grid to charge flat batteries/deal with a failed inverter, its a grid connected system so needs G98/G99 compliance. I think the wiring regs apply to surprisingly low voltages which would include your off grid PV output if its series wired. Youve stated theres an occaisional grid connection so any of that wiring falls under the regs TBH its one thing installing stuff for yourself when theres a bit of uncertainty, but doing it for someone else is a different kettle of fish.
Thats not the case for lifetime warranties on Solaredge kit as they need kit installing and maintaining to their instructions. No need for any specific skill set/accreditation other than being able to read and understand technical english, and pay the extended warranty fee. I suspect that other manufacturers are the same??
Hybrid inverter for small in roof 2kw array - help please!
Dillsue replied to Timmyk's topic in Photovoltaics (PV)
Fairly sure all the inverter manuals give recomended sizes, but as Radian says a 16A unit with B curve will likely fit the bill -
Only if dragsterdriver pushed a piece a wire up the inside of both MC4 connectors at the same time and held them. Probably no more lethal than working on the roof?
Solaredge do as standard but I dont think Tigo do. The Solaredge safe 1 volt output can be overriden with a Solaredge tool and then give full output in the same way Tigo units do. Best to check with a meter if you dont know the spec of the optimised system youre working on.
I think the OP sensibly came looking for clarification/advice about something he already seemed clued up on. If he already knew exactly what to do hes not likely to have posted??
Octopus Smart Meter Display suddenly showing export rate
Dillsue replied to NSS's topic in Photovoltaics (PV)
I think that your eleccy supplier can upload unit rates to your display so you can see what your using in £, but if you set the display to show units it will display those -
Normally, on this forum it is!😁 -
Normally?? Without trawling the forum I think its normally 3 or sometimes 2 letters, usually h, k and w with random capitalisation, if any😁 -
Read on a bit and....
