Moonshine Posted October 4, 2018 Posted October 4, 2018 I am looking to build on a sloped site, as such some of the external walls on one level of the proposed house will be a retaining wall with habitable rooms inside. My question is, in these spaces would you build the retaining wall, have a cavity with thermal insulation inside and the internal leaf, or something else?
Hecateh Posted October 4, 2018 Posted October 4, 2018 Mine is similar - access is single level leading to a two storey at the rear. Their is a side retaining section at the bottom, specified by the SE, then double blockwork with insulation up to the level of the upper floor and then timber stud to the ceiling. The attached drawings were for building regs approval High Croft Bungalow b regs-007E.pdf
Tyke2 Posted October 4, 2018 Posted October 4, 2018 Hi Yes you can do this. You can also rake back the ground behind the wall so that there is no load against it, thus reducing the need for it to retain. You really need to ensure that whatever detail you use it is adequately water stopped. The wall should have drainage behind it and a good quality DPM behind or in front of it. I'm assuming you are designing it yourself, rather than getting an architect to specify the wall detail?
Moonshine Posted October 4, 2018 Author Posted October 4, 2018 56 minutes ago, Hecateh said: Mine is similar - access is single level leading to a two storey at the rear. Their is a side retaining section at the bottom, specified by the SE, then double blockwork with insulation up to the level of the upper floor and then timber stud to the ceiling. The attached drawings were for building regs approval High Croft Bungalow b regs-007E.pdf thanks for the pointers, very useful
Moonshine Posted October 4, 2018 Author Posted October 4, 2018 33 minutes ago, Tyke2 said: I'm assuming you are designing it yourself, rather than getting an architect to specify the wall detail? Cheers, I am just thinking about layouts and setting out general space requirements, detailed design of retaining walls will be based on SE requirements
mvincentd Posted October 4, 2018 Posted October 4, 2018 In basemented sections I went for external insulation, dpm, reinforced concrete wall...that's it, a spot of clear sealer on the walls and i'm decorated. You could dot n dab plasterboard on if you prefer a more traditional aesthetic. Be sure to carefully detail all areas where external insulation has to transfer to cavity or internal.
bissoejosh Posted October 6, 2018 Posted October 6, 2018 I'd look at ICF which can be the retaining wall and the insulating external wall in one go. Spend plenty of time looking at waterproofing and warranty requirements.
