jamieled Posted May 30, 2019 Posted May 30, 2019 I know a few folk on here have built out of I-beams. I'm planning to stick build on site. The structural drawings state a 300mm JJ timber sole plate, but I'm having trouble tracking down sole plate timber that's 300mm wide. If you've used a sole plate this wide, what did you use and where did you get it from? I'm aware that it's possible to use an i-beam on its side, packed out, but since the engineer has specified solid timber I'd prefer to use that if possible.
PeterW Posted May 30, 2019 Posted May 30, 2019 I've seen this as a 300mm I Joist on its face as that gives the same support on the edges - does it show anything like this..? Give JJ a call as their tech support is very good
Russell griffiths Posted May 30, 2019 Posted May 30, 2019 I bought a lot of kerto beams to use as pole plates for my roof, straight as a die, lovely to work with but double the price of standard timber. Why can you not use two sole plates of 125x47 with spreader plates with a 50mm gap with insulation in between.
jamieled Posted May 30, 2019 Author Posted May 30, 2019 @PeterW thanks and no, it just shows solid timber, but I'll give them a ring and find out. @Russell griffiths, there's probably no reason I can't do that other than the engineering drawings show a single bit of timber and so I was keen to avoid deviating from that if possible. Kerto beams look interesting although I couldn't see them being noted as suitable for ground floor sole plate - I'll maybe investigate further.
bissoejosh Posted June 5, 2019 Posted June 5, 2019 Two options; 300mm could be a glulam. Alternatively as mentioned split the sole plate, we have 2 x 45x95mm plates with insulation between. Gives a decent amount of timber to fit to the blockwork below and our sole plates were all pre notched showing stud locations.
