Spinny Posted yesterday at 14:41 Posted yesterday at 14:41 1/ Drainage Chamber - does it need changing ? The photo shows a drainage chamber installed by my long departed builder. The kitchen sink & dishwasher waste water will come down from the top right, and then flow out at the bottom of the photo. A drainage guy today told me it has been installed wrong and there should be a swept bend between inflow and outflow. The fall is not high and the input pipe is about 4m long. Should I get it sorted now with some other drainage issues, or leave well alone ? And what should it look like ? 2/ Shared Drain Manhole - If I get it replaced will I get rats ? My drain manhole at front of the house is also fed into by the neighbours drain. Drainage guy says if I can persuade the water company they will replace it with a new one. Apparently the new ones will have a straight through outlet to the main sewer for the road, rather than the existing one which has a U / S bend with water trap (plus a plugged bypass). This makes me very nervous as we have had RATS some years ago when the bypass cap was left off. Guy claims rats can swim through a water trap (though I have yet to see one pop up in the toilet !). With no water trap on the shared manhole output I would fear a rat infestation ?
crispy_wafer Posted yesterday at 14:53 Posted yesterday at 14:53 I’ve not seen a base like that one tbf, being pragmatic about it, if it’s grey water and it flows without stalling then I don’t see a reason to change. Don’t understand why you’d need a swept bend, the chamber is fine as that provides a bend between in and out.
G and J Posted yesterday at 16:41 Posted yesterday at 16:41 You can buy a one way valve that you can pop in and it stops rats. Amazon sells a good quality Rosshield one. And yes, they can swim.
Spinny Posted yesterday at 18:08 Author Posted yesterday at 18:08 Jeepers...scream...yes... and shit standing up for evermore... https://www.express.co.uk/news/weird/1948864/woman-screams-rat-stares-up
Mr Punter Posted yesterday at 18:21 Posted yesterday at 18:21 The chamber is fine. The old chambers with the traps often get blocked and are not used now. The rat blockers fitted inside the chamber work well.
Nickfromwales Posted 22 hours ago Posted 22 hours ago 4 hours ago, G and J said: You can buy a one way valve that you can pop in and it stops rats. Amazon sells a good quality Rosshield one. And yes, they can swim. No magic flap is inedible. It may stop them walking, won’t stop them gnawing through it; they get through concrete for context.
Nickfromwales Posted 22 hours ago Posted 22 hours ago 3 hours ago, Spinny said: Jeepers...scream...yes... and shit standing up for evermore... https://www.express.co.uk/news/weird/1948864/woman-screams-rat-stares-up Time for a day off the internet for you. 1
Mr Punter Posted 5 hours ago Posted 5 hours ago 16 hours ago, Nickfromwales said: No magic flap is inedible. It may stop them walking, won’t stop them gnawing through it; they get through concrete for context. The stainless steel ones seem pretty good. I had one fitted and it stopped the rats and has not caused blockages. Some of them have a mechanism that allows them to be fitted fairly deep in an inspection chamber.
