bassanclan Posted June 7, 2018 Posted June 7, 2018 You will also need a couple of bags of cement to prime the pump
mvincentd Posted June 7, 2018 Posted June 7, 2018 When he purges the pump don't assume because you showed him earlier where to dump it that he will.....hound him. You've drawn the site road 3.5 x 1m squares and said its half that...so 1.75m.....so any obstructions or issues either side of that for the pump width including outriggers...maybe ask pump co' get their rep to drop by and see site so no-one gets surprises on the day.
Pocster Posted June 7, 2018 Posted June 7, 2018 1 hour ago, mvincentd said: When he purges the pump don't assume because you showed him earlier where to dump it that he will.....hound him. You've drawn the site road 3.5 x 1m squares and said its half that...so 1.75m.....so any obstructions or issues either side of that for the pump width including outriggers...maybe ask pump co' get their rep to drop by and see site so no-one gets surprises on the day. This is good advice ! Always get the firm out first to check access and reach !
PeterW Posted June 7, 2018 Posted June 7, 2018 If its only founds then check how much it would be for a low pump unit - not as critical to use a boom pump for placement as its more about getting the concrete to the trenches in this case. Think these guys cover your area
