scottishjohn Posted November 26, 2018 Share Posted November 26, 2018 (edited) HI, been doing some searching and contacting suppliers durisol £65 per sq m integraspec with extra insulation 45 euros Integraspec without extra insulation 42 euros integraspec insulated raft 300mm thick approx +edges up around the slab 35euros sqm any body got any other prices ? Edited November 26, 2018 by scottishjohn Link to comment Share on other sites More sharing options...
scottishjohn Posted November 26, 2018 Author Share Posted November 26, 2018 Ialso am looking into supply of bracing systems --simple cheap one zonts+zuckles https://fab-form.com/zontBracing/zontBracingProjectPacificIcf.php next year i will be building so any one interested in these message me and i will see what sort of bulk deal can be had closer to the time Link to comment Share on other sites More sharing options...
Big Neil Posted November 26, 2018 Share Posted November 26, 2018 There's a thread somewhere on here someone knocked up. Very useful. Attached are from polarwall Price list 2017.pdf Price list PLUS 2017.pdf Link to comment Share on other sites More sharing options...
ToughButterCup Posted November 26, 2018 Share Posted November 26, 2018 The price of the raw material is not the only cost to take into account; the biggest annoyance (on our build) was the cost of mishandling the blocks. In other words - the couldn't-give-a-stuff-itis It matters if other blocks are used as a cutting surface , so when the builder uses those blocks there are so many cuts on it that the block bursts. It matters if there is only one supplier: we used more than we thought we would, and instead of just popping down to the BM, you have to arrange a palletised delivery. Despite being repeatedly asked, our builder seemed to take delight it tell us we needed more blocks five minutes before they disappeared off site. It matters if the blocks are laid without care and subsequently, instead of relaying, bashed into place with a piece of 3 by 2 - and so fractured, causing the inevitable burst. Ask about delivery lead time. Its getting longer..... On balance, those carelessnesses added nearly 5% to the raw price. By the way, just been to a local Durisol build. An appreciable number of (as yet unused) blocks were 5mm more 'out' . QA, it seems is becoming an issue. They should not have left the factory. 1 Link to comment Share on other sites More sharing options...
scottishjohn Posted November 26, 2018 Author Share Posted November 26, 2018 (edited) 38 minutes ago, recoveringacademic said: The price of the raw material is not the only cost to take into account; the biggest annoyance (on our build) was the cost of mishandling the blocks. In other words - the couldn't-give-a-stuff-itis It matters if other blocks are used as a cutting surface , so when the builder uses those blocks there are so many cuts on it that the block bursts. It matters if there is only one supplier: we used more than we thought we would, and instead of just popping down to the BM, you have to arrange a palletised delivery. Despite being repeatedly asked, our builder seemed to take delight it tell us we needed more blocks five minutes before they disappeared off site. It matters if the blocks are laid without care and subsequently, instead of relaying, bashed into place with a piece of 3 by 2 - and so fractured, causing the inevitable burst. Ask about delivery lead time. Its getting longer..... On balance, those carelessnesses added nearly 5% to the raw price. By the way, just been to a local Durisol build. An appreciable number of (as yet unused) blocks were 5mm more 'out' . QA, it seems is becoming an issue. They should not have left the factory. thats handy to know --have durisol been made aware of that problem at 50% more expensive than integraspec i doubt i will be going that way ,but maybe brother will with zonts +zuccles being cheap it makes the advantage of no bracing that Durisol has --less important you can buy the zonts cheaper than you can hire bracing ,then sell on and use the 4x2 wood for interior stud walls etc current prices from ukagent Hi John, Many thanks for your enquiry. The Zonts are £12 each and come in boxes of 20 units, while the Zuckles are £18 each and come in boxes of 10 units. All prices plus VAT and delivery. Regards, Najem Al-Hasan Edited November 26, 2018 by scottishjohn Link to comment Share on other sites More sharing options...
Big Neil Posted November 26, 2018 Share Posted November 26, 2018 Zonts and Zuckles sound like something you'd find in a secret room at Willy Wonka's Factory. I can't wait to get home to a computer that works and see what they are... Link to comment Share on other sites More sharing options...
Alexphd1 Posted November 26, 2018 Share Posted November 26, 2018 (edited) Can't comment on the duriosl. The icf costs are pretty competitive, what thickness is the extra insulation? Is the raft a mix of EPS 100/300 or 100% EPS 300 as if the latter it's bang on! The zonts are a good product. Also watch shipping costs I underestimated this on my insulated raft material from Ireland while the nudara price inc shipping. Edited November 26, 2018 by Alexphd1 Link to comment Share on other sites More sharing options...
scottishjohn Posted November 30, 2018 Author Share Posted November 30, 2018 (edited) another price for ICF --velox system to give 0.15 walls £50 sqm I should clarify that is just the wall value not including exterior or interior finishing which of course will drop it some more Edited November 30, 2018 by scottishjohn Link to comment Share on other sites More sharing options...
Tom See Posted June 12, 2020 Share Posted June 12, 2020 Hi does anyone have a rough cost of Velox wall system per m2 or where to find some useful price guides?! Link to comment Share on other sites More sharing options...
scottishjohn Posted June 12, 2020 Author Share Posted June 12, 2020 (edited) 34 minutes ago, Tom See said: Hi does anyone have a rough cost of Velox wall system per m2 or where to find some useful price guides?! ring the agent http://www.velox-systems.co.uk/#2 I would qualify any of the costs you think you have got @sqm price by saying get your design and plans done first -send them to suppliers for them to quote and don,t forget to include bracing hire costs for those that need it Edited June 12, 2020 by scottishjohn Link to comment Share on other sites More sharing options...
Tom See Posted June 12, 2020 Share Posted June 12, 2020 24 minutes ago, scottishjohn said: ring the agent http://www.velox-systems.co.uk/#2 I would qualify any of the costs you think you have got @sqm price by saying get your design and plans done first -send them to suppliers for them to quote and don,t forget to include bracing hire costs for those that need it Cheers, I'm actually a student doing a university project where I have to design a house for a family for that's self build able for £50000 and meets passivehaus standards (practically impossible I know ?) and test it using Energy plus softwaere but just after some very rough price estimates. It's a 2 floor flat roof 7x8m house Link to comment Share on other sites More sharing options...
scottishjohn Posted June 12, 2020 Author Share Posted June 12, 2020 7 minutes ago, Tom See said: Cheers, I'm actually a student doing a university project where I have to design a house for a family for that's self build able for £50000 and meets passivehaus standards (practically impossible I know ?) and test it using Energy plus softwaere but just after some very rough price estimates. It's a 2 floor flat roof 7x8m house rough estimate prices will make nonsense of your project the prices need to be accurate if it is to have any validity maybe you should be emailing velox in poland diect and tell them what you are doing . or indeed and ofthe sduppliers of systems youare putting in your study Link to comment Share on other sites More sharing options...
Tom See Posted June 12, 2020 Share Posted June 12, 2020 Thanks I'll do that. Perhaps a more relevant question to people on this group could be whether relating to cost, build ability, preference etc. Aside from the velox wall system would (or have) people used the velox floor/ceiling/ roof systems or found it easier using an alternative? I.e suspended timber floor or timber roof etc Link to comment Share on other sites More sharing options...
scottishjohn Posted June 12, 2020 Author Share Posted June 12, 2020 26 minutes ago, Tom See said: Thanks I'll do that. Perhaps a more relevant question to people on this group could be whether relating to cost, build ability, preference etc. Aside from the velox wall system would (or have) people used the velox floor/ceiling/ roof systems or found it easier using an alternative? I.e suspended timber floor or timber roof etc again Iwould sday ask in polland on the internet there ,as they have been using it for 30years + very few users in UK - Link to comment Share on other sites More sharing options...
Raoul Posted February 3, 2021 Share Posted February 3, 2021 Does anyone know what's the labour price to build icf, nudura thermohouse etc. What's the sqm price for laying the blocks? Thanks Link to comment Share on other sites More sharing options...
