I would dearly love to have a freestanding tap in the garden, but is it worth the effort required to stop it freezing.  But I hate taps on the wall.
Frostline taps have some self draining mechanism to stop them frosting up but still require a nearby valve in the ground.  If I need to put a valve in the ground then I may as well just install a regular free standing tap and then a drain valve in a nearby box to drain it in the autumn.
Bernard the builder is already rolling his eyes over this, what to do?
Edited by Mr Blobby
1 minute ago, -rick- said:
And then insulate the pipe with the heating tape on the inside
Yes, that's how most were done.
19 minutes ago, Onoff said:
Hmm, I was thinking the self regulating PTC kind. Just looked at the link and this type is controlled by a thermostat. Might be a bit difficult with insulation then.
TLC seem to sell the self regulating kind on the same page, but then looks like you need to do the termination yourself which is a bit more involved than normal domestic electrics.
Bernard might forgive you for this one. Plenty of garden pipework bursts in a hard winter, and the installs that survive are the boring ones: an isolation valve with a drain off cock on the feed inside the building, pipe buried well below frost depth, and a self draining tap on the end. The trace heating ideas are fine too, but the indoor valve plus drain off is simpler, cheaper and nothing electrical to go wrong.
