Bonus edition - Garden landscaping
Back by popular demand! (Well, one person asked.)
I said the previous blog was my last.  I lied.  This bonus edition focuses our efforts to landscape the garden.
Just before we moved in in February the rear ‘garden’ looked a bit like this:
Fortunately, we’d stayed close enough to the build budget to have some funds still reserved for landscaping.  It turns out that landscaping is expensive - similar costs to groundworks in our experience.
Last year, while waiting for planning and itching to do something, we’d engaged a garden designer to help us meet some key requirements.  We wanted to create a small garden with multiple planting and seating areas with level access from the house and wheelchair access to all areas.
The designer came up with a design we liked - an interesting mixture of curves and angles, with planting and seating areas as requested.
We ended up adapting this design to form the skeleton of the garden.  In truth we were never likely to take any design without tweaking it but if we attempted the design ourselves it would have been very boring compared with the garden we now have.  (We also ditched the designers planting list suggestion but Mrs P. was always going to have the plants she wanted, and why not?)
One reason we had to adapt the design was that the fall in height was more than we planned for at 1.6m, and we only had about 12m distance to manage it given we wanted a terrace with level access next to the house.  For comfortable wheelchair access I find it’s best to limit ramps to no more than 1:20 gradient, which implies we needed to fit in 32m of ramps in a 12m x 15m area.  So the paths became a bit more meandering.  Here’s my amateur attempt at trying to gauge shape and fall of the paths.
Our excellent local landscape gardener Ashley Ralph (Ashely Ralph Landscaping - I’m not on commission!) started work in February to turn our amended plan into reality.
Marking out was fun!  This photo shows just how tight a space Ashley was working with.
Cern Abbas Giant eat your heart out!
Anyway... we needed quite a few retaining walls, which means a lot of trenches and footings.  It rained a lot in February too, which added to the challenge.
It would have been nice to achieve this with less concrete and fewer concrete blocks but I can’t think how that could have been done.
Ashley, with Francis driving the dumper.
The block walls were capped with sandstone copings and given a sand and cement render finish.
We remembered to run some armoured cables and blue water pipe to allow couple of electric sockets and water taps.  In the end we decided not to bother with external lighting even though we’d got planning permission approval because we rarely need it and are happy to use portable rechargeable lamps when we do.
The paths and seating areas are in resin bound gravel; here are the paths edged in red setts then with and a concrete sub-base on type 1.
Here’s the scene before the resin top-coat is laid but after the planting beds have had their topsoil put in.
Troy's taken the idea of 'beds' too literally:
For the terrace we used the external version of the internal 900 x 600 porcelain tiles we use throughout the house.  The external tiles are 20mm thick rather than 10mm and have a slightly rougher surface for slip resistance.
We used the same tiles for the front porch area.
The walls at either side of the rear garden have drops of over 600mm so our building inspector insisted we put up ‘fall protection’ which we did using locally sourced cedar slats, fixed horizontally to posts ‘resin-studded’ to the walls. This doubles as screening from our neighbours and provides extra shelter and structure for climbing plants, so we were not too upset at having to do this.
(The wider gaps at the bottom are deliberate here, to allow jasmine to grow through from the other side.  Beer at bottom right is entirely incidental!)
The final step for all that hard landscaping: the resin bound gravel surface.  We think it looks great.  It’s very smooth to wheel on and all the gradients are good too!
For the planting beds we imported a fair amount of loamy topsoil to go over the existing heavy clay.  Hopefully this will give a good balance with the underlying clay retaining water whilst the surface soil doesn’t get waterlogged.  The beds are not enormous but it is going to take a lot of plants to fill them.  That, and time to allow the plants to grow and establish themselves.
Er… planting beds Troy!
Obviously Mrs P. is in charge of the planting as I haven’t got a clue.   The beauty of raised beds is that you can put the soil you want in them.  One of the beds closer to the house will have sharper drainage and is going to become a Mediterranean garden.  Another has been filled with ericaceous soil for acid-loving plants.
I do know that we have some of our favourite plants already planted or planned, including roses: Nye Bevan, Claire Austen, Queen of Sweden, Champagne Moments, Donahue; also various peonies, hydrangeas eryngiums, achillia, lavenders…  and lots of others.
But plenty more planting opportunities according to Mrs P. - I’d better check that budget again!
Well, that’s it for this bonus edition garden landscaping blog.  A big thank you to Ashley and Francis for all their incredible work building our garden, and to Mrs P. of course for great plant choices, all that planting, and green fingers.
After all, what is a garden without plants?
That’s definitely it now…
…until the epilogue maybe.
Ben
  • Like 7
11 Comments
Recommended Comments
MikeSharp01
Wow - that's some landscaping - its been so long since one has seen so many terraces in a design- looks great and once it has grown in it will look amazing. Until the epilogue then.....
marshian
Lovely european feel to that - Bravo
G and J
Looking absolutely lovely, and yes lots of planting opportunities
garrymartin
This is just getting ridiculous now. Don't you know you're suppposed to have disaster stories, compromises, rogue workers, and budget failures? 😉
You and you're wife must be so happy and proud - deservedly so; you've done an amazing job. Love the terraces, and as @MikeSharp01 notes, we at least deserve an update once the planting has settled in, just so we can be a little more jealous than we already are. 🤣
Love it! ❤️
  • Like 3
Square Feet
Really smart. Lots of stone surfaces to absorb heat during the day and radiate it back out in the evening too. Really nicely done.
Pete C
Love this.  Can we have a final final blog in three months with all the snags and things you have changed?  Mind you, given the story of this blog series, I expect everything will have been perfect!
Benpointer
There are a few snags and a few things we would/should have done differently Pete, I'm not sure whether that would make for an interesting blog though.
I do plan to do something when we have had a year in the house, to reflect on our experience and lessons learned.
(PS  If you are who I suspect you are, do drop in or stop over whenever you and Mandy are down this way - not many canals nearby though, I'm afraid! ☹️)
saveasteading
Not a blog, but a few words would be interesting. Then in a year you can reflect on those notes and realise everything is fine really.
saveasteading
How high will these new trees grow? You won't be seeing that sunset for ever.
Are they fruit trees or other?
May I say it all looks great, but when I first saw your pic of the kerbs going in on 1/2m of concrete base, it made me think of a bobsleigh run.
all rather splendid now.
Gus Potter
Lovely looking house and a great job, well done!
Benpointer
Some of the trees will grow quite high but they are quite well spaced out so I am sure we'll be seeing the sunsets for as long as we're around.
None of them are fruit trees - apples in particular cause havoc for mowing, especially with a robot mower which is what we have.  So they are what I would call ornamental park trees: maple, willow, oak, chestnut, birches, elder, hornbeam, ginkgo, etc. - quite a mixture.
Mrs P. tells me we do plan to have some fan-trained fruit trees along a south-west facing fence were about to put up on one part of our boundary.  Who knew, eh?
