That part is the easy part Nick :D
Link
But the other adapter bit I can't seem to find, found this, but that looks like a BT to RJ45 cable with a RJ45 to RJ45 connector plugged in the end.  This thought there would be a neater solution..
This is what we used to supply with every telephone on structured cabling ( patch able) installs. Phone plugs into that, that plugs into wall socket.
If your having a dedicated cordless phone position ( base station ) then it seems a better idea to make that one a dedicated BT outlet and have done with it maybe?
Thats what is usually easier tbh - you can get face plates to make up BT sockets along side Ethernet and they are pennies.
I was late last night so I mustn't be explaining things right, let me try again with a diagram
What is it:                  Virgin Media     A     CAT5e cable        Faceplate          B       My phone
Socket/Plug type:      BT Socket       A      RJ45 Plug            RJ45 Socket    B      RJ11 socket
So at point B there is no problem, as a cable with a RJ45 socket on one end and RJ11 socket on the other sorts that out.
But at point A a cable with 2 plugs wont work, and the cable you linked to Nick is the wrong way round, I need something with a BT plug on one end and a RJ45 socket on the other.
I think this LINK will work but it uses a cable with a BT socket and RJ45 socket and then a RJ45 extender connector, I'm just wondering if there is something like what Nick linked to but with a BT plug and RJ45 socket
Edited by Calvinmiddle
