Alwayslearning22 Posted Friday at 16:10 Posted Friday at 16:10 Do I need to replace this flexi I think I damaged it a bit changing the tap at the very start near connector it’s hose is exposed more
Alwayslearning22 Posted Friday at 18:10 Author Posted Friday at 18:10 it’s damaged at the top of the hose right at the connection point. anyone help would save me a lot of worry
Nickfromwales Posted Saturday at 06:39 Posted Saturday at 06:39 12 hours ago, Alwayslearning22 said: it’s damaged at the top of the hose right at the connection point. anyone help would save me a lot of worry Is it mains pressure or gravity fed? I had to squint to see the damage, but unfortunately it is there. The hose needs to be replaced imo as the braiding has very little mechanical purchase on that compressed ring and it’ll be very reliant on that to stop any further unravelling. These are cheap, go get a new one Out of curiosity, are you using the wrong tools for this job?
Alwayslearning22 Posted Saturday at 07:14 Author Posted Saturday at 07:14 30 minutes ago, Nickfromwales said: Is it mains pressure or gravity fed? I had to squint to see the damage, but unfortunately it is there. The hose needs to be replaced imo as the braiding has very little mechanical purchase on that compressed ring and it’ll be very reliant on that to stop any further unravelling. These are cheap, go get a new one Out of curiosity, are you using the wrong tools for this job? It’s gravity fed with a booster pump. I used one of those basin wrenches but I think I may have caught the pipe a few times with it? Not really sure how it happened to be honest. should I replace it straight away? Could it burst while out of the house job? Thanks Nick
Nickfromwales Posted Saturday at 09:52 Posted Saturday at 09:52 2 hours ago, Alwayslearning22 said: It’s gravity fed with a booster pump. I used one of those basin wrenches but I think I may have caught the pipe a few times with it? Not really sure how it happened to be honest. should I replace it straight away? Could it burst while out of the house job? Thanks Nick It won’t burst today or tomorrow, but change it asap. Leave this at your peril. Is it a full bore flexi?
Alwayslearning22 Posted Saturday at 10:55 Author Posted Saturday at 10:55 55 minutes ago, Nickfromwales said: It won’t burst today or tomorrow, but change it asap. Leave this at your peril. Is it a full bore flexi? It’s full bore yes. can I reuse the olive on this brass section coming from press fit? Also I’m struggling to find the right hose
Nickfromwales Posted Saturday at 11:44 Posted Saturday at 11:44 49 minutes ago, Alwayslearning22 said: It’s full bore yes. can I reuse the olive on this brass section coming from press fit? Also I’m struggling to find the right hose Yea. Leave the nut and olive on. Just add some jointing compound and she’ll be mint. 1
Alwayslearning22 Posted Saturday at 12:06 Author Posted Saturday at 12:06 20 minutes ago, Nickfromwales said: Yea. Leave the nut and olive on. Just add some jointing compound and she’ll be mint. Any idea what type of hose I need? The nut says it’s 21mm on it thanks Nick
Nickfromwales Posted Saturday at 14:22 Posted Saturday at 14:22 2 hours ago, Alwayslearning22 said: Any idea what type of hose I need? The nut says it’s 21mm on it thanks Nick Should be a standard large bore 22mm x 3/4” flexi: Link 1
Gone West Posted Saturday at 14:52 Posted Saturday at 14:52 26 minutes ago, Nickfromwales said: Should be a standard large bore 22mm x 3/4” flexi: Are corrugated stainless steel flexi connectors a better type, or are there any downsides? https://ridgelinetubes.com/flexis/
Nickfromwales Posted Saturday at 16:20 Posted Saturday at 16:20 1 hour ago, Gone West said: Are corrugated stainless steel flexi connectors a better type, or are there any downsides? https://ridgelinetubes.com/flexis/ Never used them before tbh, so may give them a whirl. Seems to make sense to upgrade if these are kosher.
Alwayslearning22 Posted Saturday at 16:36 Author Posted Saturday at 16:36 2 hours ago, Nickfromwales said: Should be a standard large bore 22mm x 3/4” flexi: Link Perfect, I’ll not get it done until Monday can’t get any fittings around here until then. Is it safe to leave the flexi as it is until then? Would you say it’s unlikely to burst. It’s actually less than a year old. thanks Nick your a godsend on here
Nickfromwales Posted Saturday at 16:55 Posted Saturday at 16:55 18 minutes ago, Alwayslearning22 said: Perfect, I’ll not get it done until Monday can’t get any fittings around here until then. Is it safe to leave the flexi as it is until then? Would you say it’s unlikely to burst. It’s actually less than a year old. thanks Nick your a godsend on here If the pumps not on then it’s only holding back gravity It’ll be fine. When the pumps running it’s not under huge pressure either. Issues are largely when these are sat with full mains pressure 24/7, and then fail quite quickly (flood o’clock). You should be good until then or longer.
Alwayslearning22 Posted Saturday at 17:08 Author Posted Saturday at 17:08 12 minutes ago, Nickfromwales said: If the pumps not on then it’s only holding back gravity It’ll be fine. When the pumps running it’s not under huge pressure either. Issues are largely when these are sat with full mains pressure 24/7, and then fail quite quickly (flood o’clock). You should be good until then or longer. Brilliant. Now I can sleep tonight. Haha Thanks mate 1
Nickfromwales Posted Saturday at 18:30 Posted Saturday at 18:30 1 hour ago, Alwayslearning22 said: Brilliant. Now I can sleep tonight. Haha Thanks mate LINK 1
Alwayslearning22 Posted Monday at 12:39 Author Posted Monday at 12:39 On 26/09/2026 at 19:30, Nickfromwales said: LINK Tried changing this today the brass olive wasn’t even compressed it slid off. I can’t for the life of get a copper or brass to compress properly on the brass stub
Nickfromwales Posted Monday at 18:17 Posted Monday at 18:17 5 hours ago, Alwayslearning22 said: Tried changing this today the brass olive wasn’t even compressed it slid off. I can’t for the life of get a copper or brass to compress properly on the brass stub It just uses compression to form a grip / seal. An olive wont compress a brass stem, like bringing a knife to a gunfight Just pinch it up with a bit of oomph, and test for leaks. 👍
Alwayslearning22 Posted Monday at 18:27 Author Posted Monday at 18:27 7 minutes ago, Nickfromwales said: It just uses compression to form a grip / seal. An olive wont compress a brass stem, like bringing a knife to a gunfight Just pinch it up with a bit of oomph, and test for leaks. 👍 I’m really struggling to tighten it up. I’m lucky to even get a quarter turn on it. the original olive was brass. I put it back on and tightened as much as I can. so is it normal to tighten this and then if I were to undo it the olive would be able to slide off easily?
Alwayslearning22 Posted Monday at 18:30 Author Posted Monday at 18:30 (edited) Where should I be putting the spanner to stop everything rotating on this? Thanks Edited Monday at 18:35 by Alwayslearning22
MPH243 Posted Monday at 18:42 Posted Monday at 18:42 One spanner on nut and second one on the hex above male thread(it's not very big), should stop everything spinning. The olive won't compress on the brass but will seal with jointing compound. 2
Alwayslearning22 Posted Monday at 18:47 Author Posted Monday at 18:47 3 minutes ago, MPH243 said: One spanner on nut and second one on the hex above male thread(it's not very big), should stop everything spinning. The olive won't compress on the brass but will seal with jointing compound. When I do that and tighten nut, once I put force on it the pipe starts turning under the floor 😩
Alwayslearning22 Posted Monday at 18:52 Author Posted Monday at 18:52 Is the black plastic ring on the press fitting supposed to have movement on it ? have I messed it up now? 😣
Nickfromwales Posted Monday at 19:31 Posted Monday at 19:31 35 minutes ago, Alwayslearning22 said: Is the black plastic ring on the press fitting supposed to have movement on it ? have I messed it up now? 😣 Not sure as I "don't do pressfit"..... The two nuts can be pulled towards each other and the pipework below can be kept 'still', if you connect the flexi only a few turns hand tight onto the bath tap first, then finish tightening, and then go back to do the final tighten on the bath connector last. You can balance how much you pull on each spanner until tight, without transferring any rotational force 'down below'. The answer to the question "have I fecked it?", will be answered when the pump kicks in fella. Just suck it up and whack it on, the worst thing that can happen is in that link. Crack on 2
Alwayslearning22 Posted Monday at 19:41 Author Posted Monday at 19:41 9 minutes ago, Nickfromwales said: Not sure as I "don't do pressfit"..... The two nuts can be pulled towards each other and the pipework below can be kept 'still', if you connect the flexi only a few turns hand tight onto the bath tap first, then finish tightening, and then go back to do the final tighten on the bath connector last. You can balance how much you pull on each spanner until tight, without transferring any rotational force 'down below'. The answer to the question "have I fecked it?", will be answered when the pump kicks in fella. Just suck it up and whack it on, the worst thing that can happen is in that link. Crack on I think I’m too dumb for those instructions haha can you dumb that down a bit
MPH243 Posted Monday at 20:26 Posted Monday at 20:26 You are not dumb, you got this far. @Nickfromwales was meaning loosen the nut against the tap a little this will allow it to spin, Then if you have the spanner handles close to each other so when doing up they close up the gap(kep fingers out of the gap it can hurt if it slips😂). You should not turn the pipe, then tighten nut to tap. Did the tap and all pipe work spin under the floor? As nick said get this connected and see if the other leaks. 1
