paulc313 Posted March 3, 2018 Posted March 3, 2018 Hello, I would appreciate any comments regarding the draft plans I have had drawn up. The plans are at their very first stage and I will likely make changes but would appreciate any thoughts from users here! Thanks Paul Drumnicol new gf.pdf Drumnicol new ff.pdf
ProDave Posted March 3, 2018 Posted March 3, 2018 Which way is north? or more importantly which way is south?
paulc313 Posted March 3, 2018 Author Posted March 3, 2018 North is the top left corner of the plan, south is bottom right corner.
ProDave Posted March 3, 2018 Posted March 3, 2018 My only comment is that makes the living room window face north west, so will only get late evening sun. Is there anything stopping you putting windows in the south west facing gable end? I guess there must be as it would be so obvious if you could? Site layout might help make things clearer.
newhome Posted March 3, 2018 Posted March 3, 2018 I think the layout is great. I could easily live there . Do you have a breakfast bar somewhere in the kitchen? I can't see easily. I have a kitchen island that I use all the time for casual dining. A breakfast bar somewhere would be perfect.
PeterW Posted March 3, 2018 Posted March 3, 2018 Ok... Change the layout of the downstairs shower room so that it loses a bit of wardrobe from the bedroom but the shower and loo are moved to give you 2 doors into it so it’s a jack and Jill type downstairs WC but also ensuite to the guest bedroom Flip the long run of cupboards in the kitchen to put the fridge to the top, then storage and ovens - makes working from hob to oven easier and safer and keeps your “triangle” in form. Upstairs - swap the study for the family bathroom otherwise bed 2 has a long way to go ..! make the master bedroom ensuite a bit wider - you have the space - and line the wall up with the dressing room wall. Check the ceiling height in that dressing room - it may be lower than you envisage. Other than that - nice plans ..!
