  • entries
    29
  • comments
    139
  • views
    12364
List of equipment being installed
The holistic set I am installing is:
ASHP main parts:
: Air to water Cool Energy inverTech Air Source Heat Pump CE-iVT9 4.3kW-9.5kW
Cool Energy 60L Stainless Buffer Tank CE-B60
MVHR main parts:
 Domus HRX2-D Heat recovery System with "summer bypass"
125mm and 150mm rigid circular ducting and Domus duct insulation.
Electricity Generation main parts:
PV Sofar Solar Grid Tied Inverter 6KTLM-G2
16 Longi  320W Mono Solar Panels
CT clamp to limit power generation into grid.
HOT Water system:
206 litre indirect hot water cylinder.
1kW by 27 inch 240 volt immersion heater
Pump to showers
Heating system:
Panel radiators and two CWH 160-3 VentMatika Circular duct water heaters in the MVHR ducting.
Cooling system:
Two CWH 160-3 VentMatika Circular duct water heaters in the MVHR ducting.
EV charging point:
13 amp plug-in point direct to ring main
13amp plug-in point controlled by PV production via CT clamp.
Controls:
Dampers to the MVHR.
water flow sensors
CT clamps
5 Comments
Recommended Comments
Sandybay
Posted
I take it you are fitting a bigger solar system than 4kw?
What does the CT clamp do?
Thanks.
Marvin
Posted
Thanks.
Hi @Sandybay
Yes the system is 5.12kW max.
We had to apply to our Distribution Network Operator (DNO) for permission even though the system will be limited by the CT clamp to a 3kW feed into the grid because the system has the ability to produce over 5kW. we are still waiting for permission. The DNO advised that a decision may take 3 months!!!
CT clamp. Yes this irritated me for a while.
As I understand it, a Current Transformer (CT) clamp, can measure the current (wattage) flowing through the cable it is attached to. In this set up it will measure the current passing along the cable in between the consumer unit and the main electric meter. As the AC power goes through the cable the coil in the CT clamp produces DC power. The power runs along the CT clamps cable to the inverter. The inverter can work out how much power is being sent into the grid. When more power is potentially able to go into the grid than the level set the inverter restricts the power output.
When using the inverter it works out which way the current is flowing; otherwise it would register the current coming from the grid, however some other devices don't and the CT clamp need to go the right way.
Good luck
Marvin
Sandybay
Posted
Hi,
Thanks for the reply,
Am. Looking at a smaller system myself so appreciate the information ?
Adam2
Posted
I'm also considering a Cool Energy ASHP - the larger one. Hopefully they will be around to honour the warranty!
I notice you've mentioned pumping to showers - what is the setup you're having there?
I ask as I have 3bar where my UVC will be but most important shower is 2 floors up so may lose 1bar+ on the journey up and thinking what to do to ensure good shower performance.
Marvin
Posted
Hi Adam
We completely renovated our bungalow in 2018, but with no mains gas ran an LPG bottled gas boiler.  We know exactly how much we used and pretty much when as the bottles needed changing. We oversized our radiators at the time because we were not sure how good our insulation and airtightness would be. We have about 100 square meters of floor and used about 35kWh per m2 for heating and we estimate about 2 to 3 kWh a day hot water.
I have a 206 litre vented hot water tank, with a salamander CT50XTRA pump (1.5 bar) giving middle power water to two showers in the bungalow.
 often sold with) unvented cylinders. The ASHP uses a coil in the cylinder so it would not effect your hot water pressure. 22mm copper all the way up with as few bends as possible , and the hot pipe insulated all the way.
Having now run the ASHP for about a month, I would say that there is a lot of understanding required to know how to get the best out of a system.  We have not finished playing with the emitters (radiators and coils) yet as were running it through coils in the MVHR as well.
I believe the first two most important things when considering ASHPs are the thermal resistance and airtightness of the building and correct calculation of the heat loss. Once you have this then you can move on.
Good luck
Marvin
