MikeSharp01 Posted May 7, 2025 Posted May 7, 2025 46 minutes ago, Nickfromwales said: The 4 bar will give a 4 bar feed to the kitchen sink tap. The hot will have 3 bar from the CG at the UVC, and there's your 1 bar fight Ah I forgot to say that it is a separate filtered tap. Cold only which we will use for kettle, food water etc. Otherwise two PRVs is not a problem? 1
Nickfromwales Posted May 7, 2025 Posted May 7, 2025 3 hours ago, MikeSharp01 said: Ah I forgot to say that it is a separate filtered tap. Cold only which we will use for kettle, food water etc. Otherwise two PRVs is not a problem? Correct, sir. If you find that hard water outlet is a bit aggressive / noisy with 4 bar on it, then you can fit a flow restrictor in, if needed of course. Trial and error jobby tbh. https://www.bes.co.uk/flow-regulator-ball-valve-cp961-15mm-17527/
