Are there any other reversible monobloc ASHPs in the 4-5kW max output range...
Daikin EBLA04 (R32 based)
Vaillant aroTHERM Plus v2 3.5kW
Samsung 5kW Gen 7 R290
Grant Aerona 290 4kW HPR2904
TIA
Haier R290 4kW, comes out the box setup for heating and cooling, wouldn't bother with R32 as R290 in the real world performs better as they are generally the next generation design.
Midea M Thermal. Pretty trivial to switch between heat/cool/both using the built in controller
43 minutes ago, -rick- said:
Of the modern r290 ones are there any that don't support cooling?
Octopus, Ebac, a lot of Mitsubishi and Daikin ones, don't support cooling at all and others. Valiant needs a widget to make it work, Grant only enables cooling if you do not select radiators within your heating system.
Not sure about Viessmann.
Panasonic does support cooling also out the box.
Wow, ok. That's a lot more than I thought.
FWIW one of Valliant guys on their stand at the NEC a couple of weeks told me they included the resistor for cooling with the plus model.
Well I raised potential cooling with the service engineer who came today. Mines a Vaillant and whilst it apparently can do it he didn't recommend it as the "underfloor pipes can contract and crack the concrete". I wasn't going for the sub-zero approach, merely say 16 degrees.......
That will be right - not
