4 hours ago, Roundtuit said:
You really need to mouse-proof the house, not the cable, for all sorts of safety and health reasons, and sort out the current infestation ASAP if you've had mouse damage to new stuff within two days.
Hi Roundtuit, thanks for reply.
Yup absolutely- but.. when I took out replacement fridge today, I looked underneath & saw the dishwasher & sink waste pipes dissapear way off twds RHS twds corner of other worktop cupboards. Simply no way (without all worktops & cabinets removed that is) I could get to the wall corner, to sure up around pipes with steel mesh.
Anyway, my method of chopping all but 6" of Mum's fridge cable off, & adding a plug on, seems to have paid off. This meant I could separate the white extension cable from it, pass the female end of this thru sink cabinet back hole, then with a coathanger stretched out & a hook on the end.. looked underneath, & really rather brilliantly, fished/ hooked the socket out twds me, & mated it to fridge plug. Doddle then to put fridge back.
Also then a doddle to undo out again, & add some flexi ribbed 20mm black conduit to sheath the white extension cable, which even I thought looked appetising to gnaw on. When I can stumble on such pipey numnums that is.
Mum pleased.
I thank you. Zoot.
Edited by zoothorn
Top tip, never work with cables if you've been eating, sandwiches etc and not washed your hands thoroughly. All that crumby, oily goodness leaves traces on the cables that makes it attractive to rodents.
You could invest in a can of Anti Marten  spray. I spray vulnerable areas and under the bonnets of parked cars with it.
