Imtrying to establish what size this ASHP is and is it a model worth having?
Viessmann Air Source Heat Pump complete with Indoor Unit & 200L Viessmann Buffer Tank. Buffer Tank Model - VC100-ESWV 200L. Air Source Model - Vitocal 200 - S/222/S/242/S
Just contacted the seller who says - The heat pump is 4.5kw power consumption, heating output is 7.7kw.
Is it a split or a mono?
Is the COP really only 7.7/4.5 = 1.7 ?
Does it improve at say half power?
Edited by Temp
Does it improve at half power?
From what others have deduced the ASHP in question is a split unit and being second hand may not be worth buying as it requires a specialist install.
ps. So you can’t sleep either!
Edited by Triassic
