Dillsue
Everything posted by Dillsue
Theres a meter installed between your consumer unit and the house meter thats connected to the inverter. The inverter is configured so that when it sees >5kw being exported it throttles production. The config is password protected if its G100 compliant. Let's you use the full 8kw within the house but not pump it into the grid.
?? Why doesnt that help? You either want to stay within the law or not regardless of what others are doing. ENA database is easy enough to search for compliant kit
You need to look at this in the correct order!! First off, if you want to have the potential to export all you can generate then you need to speak to your DNO and likely put in a G99 application. No point in looking at inverters until you know what capacity is allowable. Secondly, look on the ENA inverter type approved database and make sure anything you shortlist is on the database. If its not then you can't legitimately connect it to the grid. Then start looking at the specifics you want
Take note of the Danger sign on the front of the grey and black isolator hanging loose. If its connected to the panels there could be several hundred volts on the isolator. If your electrician left the isolator like that and doesnt understand solar, then get a new electrician!
You'd have to ask the seller, but they seem at a good price already
There's a seller on ebay got them at £120 with plenty in stock so not a one off deal. I'd imagine trade would be cheaper than that??
370 watt panels can be had for half that price retail and likely less for trade. That's a hell of a markup!
Bah, humbug can I not have integrated p.v.with trocal?
Dillsue replied to CalvinHobbes's topic in Photovoltaics (PV)
Appendix 3 is all you need to read.........before beer! -
https://www.google.com/url?sa=t&source=web&rct=j&url=https://www.ofgem.gov.uk/sites/default/files/2021-12/Feed%20in%20Tariffs_Consultation%20on%20the%20treatment%20of%20replacement%20generating%20equipment_Decision_13122021.pdf&ved=2ahUKEwj9hZf-qp__AhWRoFwKHfltBqQQFnoECAkQAQ&usg=AOvVaw0l46qMEQAdIwmJgw1ZmS1x -
Under the FIT scheme youve always been able to replace components on a like for like basis but OFGEM changed the rules in 2021 so you can change more or less what you want including increasing or decreasing the installed capacity and still retain your FIT payments on the original capacity -
PV on a flat roof, how far from the edge?
Dillsue replied to Smallholder's topic in Photovoltaics (PV)
Margins are likely not just to reduce uplift but to save disturbing the perimeter of the roof. Trying to lift tiles/slates near the ridge and or gable verge is difficult without disturbing things. Even in a sheltered location where could go right to the edge life is easier with a verge around the array. It also gives access up the side of an array to get to the ridge or top of the panels, if youve a head for heights!! -
Building regs specific to batteries, solar PV?
Dillsue replied to Drellingore's topic in Energy Storage
I think Solaredge have ditched the fire extiguisher in their current batteries. Don't know if they've changed the chemistry or just a bit more confident?? -
System sizing based on actual consumption - a better way?
Dillsue replied to JamesPa's topic in Air Source Heat Pumps (ASHP)
Place the mounting slab on casters so its "mobile"therefore temporary and nowt to do with planners -
Other than not retro fitting a smaller system than is alresdy fitted, thats all pretty vague 3 paragraphs! -
I think/hope you already know this but G98 restricts your inverters export capacity, not the size of the array. Within the inverters limits, put a bigger array up and your G98 inverter can sit at 16amp(3.68kw) output for much of the day. Don't switch big loads on at the same time and there's not much in a typical house that will need more than 16amp.
Ours displays RED too on account of the not so small ammount of export. I read somewhere a bit ago that your style of meter(ours to) actually records energy flow in both directions but can only display one figure. I have it in my head that there is a way to display the second figure but can't remember how to change it or where I read it!!
Interesting. Would that be a standard dumb digital meter wired in reverse??
I assume that you meant why cant your INVERTER charge and discharge simultaneously as in charge the battery and feed power to the house/grid/PW, which it can.
You don't need an installer to submit a G99, in its straight forward to do yourself. If you want 7 kw to use in the house then apply for 7kw and see what they come back with. If its a no then you can- Ask then to reinforce the grid so you can export 7kw Implement an export limitation system Use the 3 phase supply youve got
What would you do differently if you could do your PV install fresh?
Dillsue replied to Gill's topic in Photovoltaics (PV)
The inverter does limit all throughput but it matches its throughput to the house load. It monitors the power leaving the house and as soon as it sees export go above the limit it's been set to, it throttles the throughput so that export stays within set limits. Yes you can export 3.68kw on each of the 3 phases without getting permission via G99. With 3 DNO fuses Id guess youve got 3 phase to the house but the house is only using 1 phase. Youd need a new meter and a new consumer unit to hook up the 3 phase. Except for the meter, your spark should be able to sort out the rest. If youre only looking for 7kw export it would likely be easier/cheaper to stick with single phase unless SPEN object -
We've got the same DNO as you, SPEN, but likely a different engineering office as we're in N Wales. We had informal agreement to double our export from 3.68 to 7.4kw within a few days. Formal offer took a month or 2 but nothing like 9 months. Definitely speak to them as theyll likely be able to give you an idea of the export theyll allow over the phone. If you are constrained by what you can currently export, theres 2 things to remember. First you can have a big system with export limitation so you could have an inverter/batteries that will feed 7kw to the house but is limited to 3.68kw to the grid. Second is that the rules on who pays for grid reinforcement have just changed so if theres export limitation because of grid capacity, the DNO pays for upgrades whereas previously the customer often did -
I wasnt suggesting that you get your installer involved with the DNO but just to get a second opinion that what you want to do is ok. Armed with confidence that there's no reason to object then formalise the complaint. It doesn't cost anything to complain to the energy regulator so even if you "lose" youll be exactly where you are now If youre happy to go with an SE battery then discussion over the Powerwall is academic. It's £7k ish for an SE 10kwh battery vs £10k? for a 14kwh? Powerwall. I have an inkling that a Powerwall has to be installed by a Tesla installer so there's mandatory install costs with the PW
If you really want a second Powerwall maybe ask your installer and Tesla if theres a reason they can see for the DNOs objection and if not, make a complaint firstly to the DNO then to OFGEM. DNOs arent always correct in what they say! When we applied to add a second 3.68kw system to the 3.68kw system we already had, the lad that was doing the intial assessment said we would need to have export limitation on the new system. It took a few emails before the penny dropped that the second system was inherently limited to 3.68kw. We got approval despite initial objection/confusion.
My guess would be because 2 powerwalls isnt really a problem??
Maybe let Tesla know then as your DNO citing 2 Powerwalls as a problem might be of interest/concern to them
