Is it OK to build blocks off damp proof liquid membrane? I think I was once told it's ok and you throw sand in the second coat of the stuff?
Cheers
Vijay
Any reason you want to use this rather than DPC..??? The mortar below needs to be dry so you will be waiting a week before you can paint it on - and the blocks need to be dry too..!
I've put DPC under the floor beams but wanted to have another slightly higher up too where the radon/DPM will be. I'm not 100% happy with the DPC under the beams as when moving them into position, there's every chance they may be scratched/scored - so I'd rather be 100% happy. I may use both a normal DPC and liquid
10 hours ago, Mr Punter said:
Unless you are building over a swamp you are being paranoid unnecessarily cautious.
That probably wouldn't be the first time that's been said to me ?
