Russell griffiths Posted April 26, 2018 Posted April 26, 2018 Evening, can anybody point me in the right direction what is the minimum soil coverage over the top of a drain run, 1. If it was running parallel with the house and going to have a concrete foot path over it, no vehicle access. Thanks. Russ.
Onoff Posted April 26, 2018 Posted April 26, 2018 All the soil pipe people do something like this: https://www.marleyplumbinganddrainage.com/media/5423/pipe-laying.pdf 1
Construction Channel Posted April 26, 2018 Posted April 26, 2018 3 minutes ago, Onoff said: All the soil pipe people do something like this: https://www.marleyplumbinganddrainage.com/media/5423/pipe-laying.pdf I read that as min 75mm +slab. I have dug out others a lot shallower than that. id say 50mm of concrete on top and you should be fine but it all depends if it has to be passed by someone.
nod Posted April 26, 2018 Posted April 26, 2018 1 hour ago, Russell griffiths said: Evening, can anybody point me in the right direction what is the minimum soil coverage over the top of a drain run, 1. If it was running parallel with the house and going to have a concrete foot path over it, no vehicle access. Thanks. Russ. I’ve one drain simalar to yours running parrelel to our build We has to start high to get the required fall So about two metres has hardly any cover on it BC said its ok just put a strong mix over it when I bed the flags 1
