October 31Oct 31 I need a challenge !3d three.js engine done , super wall click done , custom tv remote almost done .These aren’t 100% complete just requiring parts / 3d printing / motivation- but clearly no technical challenges left .So what next ? A full articulate human robot ? - issue then is vision recognition - that’s a challenge beyond current capabilities!So what next ? Me , Claude ultimate combo - I need new vision , new high bar , next level accomplishment.
October 31Oct 31 Author Kind of thought of this before ….https://mujoco.readthedocs.io/en/stable/index.htmlIt might have to be ….
October 31Oct 31 Author Robot it is !Start with jetson nano orin and oak lite camera . So object recognition and learning first ! Must try not to scale project to early … 🤣
November 1Nov 1 Author Decided no need for Jetson. Also sent m5 back for refund. So PARSEC will leverage the m3 ultra as its brain via wifi.The oak camera should be interesting; got an older edition off ebay for 60 quid.Will use my mac air for testing first with camera with compute done on m3.Later will use a pi or nuc. - as its task is just to stream camera images.OAK-D Lite is the ultimate camera for robotic vision that perceives the world like a human by combining a stereo depth camera and a high-resolution color camera with on-device Neural Network inferencing and Computer Vision capabilities.Key Features:4 TOPS of processing power13 MP central RGB camera available in auto-focus and fixed-focus variantsBMI270 IMU, 6-axis sensor combining accelerometer and gyroscopeUSB2 / USB3 for power delivery and communicationRVC2 architecture on-board features:4 TOPS of processing power (1.4 TOPS for AI - RVC2 NN Performance)Run any AI model, even custom architected/built ones (models need to be converted)Encoding: H.264, H.265, MJPEG - 4K/30FPS, 1080P/60FPSComputer vision: warp (undistortion), resize, crop via ImageManip node, edge detection, feature tracking. You can also run custom CV functionsStereo depth perception with filtering, post-processing, RGB-depth alignment, and high configurabilityObject tracking: 2D and 3D tracking with ObjectTracker nodeBase line: 75 mmIdeal depth range: 40cm - 8m. See technical specifications.Maximum effective depth range: 20mPower consumption: Up to 5W. See technical specificationsIndustrial grade aluminum housing with Front Gorilla Glass1/4" tripod mount and 75mm M4 Vesa mountDimensions & Weight
November 1Nov 1 Author 1 hour ago, -rick- said:You know about ROS?https://www.ros.org/I didn't no. I then mentioned it to Claude why this had been missed as it's clearly of considerable use. It said we are at Stage 1; Stage 2 is ROS - (expletive deleted)ing liar I thought!Looking back in the long Claude conversation I do now see "ROS" mentioned ... but its like in a list of stages with no explanation or detail.So Claude was correct! as it frequently is of course. Edited November 1Nov 1 by Pocster Ai showed me up
November 6Nov 6 Author A bit of project creep.....PARSEC: a home robot I’m building in stagesPARSEC (Pocster Adaptive Reasoning, Sensing & Embodied Cognition) is a home robot that learns my own objects, remembers where it last saw them, and eventually goes and fetches them. I’m treating it as an R&D project. Every capability gets a measured pass/fail test, and the target to beat is published research results for home fetch robots.How it’s laid outThe brain is a Mac Studio (M3 Ultra) that stays at home. It does all the heavy work: vision, object recognition, memory and, later, a local vision-language model.The robot carries one small onboard PC (a GMKtec mini PC). It runs the sensors and motors and streams everything to the Mac over Wi-Fi. Everything plugs into it over USB, with no Arduinos or separate microcontrollers.Teaching an object: I hold it up and the robot cuts it out of the image with SAM 2. It then builds a visual fingerprint with DINOv2 from several angles. Depth data puts each sighting at a 3D position, which goes into memory.PartsVision: OAK-D Lite depth camera, which does some detection on the camera itselfHead: pan-tilt made from serial-bus servosBase: two hub-motor wheels with built-in encoders, castors, an aluminium extrusion frame and LiDAR for mappingArms: two SO-101 arms printed at home with Feetech servos. One has a two-finger gripper and the other has Seeed’s Amazing Hand. Touch-sensing fingertips are planned.Spine: a mast with a lift, so the arms can reach both the floor and the worktopsPower: a 24 V LiFePO4 battery split into several rails through DC-DC converters, with a current gauge. A hardware e-stop cuts the motors while the computer stays on to log what happened. It charges itself at a dock.Brackets and mounts: designed as code and 3D printedStages and goalsLearning eye (current stage): live detection, teaching it 5 of my own objects, and recognising them from angles it hasn’t seenWatching room: the pan-tilt head scans the room so it can answer “where’s my remote?” from memory. It also recognises me, and ties into Home Assistant and my existing voice assistant.Wheels: mapping, driving itself to named rooms, searching for objects, and a proper safety layer (watchdog, speed limits, no-go zones, stall detection)Arms: grasping and fetching (“bring me the remote”). The goal is to beat the published success rate for real-home fetching. There’s also a fun benchmark: playing an arcade cabinet by sight alone.A simulation twin runs alongside the build to check tipping, motor margins and arm reach before the hardware for each stage is committed.Where it’s atWorking: the camera-to-brain link, tested with synthetic frames.Status screen: a 3D twin of the robot and house, with panels showing what it sees, believes, plans and does. It’s rewindable and viewable from a phone, and runs on sample data until the robot exists.Parts: mostly ordered and arriving now. The first real job is the camera range test.Later ideas include “did I leave the hob on?” checks with photo proof, spotting damp and leaks, telepresence, and eventually letting it swap its own tools.
