Just looking for a 2nd opinion. We are planning to treat the 18mm wbp plyboard with creosote. Any other paints oil would be a better option? The plyboard will have a 2 inch ventilated gap under and breathable felt with standing seem stainless steel roof above.
It will stink when it gets warm for years ! why do you want to treat it...??
If its for anti condensation then you would want something acrylic based.
Reason, quick Google on wbp ply and a few comments on not as good as it used to be and little water results in delaminating. I am probably over thinking this.
Proper BS STD ply is water and boil proof and will stand a lot of moisture before it delaminates. For something that’s going to be there for decades I’d suggest you go for a decent and stamped / approved board from a reputable supplier.
15 minutes ago, PeterW said:
Is it stamped as certified WBP. ..?
Good exterior ply should be marked as BS so check first.
Yes just checked.
