Onoff Posted April 25, 2018 Share Posted April 25, 2018 Is this stuff any good for insulation in a timber stud wall? http://www.stvincents.co.uk/polystyrene_beads.php Link to comment Share on other sites More sharing options...
epsilonGreedy Posted April 25, 2018 Share Posted April 25, 2018 3 hours ago, Onoff said: Is this stuff any good for insulation in a timber stud wall? Thermal or sound insulation? Link to comment Share on other sites More sharing options...
Onoff Posted April 25, 2018 Author Share Posted April 25, 2018 38 minutes ago, epsilonGreedy said: Thermal or sound insulation? Thermal more so. Rather than keep faffing cutting PIR offcuts and foaming them in I wondered whether to just staple the vcl on and fill as I go with beads: Link to comment Share on other sites More sharing options...
ADLIan Posted April 25, 2018 Share Posted April 25, 2018 Probably not - total lack of any technical info. High performance mineral wool would be best option. Link to comment Share on other sites More sharing options...
Onoff Posted April 25, 2018 Author Share Posted April 25, 2018 1 minute ago, ADLIan said: Probably not - total lack of any technical info. High performance mineral wool would be best option. Good shout other than I've got to BUY it! Was hoping to just use up the old crap lying around. Link to comment Share on other sites More sharing options...
PeterW Posted April 25, 2018 Share Posted April 25, 2018 So you’ll get an old crap result .... drilling a hole will see them pour out into the room ... good for You’ve been Framed, not so good for thermal insulation ... Link to comment Share on other sites More sharing options...
Onoff Posted April 25, 2018 Author Share Posted April 25, 2018 (edited) 12 minutes ago, PeterW said: So you’ll get an old crap result .... drilling a hole will see them pour out into the room ... good for You’ve been Framed, not so good for thermal insulation ... Cheap seats here! OK, no EPS beads but all this "old crap" is going in the wall with copious amounts of gun foam and foil! Edited April 25, 2018 by Onoff Link to comment Share on other sites More sharing options...
daiking Posted April 25, 2018 Share Posted April 25, 2018 All that wood is going to give you more bridges than Amsterdam anyway. 1 Link to comment Share on other sites More sharing options...
Onoff Posted April 25, 2018 Author Share Posted April 25, 2018 1 hour ago, daiking said: All that wood is going to give you more bridges than Amsterdam anyway. I know. Tbh the packs aren't as numerous as they appear. Originally it was just 5 fixings per vertical stud but the concrete screws wouldn't hold very well in this bit of the wall. So in went some horizontal 3"x2"s fixed with resin studs. Link to comment Share on other sites More sharing options...
