Thursday at 14:545 days Are there any other reversible monobloc ASHPs in the 4-5kW max output range... Daikin EBLA04 (R32 based) Vaillant aroTHERM Plus v2 3.5kW Samsung 5kW Gen 7 R290 Grant Aerona 290 4kW HPR2904 TIA
Thursday at 15:345 days Haier R290 4kW, comes out the box setup for heating and cooling, wouldn't bother with R32 as R290 in the real world performs better as they are generally the next generation design.
Thursday at 16:105 days Midea M Thermal. Pretty trivial to switch between heat/cool/both using the built in controller
Thursday at 17:025 days 43 minutes ago, -rick- said: Of the modern r290 ones are there any that don't support cooling? Octopus, Ebac, a lot of Mitsubishi and Daikin ones, don't support cooling at all and others. Valiant needs a widget to make it work, Grant only enables cooling if you do not select radiators within your heating system. Not sure about Viessmann. Panasonic does support cooling also out the box.
Thursday at 17:125 days 10 minutes ago, JohnMo said: Octopus, Ebac, a lot of Mitsubishi and Daikin ones, don't support cooling at all and others. Valiant needs a widget to make it work, Grant only enables cooling if you do not select radiators within your heating system. Wow, ok. That's a lot more than I thought.
Thursday at 17:155 days Author FWIW one of Valliant guys on their stand at the NEC a couple of weeks told me they included the resistor for cooling with the plus model.
Thursday at 17:175 days Well I raised potential cooling with the service engineer who came today. Mines a Vaillant and whilst it apparently can do it he didn't recommend it as the "underfloor pipes can contract and crack the concrete". I wasn't going for the sub-zero approach, merely say 16 degrees.......
Thursday at 17:245 days 2 minutes ago, kandgmitchell said: Well I raised potential cooling with the service engineer who came today. Mines a Vaillant and whilst it apparently can do it he didn't recommend it as the "underfloor pipes can contract and crack the concrete". I wasn't going for the sub-zero approach, merely say 16 degrees....... That will be right - not
Thursday at 21:065 days We have a 6kW R290 Maxa. Slightly higher power than you ask for but seems to be ok. Comes in a pleasant colour too (for it’s position in our garden). Is there any difference in sound level in general between R32 and R290?
Friday at 07:435 days 10 hours ago, G and J said: sound level in general between R32 and R290? Comparing our Maxa R32 (now heating our hot tub) and Haier R290, the R290 makes slightly less noise, but both are not noisy. The R290 has a bigger fan that runs slower and a bigger evaporator, so air flow rate is lower circa given load. Edited Friday at 07:445 days by JohnMo
3 hours ago3 hr I would include the Vaillant 5kW, which is the model i have.Don't discount it just because you need the resistor, its less than £10 even if you have to buy one and its trivial to fit.
3 hours ago3 hr On 16/10/2026 at 08:43, JohnMo said:(now heating our hot tub)Thread hijack alert- how did you plumb this? PHX? I want to use the HW cycle from my second HP to do this for our HT, have bought all the parts but just haven’t gotten around to doing it. Just wondered if I was overcomplicating…
2 hours ago2 hr 5 kw panasonic J series. WH-MDC05J3E5Does cooling out of the box. Very easy to set up, cheap as chips, and now available in anthracite.
2 hours ago2 hr The Cool Energy units can do cooling out of the box, not sure if they go small enough.
39 minutes ago39 min 2 hours ago, Wil said:Thread hijack alert- how did you plumb this? PHX? I want to use the HW cycle from my second HP to do this for our HT, have bought all the parts but just haven’t gotten around to doing it. Just wondered if I was overcomplicating…Pretty simple plumbing, I just have an after filter and used thick wall hose as pipe, which is also insulated. One issue that came up was main pump cavitation due to the pump being at top of the ASHP package. So have installed a spare Wilo pump I had laying around. This is in the suction line and runs 24/7. Main ASHP only runs in Cosy tariff windows and use a timer acting on the external thermostat terminals.But I cannot use chlorine based chemicals, so use a bunch of copper fittings in a bag, non chorine shock dose intermittently and sodium peroxide (12.99%) as routine bio-growth prevention.But you would need to keep CH water and HT water apart. Chlorine stuff above would also apply unless you use a titanium heat exchanger as opposed to Stainless 304 which are more normal
Just now1 min @JohnMo Thanks, I got a Bowman heat exchanger, but the thought and pain of cutting into the pipework under the tub is what puts me off most. I tend to use Bromine rather than chlorine but haven’t looked into changing chemicals. I’m also trying to plumb this in parallel with the existing element and controls to keep those running once warm. HT hasn’t had water in it for a couple of months while I scratch my…. Head
