I am in the process of removing our solid floors and our suspended floors to fit insulation and underfloor heating.
Below our suspended floors the void is bigger than I had expected and below the void there is a concrete slab. I had originally expected to lay new concrete and PIR insulation. I am now considering using the existing concrete base and using EPS; aware that EPS is less insulative than PIR but putting more down to compensate.
The issue I have is the original concrete floor is sloping. At one end I have about 400mm to the floor level; 4 meters away its 300mm. I'm looking for suggestions to fill this. Would you just level with more concrete or is there something cleverer I could do?
Just add more insulation in steps
EPS at 25mm sheets would mean you can step it down roughly (ie 25mm every metre) so it goes 200-225-250-275mm across the room.
Stick them together with low expanding foam.
As an alternative method
kango up the old concrete into tiny bits, leave in situ
add a layer of type 1 and whacker down firm
blind with a thin layer of sand
damp proof membrane
insulation
ufh
concrete topping with mesh.
I would use type 1 to part fill where it is over 50mm and sharp sand elsewhere, compact with a whacker to get it nice and level.  Cleaner and more forgiving than concrete and simple to DIY.
Many thanks for the suggestions and sorry for the delayed reply.
How thick do you think this would have to be?
Would you think structural concrete above the insulation is required in this case, or would a liquid screed be sufficient?
Either 75mm normal screed or 50mm liquid.  Double check with insulation and screed suppliers for peace of mind.  Put a thin strip of insulation around the perimeter.
