November 14Nov 14 1 hour ago, Oz07 said:Thats what I was on at last place. As I understand building regs have changed now though?Where our new plot is the phone lines are off telegraph poles. Not sure if we'd even bother with a duct. When i enquired about virgin in last place had the redundant OR duct in and surveyor just sprayed it green.Even with any new regs, our internet via openreach infrastructure was going to be super slow about 4 to 6Mbps. They even said if you want to watch anything on demand don't bother.There other way to do it, in Scotland there is WiFi Scotland which beams WiFi via TV master via line of sight or bounced of repeaters. Several companies exist in all areas of Scotland. Edited November 14Nov 14 by JohnMo Changed beans to beams
November 14Nov 14 15 hours ago, JohnMo said:We just went 4G, easy, cheap and it works.All I used, until it got upgraded to 5G for no extra cost.The house used a Smarty (³) service and my everyday phone uses GiffGaff (O²).As soon as the local O² transmitter near my house is upgraded I will ditch ³. GiffGaff is a tenner a month.Both services have been very reliable.
November 14Nov 14 7 hours ago, worldwidewebs said:Was your duct from the external box through the wall into the house, or under the slab coming up in the house?Over the top of the wall (effectively single storey). I have four ducts in the same location in readiness for things such as solar PV DC cables, satellite dish or other co-ax cables and this Internet cable. There is lots of air tight foam around these four ducts.As it happens the ones for the DC cable won't be required now, and likely neither will the one for co-ax, so they will get sealed
November 14Nov 14 8 minutes ago, BotusBuild said:As it happens the ones for the DC cable won't be required now, and likely neither will the one for co-ax, so they will get sealedDon't seal to tight you can't reverse, I've loads of stuff since finishing the house. External commando socket for generator, ground mount PV etc
November 15Nov 15 Author 17 hours ago, BotusBuild said:Over the top of the wall (effectively single storey). I have four ducts in the same location in readiness for things such as solar PV DC cables, satellite dish or other co-ax cables and this Internet cable. There is lots of air tight foam around these four ducts.As it happens the ones for the DC cable won't be required now, and likely neither will the one for co-ax, so they will get sealedWhen you say over the top of the wall, do you mean that the duct goes up the outside of the wall from the O/R box and then under the eaves? But essentially, the duct doesn't go directly through the wall? Edited November 15Nov 15 by worldwidewebs
November 15Nov 15 The black cable (I had a choice of black or white) goes up the wall from the box and then into a duct at the top of the wall that is now behind some cladding (the cable is to left of the blue line)
November 16Nov 16 While trying to navigate Openreach's online 'customer service' system makes you question your life choices I would persist through the early stages at least to the point where you have a local engineer allocated to your project.Talking to their customer system is a nightmare but I've found the local engineers to be brilliant and very practical. They are also the people who will give you the ducting required for any underground connections.If, at that stage, everything then looks too complicated/expensive then you can still just drop out of the contract with no cost. At least that way you will know you've made the right choice based on full information.
November 17Nov 17 On 14/11/2026 at 07:56, saveasteading said:And as we now know, he will turn it on and off [...] What else might he do?Well he might usefully try growing up. I'm not religious, but that notion of the rich finding it harder to get through the eye of a needle is apt. Not having enough money to achieve some reasonable, worthy goal is a real, tangible, but annoying possession. Money loses meaning as soon as it lulls the owner into the belief that - instead of careful thinking - money alone solves every problem. Lacking funds - At the same time uncomfortable, and extremely useful. The process of getting over the associated self-pity promotes clear thinking. It's bloody hard work. Musk isn't prepared to put in the mental effort. Thats why I despise his behaviour.Lend us a fivver @saveasteading - please.
November 17Nov 17 2 hours ago, ToughButterCup said:Lend us a fiver @saveasteading - please.It's under the flowerpot.
November 18Nov 18 I went with Starlink because i lost the will to live trying to deal with the incompetence of Openreach. Mobile signal is garbage in the village. I never even considered the 'conservation area' aspect of the dish, we are in one i just bought the thing and bolted it in place. I dont care that Starlink is owned by Musk, there are plenty of unpleasant people in the Telecommunications world and in big business generally so what does it matter? He never did me any harm.
November 18Nov 18 Author Thanks for all the replies. My plan is as follows: install a 50mm duct between the driveway and the outside of our technical room; install another duct from that same point that goes under the slab and comes up in the plant room. I won't bother with Duct56 as I don't want to waste my life chasing up Openreach for a few quid of ducting. If that isn't satisfactory to Openreach then I'll fit Starlink and route the cable into the technical room through the second duct.
4 hours ago4 hr We’ve just got our ONT installed this week and the PON light is now green today so we should be linked up to the exchange now. A few notes about how this all went down:We registered our site in Openreach Developer Portal early last year and got given a quote of about £10k. Nuts given that the house next door had fibre, and the pole that served them (yes fibre from the pole was couple metres from our boundary). Tried the ISP route as has been suggested a few times in various places with no luck. One of them tried to disconnect our neighbour because they couldn’t find our address. Others just flat out told us that we couldn’t get fibre. Gave up for over a year then read a post here that I could accept the quote and that would then assign a field engineer you can talk to, and not someone following a script behind a desk. Second time the quite came through it was £8k. Nothing changed from the previous year. Accepted the quote the spoke to field engineer who did the survey and begged and pleaded for them to see what they can do given that the pole was right there… they came back with a quote for £2k which I accepted. I bought my own duct 56 during groundworks so had it coming into my plant room already from under the raft slab. They gave a few more when I signed the contract so that I could bring the duct to the boundary. Route was from plant room to kiosk where the CSP is, then kiosk to boundary. Some misc notes:Original quote is done by someone behind a desk using some data they have on hand. Don’t bother trying to reason with them, they seem to only be and to follow a script for the large part. Their billing department is the worst of them. After getting the revised quote they kept demanding payment for the £8k. Got them to invalidate that eventually. But they are still trying to demand payment for the quote where VAT was applied after we paid the final revised quote with zero rated VAT…My interactions with the field engineer have been good but I’m not sure if I’m lucky so your mileage may vary. Though in general the engineers themselves seem more flexible. We technically now have two splice points. One in the kiosk and one in the plant room. The cable run between the plant room and kiosk was damaged and I wanted the ONT in the network room. Since the cable was being routed through the walls and joist with no way of getting to it anymore they were happy enough for me to run another cable between the plant room and kiosk and to add another splice. Next step is to get an ISP to provide us a service, but the openreach database is still showing as no fibre available so I’m sure there’s going to be a few more challenges ahead to finally get connected…
Just now1 min I don't understand the variations here, our new build FTTP costs £600 for install and that includes going across three telegraph poles and then down into the grey ducting they supplier and i installed. I registered as a developer with them.I was baffled over how cheap it was, and their customer service were a bit of a faff but local engineer was very good. My three neighbours can also get FTTP now as the pole is "enabled" by us.Just had CityFibre install their kit as well yesterday, which was a massive headache as I wanted them to use the grey ducting and they wanted to string the cable from the poles.Again, local engineer... on the third attempt....got his manager to come and onspeftz and the guy just arranged it all on the day.Now FTTP to the property at 900mbps, with a modem that can handle 9000mpbs. That's future proofing!!
