Solid external wall advice
Russ P
After some advice/guidance I have stripped a late 1800’s cottage back to brick and currently boarding it. Is there any method to dab a vapour board to the external walls? I was always under the understanding they had to be hardwalled or batten and boarded (not keen on this method as don’t want to loose depth) but was told by someone a few days ago I could dab vapourboard
I think the answer is yes.
you could fasten  25mm or 50mm  batons direct to bricks --so loosing  only an inch or two  and be able to put a VCL in,which  is the way I would go
but firstly  are you really  sure there are no damp problems,you need to check carefully ,
if there are these need to be sorted first ..
I,m guessing its not a cavity wall  and originally it would be lime mortar
if it has been pointed with cement mix then that could be a problem  waiting to happen ,cos cement does not breath and is not flexible like lime mortar ,so any cracks in pointing and water runs in  and don,t come out.
with the change from lime to cement was when they went to cavity walls
so any moisture in the wall cannot evaporate outwards
only inwards  .
Yes you could paint or render
.maybe ,if you have the money its time  to insulate it on outside .then render  or brick slips--2 jobs at once! warm +dry
Edited by scottishjohn
You can dab a moister board on
Or even a foam backed board
 No need to machanocal fix if it is bare brick or block
13 minutes ago, ADLIan said:
Foam (insulation) backed plasterboard must be mech fixed to wall (otherwise it’ll just fall off in a fire!)
No
Ive fixed thousands of them
No problem at all
Dab with standard drywall
only inwards  .
I was hoping to avoid batten and board as the 2 of the rooms are small already. The outside is already rendered and painted and I’ve not had damp issues in the 3 years I’ve owned it so far.
I was told it was the standard foil backed plaster board that can be dabbed
Is there’s a certain adhesive you have to use for the vapour boards (foil backed)?
trying to stay away from foam backed due to the rooms being small already
