Starlink or fibre broadband?
1 hour ago, Oz07 said:
Thats what I was on at last place. As I understand building regs have changed now though?
Where our new plot is the phone lines are off telegraph poles. Not sure if we'd even bother with a duct. When i enquired about virgin in last place had the redundant OR duct in and surveyor just sprayed it green.
Even with any new regs, our internet via openreach infrastructure was going to be super slow about 4 to 6Mbps. They even said if you want to watch anything on demand don't bother.
There other way to do it, in Scotland there is WiFi Scotland which beams WiFi via TV master via line of sight or bounced of repeaters. Several companies exist in all areas of Scotland.
Edited by JohnMo
Changed beans to beams
15 hours ago, JohnMo said:
We just went 4G, easy, cheap and it works.
All I used, until it got upgraded to 5G for no extra cost.
The house used a Smarty (³) service and my everyday phone uses GiffGaff (O²).
As soon as the local O² transmitter near my house is upgraded I will ditch ³. GiffGaff is a tenner a month.
Both services have been very reliable.
7 hours ago, worldwidewebs said:
Was your duct from the external box through the wall into the house, or under the slab coming up in the house?
Over the top of the wall (effectively single storey). I have four ducts in the same location in readiness for things such as solar PV DC cables, satellite dish or other co-ax cables and this Internet cable. There is lots of air tight foam around these four ducts.
As it happens the ones for the DC cable won't be required now, and likely neither will the one for co-ax, so they will get sealed
Don't seal to tight you can't reverse, I've loads of stuff since finishing the house. External commando socket for generator, ground mount PV etc
When you say over the top of the wall, do you mean that the duct goes up the outside of the wall from the O/R box and then under the eaves? But essentially, the duct doesn't go directly through the wall?
Edited by worldwidewebs
The black cable (I had a choice of black or white) goes up the wall from the box and then into a duct at the top of the wall that is now behind some cladding (the cable is to left of the blue line)
