Decided on galvanised Lidab majestic guttering...anybody got this and what diameter did they go for?
choices are: 100, 125,150 and 190... ruling out 150 and 190 as enormous for a 1.5 story building!
Depends on the roof pitch and also the tile overhang. 125mm is much better than 100 - deepflow gutters also don’t need as many downpipes
How do you work out how many down pipes I wonder.
BSEN 12056, Part 3: Roof drainage, layout and calculations...
Slate roof, 42degree pitch, overhang of 60mm, can’t see an option for deep flow but think the steel is all deep? Happy to be corrected!
You need to be pretty handy with the tin snips for cutting Lindab and fitting outlets.  Saw or grinder is a no-no as the rough edges rust where a clean cut has less surface area and will heal with galv.
That is interesting, I just took the house next door as an example of required drainage arrangements and used the part H rules for the BC stuff, seems I could have been much more refined.
