Suggestions for power backup etc
Does anyone have any good insights on risk management and power backup at this not very peaceful time?
I'm interested in what has been done by build hubbers, and what is possible, as well as my own options. AIUI a house battery can be appropriately configured to provide suitable backup - though personally I only have traditional solar and no plans soon to spend thousands on a house battery.
For me, my basic power supply is very stable, and I cannot remember a power cut, but my vulnerabilities are probably the freezer and internet, and I have things around like a portable gas heater and a decent camping stove anyway, plus a gas cylinder, which would do cooking for days, and various types of torch.
Looking at the fairly good Black Friday price reductions (more than half) on good quality camping powerbanks in the 2kWh range, I'm perhaps inclined to go for one of those using an LiFePO4 battery, which does thousands of cycles and is aiui inherently safer than other lithium batteries.
I get double bubble in that it will get used for camping. They are still quite chunky bits of kit, however.
All comments and enlightenment welcome.
Ferdinand
I would imagine that any large scale blackout is going to bring down the ISPs too, so internet probably beyond your control. I doubt there is much better than your mobile phone and a small powebank, unless you want to go starlink.
I'm not sure how much good a house battery does you for resilience. If you are using it how most people do then run a risk that when the power goes off it is empty, so then you are relying on solar etc. Personally wouldn't worry about the freezer, it will be ok for a few hours to a day i would guess and you can buy many freezers of food for the price of a battery.
What I am intending to do is get a good inverter to run off my electric car battery. Even when nearly empty it has more energy than most house batteries and it is usually kept topped up. I could run my house for days off a half full battery.
Very wise.
Mentioned this on another topic about this.
My car ticks over and used 0.1 gallons per hour. So about 450W.
It would be warm in the car as well.
Maybe a camper van is the best option.
I think the biggest problem is that a lot of households don't want to change lifestyle when the power goes out.
Why run a huge telly with surround sound to watch the news saying there is a major power outage.
Interesting thread. Guess you need to decide what you’re trying to cover and for how long?
UK grid is generally fairly good (unless you live remotely with trees over your lines). So rarely worthwhile to actually reinforce beyond a couple of hours for them doing line maintenance.
If you’re going the whole hog, you’d need a gen set and a changeover switch, but if we’re talking doomsday scenarios, you’d also need a way to fuel it. Then maintaining it etc is a different headache.
Maintaining family convenience is very different to ‘what do I need for security’ and depends on the grade of your tinfoil hat.
In a major outage wouldn't the masts go down if they don't have their own battery backup and if so how long would that last?
We're doomed Capt Mainwaring, we're doomed.......
Unless you are planning for end of times survival I don't think a genset is needed any more if you have an electric car.
Reasonable electric car with 60kw+ battery will see you through a decent amount of time (enough get the road cleared) and once the battery starts running low you should be able to drive somewhere where you can recharge and then bring it back. A little less convenient than a generator but avoids the extra cost and having to keep fuel around (that's fresh enough to use).
1 hour ago, SteamyTea said:
Very wise.
Does it need much gubbins to plug the output from the rectifier into the house?
(I think there will be a thread about this somewhere.)
That said @Ferdinand s question was more about a simple short term solution.
If you don't have an EV and do have a another use in mind (power when out camping) then the ecoflow/jackery/many other options in the 2-3kwh range would buy you an extra day or two of low energy use (keeping the fridge cool, warming up a meal in the microwave or using a small plug in induction hob/air fryer for a quick cook. Buy a cheap single ring induction burner with it and you can take that camping.
I've seen people do this but its more the sort of thing you do with a pickup truck where you can adjust the RPM of the engine to a higher than normal idle while running your house off a second alternator.
Quite a lot more work/cost to set up than just buying a portable battery. Though a tank of fuel will obviously last a lot longer.
Not really recommended.
Cheap 12V inverters tend not be be proper sine wave ones.
Then there is disconnecting the mains from the grid.
Probably best off writing yourself a list of what you are trying to achieve. Then you can work out what you may need, and the cost effective way to do it.
So say you have a large fridge that takes 300W to run, you may find it cheaper to buy a small one what takes 50W for 120 quid from Curys and plug it in when needed.
Generators Direct
No image preview
Hyundai HY6250SEi Electric Portable Inverter Generator
Power larger motorhomes and glamping setups with the Hyundai HY6250SEi 5kW inverter generator. Electric start and clean, stable power.
The government Be Ready page (and related be informed pages about power cuts etc) has some pretty solid advice.
Making sure to always refill your prescriptions in good time so you always have a few days supply around is the sort of thing I might have missed - running out of essential medication will have a much bigger impact than whether you're eating beans hot off the camping stove or cold from the can for a few days. A battery powered radio may be the most reliable way to keeping receiving news, make sure you've got some cash available. I'm not saying I wouldn't plan for comfort too but keep it proportional, a power bank for your phone might be nearly as useful as a big inverter and cost a lot less.
Pessimistically, in 'end of days' scenarios it'll probably be the average Buildhubber's vast arrange of dangerous tools that'll be most useful as we fight over what's left ('end of days' being at most a week without the supermarket's re-opening I reckon!)
