gravelld Posted May 27, 2019 Author Posted May 27, 2019 Thanks so much, I'll purchase the kit this week and hopefully fit next weekend.
gravelld Posted May 29, 2019 Author Posted May 29, 2019 Regarding using an isolator, what do I do about the earth? I can park the earth from the junction box in the back box of the isolator, but what do I do about the earth conductor in the cable running from the isolator to the fan? The wiring diagram on the isolator suggests earth from the switch is parked in the isolator, and earth from the supply goes to the fan, but the fan does not need earth.
Onoff Posted May 29, 2019 Posted May 29, 2019 8 minutes ago, gravelld said: Regarding using an isolator, what do I do about the earth? I can park the earth from the junction box in the back box of the isolator, but what do I do about the earth conductor in the cable running from the isolator to the fan? The wiring diagram on the isolator suggests earth from the switch is parked in the isolator, and earth from the supply goes to the fan, but the fan does not need earth. The fan likely doesn't need an earth but what happens if some muppet bangs a nail in or puts a screw through the CABLE supplying the fan??? Good to have the earth continuous from the supply, to the back box then onto and "park" at the fan.
ProDave Posted May 29, 2019 Posted May 29, 2019 Continue the earth through the isolator so the earth to the fan is connected. Then at the fan just terminate it unused somewhere safe.
gravelld Posted May 29, 2019 Author Posted May 29, 2019 Oh - both earths terminate in the same block in the isolator? Duh....
Onoff Posted May 31, 2019 Posted May 31, 2019 On 29/05/2019 at 20:48, gravelld said: Oh - both earths terminate in the same block in the isolator? Duh.... Yes. Feed comes into isolator and earth terminates. Cable that goes onto fan, its earth wire is connected to the same point in the isolator. 1
gravelld Posted June 2, 2019 Author Posted June 2, 2019 Thanks. Fitted the new cable today, works a treat, trickling away with the light off! Thanks everyone. 1
