Triassic Posted February 12, 2018 Posted February 12, 2018 I’ve had the basement dug out into a hillside and I’ve just started levelling ready to install the insulated raft foundation. Before I do that, I need to install a foul drain to serve a bathroom, along with a spur to the storeroom containing the thermal store. The problem I have is that we hit limestone bedrock, so I’ll need to chisel out a slot around 20m long into which the Darin will go. What is the minimum depth the Building Inspector is likely to find acceptable?
ToughButterCup Posted February 12, 2018 Posted February 12, 2018 3 minutes ago, Triassic said: [..] . The problem I have is that we hit limestone bedrock, so I’ll need to chisel out a slot around 20m long into which the Darin will go. [...] Oooooooooofffffff
Ian Posted February 12, 2018 Posted February 12, 2018 33 minutes ago, Triassic said: What is the minimum depth the Building Inspector is likely to find acceptable? There's no minimum depth as far as I know however you'd need to check with your BCO. If it's very shallow they may want you to surround the drain in concrete with movement joints at each pipe joint
MikeSharp01 Posted February 12, 2018 Posted February 12, 2018 I have a friend with an explosives licence - she might be able to 'create' a feature in which to run the pipe!
Triassic Posted February 13, 2018 Author Posted February 13, 2018 Just to clarify, the ground surface is limestone bedrock, how deep into the rock would I need to dig ?
PeterW Posted February 13, 2018 Posted February 13, 2018 If you are less than 200mm below the surface to the top of the pipe, from memory I think you need to encase in concrete. http://www.marleyplumbinganddrainage.com/media/5423/pipe-laying.pdf
Triassic Posted February 23, 2018 Author Posted February 23, 2018 Had a helpful conversation with our Building Control guy, he’s happy with 50mm of concrete cover over the pipe encased in rock.
Triassic Posted March 8, 2018 Author Posted March 8, 2018 (edited) Just one further question. I was thinking of running a drain from my thermal store to the sewer 12 metres away. Is this OK run in 40mm waste pipe, is 40mm big enough? Edited March 8, 2018 by Triassic
