Alwayslearning22 Posted August 9 Posted August 9 Hi all, I’ve noticed damp odours coming from sockets on an exterior wall in my new home. It’s only one wall and it’s about 4 metres. The rest of the house is good. I’m afraid the smell is coming from behind the air tightness memebrane as It must havre some punctures in that area. So I’m thinking is there mould on the studs or insulation? If it were your house what would you do? Where would you start? thanks
JohnMo Posted August 9 Posted August 9 1 hour ago, Alwayslearning22 said: If it were your house what would you do? Where would you start Go back to the builder - tell him the issue. Or is this a self build? Could be a small leak from water pipes also.
Nickfromwales Posted August 9 Posted August 9 27 minutes ago, JohnMo said: Go back to the builder - tell him the issue. Or is this a self build? This. 1 hour ago, Alwayslearning22 said: If it were your house what would you do? Where would you start? I’d remove the plasterboard from the whole wall, from 200mm of FFL (so skirting remains undisturbed) up to around 1200mm, staying 500mm away from the left and right corners, and look at this very intensively. 1
Nickfromwales Posted August 9 Posted August 9 If you start the work then you’ll lose the ability to sue the builder btw, so, if this is the case, get them to come and do removals. 1
Alwayslearning22 Posted August 9 Author Posted August 9 I had the foreman in and he said he can’t smell anything. So I’d like to gather some evidence. there’s no pipes on that wall I also noticed today I can smell it from my bedroom sockets which is the floor above but a few metres to the right near to the end of the house
Mr Punter Posted August 9 Posted August 9 Smell is very difficult to establish and prove. Actual moisture and mould can be measured and photographed. Have you had anyone else in to verify the smell, like a mate or your partner? If it is really obviously bad you should go back to the housebuilder and register it as an official issue, stating that x people have also noticed it. 2
Alwayslearning22 Posted August 9 Author Posted August 9 7 hours ago, Nickfromwales said: If you start the work then you’ll lose the ability to sue the builder btw, so, if this is the case, get them to come and do removals. The builder doesn’t “smell anything” if there are issues wouldn’t it be behind the vcl would I need to cut this open to inspect framing?
Nickfromwales Posted August 10 Posted August 10 14 hours ago, Alwayslearning22 said: The builder doesn’t “smell anything” if there are issues wouldn’t it be behind the vcl would I need to cut this open to inspect framing? Yes, most likely. Is it a block & beam floor?
Nickfromwales Posted August 10 Posted August 10 15 hours ago, Mr Punter said: Smell is very difficult to establish and prove. Actual moisture and mould can be measured and photographed. Have you had anyone else in to verify the smell, like a mate or your partner? If it is really obviously bad you should go back to the housebuilder and register it as an official issue, stating that x people have also noticed it. +1.
Alwayslearning22 Posted August 10 Author Posted August 10 1 hour ago, Nickfromwales said: Yes, most likely. Is it a block & beam floor? No it’s just a concrete slab. How would inside a closed panel even get damp? There are no windows on this wall.
Nickfromwales Posted August 11 Posted August 11 21 hours ago, Alwayslearning22 said: No it’s just a concrete slab. How would inside a closed panel even get damp? There are no windows on this wall. Ventilated cavities will allow things to blow about quite indiscriminately, so maybe we’d need some section drawings to help work out what is actually going on here.
