ProDave Posted May 26, 2018 Posted May 26, 2018 To insulate the pipes from the house to the ASHP All I seem to be able to find is the normal foam stuff. I can't believe that will be any good outside for long, and the mice will eat it anyway. I want something properly rated for outside use, that won't turn to dust and won't get eaten. All the usual outlets, the sheds, BES etc don't have anything. Bhe best I can find is this, but it looks pathetically thin. https://www.ebay.co.uk/itm/EXTERNAL-INSULATION-FOR-USE-WITH-PEX-AL-PEX-COPPER-PLASTIC-PIPE-10-METER-LONG/142498377460?hash=item212d90aef4:m:mK9vmX0SOEaVH7M3-B-diAA What do the rest of you use? why is it so hard to find?
PeterW Posted May 26, 2018 Posted May 26, 2018 You need to use Nitrile Rubber so Armaflex or InsulTube. All are suitable but the preference should be one that is also UV rated which the solar ones tend to be. Armaflex
ProDave Posted May 26, 2018 Author Posted May 26, 2018 Se will the nitrile rubber survive the tendancies or rodents to eat anything vaguely plastic? As always it's knowing the trade names. You would think the sellers would refine their search engines so this comes up when you search for "outside insulation"
newhome Posted May 26, 2018 Posted May 26, 2018 11 minutes ago, ProDave said: So will the nitrile rubber survive the tendancies of rodents to eat anything vaguely plastic? I don't think the stuff I've got here looks very rodent proof TBH. Can't you wrap it with something like aluminium foil tape afterwards as a deterrent?
ProDave Posted May 26, 2018 Author Posted May 26, 2018 Still struggling I have found this https://www.ebay.co.uk/itm/new-4M-ARMAFLEX-HIGH-TEMP-solar-copper-MDPE-pipe-tube-A-C-Insulation-lagging-UK/122801904482?hash=item1c97905b62:m:mQh2N7BMledKQZKkAMSS2CQ That's flippin expensive. (I need about 6 metres so that one would not be long enough) BES don't have Armaflex or that other one. I keep finding "Class O Nitrile insulation" but it doesn't mention outdoor use https://www.bes.co.uk/class-o-insulation-tube-7-8in-x-25-mm-x-2-m#product-details-tab Would that one be okay if I did as @newhome suggests and wrap it in aluminium tape?
PeterW Posted May 27, 2018 Posted May 27, 2018 @ProDave JTM sell it as per the link - £2 a metre for the solar stuff. None of it is rodent proof but you could wrap it with something like duct tape but they will eat that too ... tbh if they are eating that, they are hungry ..!
newhome Posted May 27, 2018 Posted May 27, 2018 https://www.ebay.co.uk/itm/ANTI-RODENT-RATS-MICE-ELECTRICAL-DETERRENT-INSULATION-TAPE-CABLES-WIRING-PIPES-/282336801801
Onoff Posted May 27, 2018 Posted May 27, 2018 Any aircon or ducting manufacturers near you? They might roll you a length of ali or zinc sheet you could prime & paint?
Onoff Posted May 28, 2018 Posted May 28, 2018 (edited) Is there any possibility of running the ASHP pipes underground / in a hidden duct? Edited May 28, 2018 by Onoff
ProDave Posted May 28, 2018 Author Posted May 28, 2018 No way too late for that, that would have required thought when the foundations were going in.
Onoff Posted May 28, 2018 Posted May 28, 2018 (edited) I'll email a chiller lad I know from site in the morning. He fits GSHPs. Maybe he'll know the name. Edit: I've had a beer, I meant ref your dosing pot thing! Edited May 28, 2018 by Onoff
