Sam Thomas Posted February 1, 2019 Posted February 1, 2019 Normally 63mm pumping discharge guide rails are good as pump slides down rail and connects easily to tank good if ever go wrong for maintenance. twin pump are also good systems have you tried marsh industries at Kettering way they are also stocked at sde Milton Keynes
Ed_MK Posted February 2, 2019 Author Posted February 2, 2019 thanks for the advice guys ...and where was that coil price please ? The BCO hasn't signed it off yet ...but I am making sure that it is compliant with section H specifically the tank size / no of bedrooms and alarm if no redundancy is built in (single pump) and the fact we are running it to a mains sewer I cant see him having much objection ..but i will run it by him the alternative is cesspit ..and they seem to hate those
Russell griffiths Posted February 3, 2019 Posted February 3, 2019 Here’s a random idea why not install a sewage treatment plant, and then just pump cleaned grey water instead of lumpy poo water. Would only require the digging of a shallow, narrow trench to take the 65mm pipe, no fall needed
