Ferdinand Posted May 19, 2019 Posted May 19, 2019 (edited) I am looking at adding a Heatstore and an Immersion type device whilst I am redoing my two bathrooms this summer. The position is: Currently I have a big solar array (10kWh, generating approx 550 kWh per year due to E/W alignment and a measure of shading) No Immersion diverter as I have no convenient heat sink. Big combi boiler (Worcester Bosch Classic Range - the biggest model). Not relevant, but modulates down to 35C. The boiler is quite new - 2-3 years. Combined UFH/radiator downstairs/upstairs heating driven from the combi. But no buffer tank in the heating system. 2 x elecric shower, 1 x shower, bath etc driven off the gas. No problems on space in the Consumer Unit etc. Most of the plumbing is in the right places, and I do not plan t be digging too many holes in walls apart from the bathrooms. Current bills are more or less £1000-1200 a year - half gas, half electric. Showers are used everyday, bath several times a week. Mainly use the gas powered shower. I am thinking about: Adding a heatstore and immersion or i-Boost, to make better use of the solar. Putting in provision for a buffer in the ufh, which willrequire inserting a couples of pipe runs in one of the bathroom refurbs. I can see that in the future I may wish to replace the boiler with a ASHP - space is available for that. Questions: Can I use a heat store in a straightforward way in this arrangement? eg can one be used to preheat water to the combi like a Sunamp? I am aware that a Divert-device will be about £500 installed, and should potentially give me £150-200 of electricity a year (perhaps), which would replace perhaps £60-75 of gas. What bill am I facing for a potential heat store? I estimate I would want one that would do 1-2 days usage. There are currently 2 here but it is potentially a house with 3-4 or a family. Am I missing any tricks? Really I am trying to think about what can usefully be done at the same time as bathrooms. All comments will be gratefully received, as thus is not an area where I have good gut-feel? (Potentially I can move some solar to the South to get better performance, but that requires me to get a car-port past the authorities - which will not happen any time very soon) Cheers Ferdinand Edited May 19, 2019 by Ferdinand
ragg987 Posted May 19, 2019 Posted May 19, 2019 (edited) 26 minutes ago, Ferdinand said: Currently I have a big solar array (10kWh, generating approx 550 kWh per year due to E/W alignment and a measure of shading) I believe you have dropped a zero here - 1kWp of PV has the potential of delivering about 1MWh per year in optimum conditions, England. Not clear what problem you are trying to solve here. Is it: I want maximise my use of generated solar? As you have mains gas / combi, as you say you will need a water store if you go that route, seems counter to the gas combi capability, plus your savings will be small compared to investment An option might be to get battery storage, you would need to do the calculations on return, but prices seem to be dropping Is it: I want to future-proof and think about ASHP? An ASHP will require a DHW store, so maybe install it now and use the immersion diverter as a stepping-stone to a future ASHP. But see above, it will not pay back on its own merits. And presumably your combi is good for another 10+ years so why bother now? I guess you could use the solar-heated water as input to the combi, maybe others can comment here Another option might be to have a cold-water coil in the tank that pre-heats the water to supply the combi Edited May 19, 2019 by ragg987
Alexphd1 Posted May 19, 2019 Posted May 19, 2019 I remember something about the worcester cdi's didnt like preheated water but this was years ago. A esbe 1 inch solar diverter is approx £120, £500 installed seams a bit high.
Ferdinand Posted May 19, 2019 Author Posted May 19, 2019 (edited) Indeed 10kWp of solar and 5500kWh of energy. I am doing bathrooms, so I am thinking about what else would be appropriate at the same time. It may be that I in fact do nothing now about from a little provisioning. Ferdinand Edited May 19, 2019 by Ferdinand
Ed Davies Posted May 19, 2019 Posted May 19, 2019 1 hour ago, ragg987 said: 2 hours ago, Ferdinand said: Currently I have a big solar array (10kWh, generating approx 550 kWh per year due to E/W alignment and a measure of shading) I believe you have dropped a zero here - 1kWp of PV has the potential of delivering about 1MWh per year in optimum conditions, England. I, too, hope you've dropped a zero here. Typically you'd expect something like 800 to a 1000 hours worth of generation per year in the UK for a decent installation depending on location and orientation. For a somewhat sub-optimal one to get 550 hours (so giving 5500 kWh) might be reasonable; 55 hours would be stunningly awful.
Ferdinand Posted May 19, 2019 Author Posted May 19, 2019 3 hours ago, ragg987 said: I believe you have dropped a zero here - 1kWp of PV has the potential of delivering about 1MWh per year in optimum conditions, England. Not clear what problem you are trying to solve here. Is it: I want maximise my use of generated solar? As you have mains gas / combi, as you say you will need a water store if you go that route, seems counter to the gas combi capability, plus your savings will be small compared to investment An option might be to get battery storage, you would need to do the calculations on return, but prices seem to be dropping Is it: I want to future-proof and think about ASHP? An ASHP will require a DHW store, so maybe install it now and use the immersion diverter as a stepping-stone to a future ASHP. But see above, it will not pay back on its own merits. And presumably your combi is good for another 10+ years so why bother now? I guess you could use the solar-heated water as input to the combi, maybe others can comment here Another option might be to have a cold-water coil in the tank that pre-heats the water to supply the combi Excellent focusing question - thanks. It is more exploring whether there is an opportunity for me at this point, rather than trying to solve a problem. It is really - can I reduce my bills further at this point, in a way which is at least marginally justifiable on the numbers (I am always happy to take a slight hit for energy economy)? (Bills have just gone back up again as I am now running heating more for a parent who is heading towards mid-80s. When we moved in in 2013 I knocked them down by a 35-40% by various usual means, but got a small shock over the last 2 quarters as extra usage has taken them part way back again.) I do not think batteries are anywhee near viable for me yet - especially as I do not get eg power cuts and so on, and I am wedded to diesel for my car for some years (towing) - just having bought a new one. For now, it would be a 24 hr capacity (ish) heat store linked to the hot water only, with the water preheating done via a heat exchanger. That is it would have at least one coil plus an immersion heater or two, and the mixing valve, boiling prevention gubbins and the rest. Reflecting, I think I would be happy to lay out perhaps £1000 for the type of saving I mentioned including the Immersun equivalent, and I do not think that will happen unless a suitable Heat Store comes up for a couple of hundred. So I think it is probably futureproof and wait until one is taken out by a Sunamp Enthusiast, and have it on the "ebay swoop" or "returned to seller" list, and provision where necessary. I will also take a look at Shower Waste HR devices, but these may be tight for my setting, and still seem to be seriously overpriced. I also need to provision for a buffer tank, which does not currently I think exist in my ufh system, unless it is in hiding. Cheers all. Ferdinand
PeterW Posted May 19, 2019 Posted May 19, 2019 20 minutes ago, Ferdinand said: Reflecting, I think I would be happy to lay out perhaps £1000 for the type of saving I mentioned including the Immersun equivalent, and I do not think that will happen unless a suitable Heat Store comes up for a couple of hundred. Unlikely however .... in your situation I would use 3 or 4 smaller cylinders such as pretty standard 140 litre hot water tanks. You can get these pretty cheap, but you can daisy chain these - and their immersions - to an immersun or similar. Also easier to source and to plumb in and locate.
Ferdinand Posted May 22, 2019 Author Posted May 22, 2019 Thanks for tecpomments, all. It looks like provision for the future and watch this space, for now, then. Ferdinand
