Stu789 Posted 10 hours ago Posted 10 hours ago Are there any other reversible monobloc ASHPs in the 4-5kW max output range... Daikin EBLA04 (R32 based) Vaillant aroTHERM Plus v2 3.5kW Samsung 5kW Gen 7 R290 Grant Aerona 290 4kW HPR2904 TIA
JohnMo Posted 9 hours ago Posted 9 hours ago Haier R290 4kW, comes out the box setup for heating and cooling, wouldn't bother with R32 as R290 in the real world performs better as they are generally the next generation design.
torre Posted 9 hours ago Posted 9 hours ago Midea M Thermal. Pretty trivial to switch between heat/cool/both using the built in controller
-rick- Posted 9 hours ago Posted 9 hours ago Of the modern r290 ones are there any that don't support cooling?
JohnMo Posted 8 hours ago Posted 8 hours ago 43 minutes ago, -rick- said: Of the modern r290 ones are there any that don't support cooling? Octopus, Ebac, a lot of Mitsubishi and Daikin ones, don't support cooling at all and others. Valiant needs a widget to make it work, Grant only enables cooling if you do not select radiators within your heating system. Not sure about Viessmann. Panasonic does support cooling also out the box.
-rick- Posted 8 hours ago Posted 8 hours ago 10 minutes ago, JohnMo said: Octopus, Ebac, a lot of Mitsubishi and Daikin ones, don't support cooling at all and others. Valiant needs a widget to make it work, Grant only enables cooling if you do not select radiators within your heating system. Wow, ok. That's a lot more than I thought.
Stu789 Posted 8 hours ago Author Posted 8 hours ago FWIW one of Valliant guys on their stand at the NEC a couple of weeks told me they included the resistor for cooling with the plus model.
kandgmitchell Posted 8 hours ago Posted 8 hours ago Well I raised potential cooling with the service engineer who came today. Mines a Vaillant and whilst it apparently can do it he didn't recommend it as the "underfloor pipes can contract and crack the concrete". I wasn't going for the sub-zero approach, merely say 16 degrees.......
JohnMo Posted 7 hours ago Posted 7 hours ago 2 minutes ago, kandgmitchell said: Well I raised potential cooling with the service engineer who came today. Mines a Vaillant and whilst it apparently can do it he didn't recommend it as the "underfloor pipes can contract and crack the concrete". I wasn't going for the sub-zero approach, merely say 16 degrees....... That will be right - not
G and J Posted 4 hours ago Posted 4 hours ago We have a 6kW R290 Maxa. Slightly higher power than you ask for but seems to be ok. Comes in a pleasant colour too (for it’s position in our garden). Is there any difference in sound level in general between R32 and R290?
