Jeremy Harris Posted January 8, 2019 Posted January 8, 2019 7 minutes ago, ProDave said: My guess re the PPE is he didn't know what service head he would find. A modern one like you have is usually perfectly safe, but if he had found an old cast iron one, I'll bet the PPE would have been used. I reckon the old Bakerlite ones are probably the worst, aren't they? At least with the cast iron ones you can see what you're dealing with before you start, but I pulled one of the black ones years ago and the thing literally fell to pieces as it came out. Luckily we were taking the roof off the house and doing a complete rewire and replumb, plus we still had power from the farm supply, as IIRC it took SWEB a couple of weeks to come out and fix it (them being so slow was the reason my brother and I just pulled the fuse in the first place).
Adsibob Posted April 21, 2021 Posted April 21, 2021 On 22/12/2018 at 14:14, scottishjohn said: has anybody done the calculations on CHP units run on mains gas ,as it appears that my plots can have mains gas now - and from what I have gleaned from here if you have mains gas its still cheaper than any other solution at this time even if only to heat water . Just giving this a bump in case 2.5 years later someone has an answer to it.
