Alan Ambrose Posted 8 hours ago Author Posted 8 hours ago Quote I went the max panel and inverter route. Size of inverter was partly determined by desire to cover peaks without drawing from grid i.e. kettle, toaster, air fryer all on at same time. This allowed for a large number of panels (24). This was dictated strongly by my (carport) roof size. I wanted to get it looking neat so fewer panels would look stupid. 24 panels filled the roof really nicely. It also compensated for sub optimal angle and orientation (12 degrees and South West). It also allowed reasonable generation (enough to cover daily demand) in the shoulder months as the panels are badly shaded by trees and the house. All in all we have zero import for 6 months and produce about 25% of demand in deep winter. The array easily saturates my export limit (a measly 3.6kw) so we have alot of potential excess in the summer. One advantage of the big array and inverter in the winter is the charge rate can be really high so you can take advantage of the 2 or 3 hours of sun during an otherwise dull day. 3 hours of good sun is about all I need to top up. @Beelbeebub Yeah, that's pretty much what I want to do for similar reasons. Presumably you had to limit the export in software but had a much larger inverter?
scottishjohn Posted 7 hours ago Posted 7 hours ago 22 minutes ago, Alan Ambrose said: @Beelbeebub Yeah, that's pretty much what I want to do for similar reasons. Presumably you had to limit the export in software but had a much larger inverter? why are you limited to export volume?
scottishjohn Posted 7 hours ago Posted 7 hours ago On 06/08/2026 at 08:31, G and J said: For us and I assume many, maxing the panels on one face of the roof was a no brainer as it saved slate (I’m not a fan of surface mount panels). I did look at that but was assured by builder that by the time they GRP that area there would be no savings and possible problems over time if not GRP below the panels
Alan Ambrose Posted 5 hours ago Author Posted 5 hours ago >>> why are you limited to export volume? Well the DNO will always limit, even if it's only to 17kW on single phase - it's a risk thing with local voltages apparently. And we have planning permission to cover one roof and the 'cartlodge' with panels.
Dillsue Posted 5 hours ago Posted 5 hours ago 2 hours ago, scottishjohn said: why are you limited to export volume? Are you talking about volume/quantity(kwh) or the rate(kw) of export?? I don't think anyone in a domestic situation gets limited on the volume they can export but everyone gets limited on the rate they can export as ultimately you'll blow your service fuse if you try and push power into the grid too fast! Most are limited way below the power that would blow their fuse though!
scottishjohn Posted 4 hours ago Posted 4 hours ago (edited) 1 hour ago, Alan Ambrose said: >>> why are you limited to export volume? Well the DNO will always limit, even if it's only to 17kW on single phase - it's a risk thing with local voltages apparently. And we have planning permission to cover one roof and the 'cartlodge' with panels. yes I knew that one -- unless you get a different export permit 16 kW per phase is what I remember form when I got my 3 phase supply when I asked how big a system I could run but it will be limited really by your invertor size and I see 11kW at most as my invertor is 11.5kW-- But seen it a few times this summer It just sounded like he was limited to the amount of kW he could send back per day good days here i,ve been sending back 50-60 kW Edited 4 hours ago by scottishjohn
-rick- Posted 2 hours ago Posted 2 hours ago 1 hour ago, scottishjohn said: 16 kW per phase It's 16A per phase, ie, 3.8kW
SteamyTea Posted 2 hours ago Posted 2 hours ago 16 (amp) x 230 (nominal voltage) = 3.68 kW (power per phase)
-rick- Posted 2 hours ago Posted 2 hours ago 5 minutes ago, SteamyTea said: 16 (amp) x 230 (nominal voltage) = 3.68 kW (power per phase) Yes, but mostly no. Technically the nominal voltage is 230V but for the vast amount of consumers the voltage at their socket is closer to 240 (likely higher). The limit is set by amps to avoid any confusion here. You can export 16A whatever your local voltage.
SteamyTea Posted 2 hours ago Posted 2 hours ago 1 minute ago, -rick- said: The limit is set by amps to avoid any confusion here Correct.
Dillsue Posted 2 hours ago Posted 2 hours ago 2 minutes ago, -rick- said: Yes, but mostly no. Technically the nominal voltage is 230V but for the vast amount of consumers the voltage at their socket is closer to 240 (likely higher). The limit is set by amps to avoid any confusion here. You can export 16A whatever your local voltage. 16A is without consent via G98. We have 32A via a G99 but I think others have posted higher limits.
Beelbeebub Posted 38 minutes ago Posted 38 minutes ago 7 hours ago, Alan Ambrose said: @Beelbeebub Yeah, that's pretty much what I want to do for similar reasons. Presumably you had to limit the export in software but had a much larger inverter? Yes. 8kw inverter 3.6kw export
Beelbeebub Posted 37 minutes ago Posted 37 minutes ago 7 hours ago, scottishjohn said: why are you limited to export volume? I should have said export power - 16A export limit.
Beelbeebub Posted 35 minutes ago Posted 35 minutes ago 1 hour ago, SteamyTea said: Correct. What is slightly annoying is my inverter limits by power - which varies the amps as the voltage goes up and down. My voltage is regularly high 240's so i could export about 4kw but occasionally it dips to 230 or so which is only 3.6kw It would be nice if the inverter had a current limit export
SteamyTea Posted 30 minutes ago Posted 30 minutes ago 3 minutes ago, Beelbeebub said: It would be nice if the inverter had a current limit export I am not sure how current gets limited.
