Pocster Posted June 28, 2018 Author Posted June 28, 2018 17 minutes ago, joe90 said: The size of pipe depends on what area of roof you are draining really ? It’s about 5 x 7 m Thing is I’ve got to put 90mm block paving on that - which obviously won’t fit . So will need to trim them anyway ......
Pocster Posted June 28, 2018 Author Posted June 28, 2018 Joining 2 4m lengths on your own not fun ! But done !!
joe90 Posted June 28, 2018 Posted June 28, 2018 Well, standard down pipe is 68mm, I would have thought this would cope very well on the flat with such a small roof. Others will be along shortly to confirm/deny. 1
Pocster Posted June 28, 2018 Author Posted June 28, 2018 44 minutes ago, joe90 said: Well, standard down pipe is 68mm, I would have thought this would cope very well on the flat with such a small roof. Others will be along shortly to confirm/deny. The thing is a 110mm is nice and solid . Rain pipe 68mm quite flimsy . Unless of course you can get a 68mm below ground drain pipe - that would help ! Found pavers the wife likes that are 55mm ( hurray ) but £120 a sq metre ?
Pocster Posted June 28, 2018 Author Posted June 28, 2018 (edited) Ok ! It would seem a below ground 68mm drainpipe doesn’t exist ; only 110 or above . Bit reluctant to use down pipe drain horizontally in concrete . Drainpipes are quite solid compared to rather brittle down pipes ..... Edited June 28, 2018 by pocster
Construction Channel Posted June 28, 2018 Posted June 28, 2018 Could you not run an aco drain across in front of the opening? As it would finish flush with the pavings it would gain you a lot of height.
Pocster Posted June 28, 2018 Author Posted June 28, 2018 17 minutes ago, Construction Channel said: Could you not run an aco drain across in front of the opening? As it would finish flush with the pavings it would gain you a lot of height. I could But its rainwater for harvesting I’m trying to collect so don’t really want any surface water . I do have a micro channel drain (32mm wide) that I am going to run across the front for surface water . So downpipe from roof for harvesting . Nano for surface in front house . Also have a shallow drainage channel for front of plot / driveway . Trying my best to avoid any sitting water !!
Construction Channel Posted June 28, 2018 Posted June 28, 2018 24 minutes ago, pocster said: I could But its rainwater for harvesting I’m trying to collect so don’t really want any surface water . I do have a micro channel drain (32mm wide) that I am going to run across the front for surface water . So downpipe from roof for harvesting . Nano for surface in front house . Also have a shallow drainage channel for front of plot / driveway . Trying my best to avoid any sitting water !! Why is the rain that hits the roof different to the rain that hits the pavings? 1
PeterW Posted June 28, 2018 Posted June 28, 2018 2 minutes ago, Construction Channel said: Why is the rain that hits the roof different to the rain that hits the pavings? Rain on a roof is only contaminated by airborne particles and dirt. Ground borne contamination can include hydrocarbons such as oil and fuel, and other chemicals such as antifreeze or anything spilt on the floor. None of which you want in your rainwater tank !! 1
